Old 10-21-2014, 02:25 AM   #21196
Gonz13's Avatar
Originally Posted by J@EastmanPark View Post
Hello, I have a question I'm hoping someone can answer. I run a small refurb business and am needing some gears, the Idler gears on your cars look perfect. I've searched all over and still haven't found the Diameter of that gear in particular. If anyone could help me it would be greatly appreciated.
Have a look at an online hobby store, like amain, and search for idler gears. There's a big variety of sizes/ pitches. You might also want to look for other gears, like pinion gears or differential gears, depending on what you're after.
Here's a link that might be useful:
http://www.amain.com/Radio-Control
Gonz.
TLR 22
Gonz13 is offline   Reply With Quote
Old 11-20-2014, 11:04 AM   #21197
Default ???
could somebody tell me which way is the right, to get 25degr kickup for tlr22 bugy:
1. I only need to add a 25degr shim over 20degr insert,
or
2. I must replace put 25degr. shim instead of 20degr. one.
So which is the right way?
hardijs is offline   Reply With Quote
Old 11-21-2014, 04:12 AM   #21198
30Tooth's Avatar
#2 is the correct answer.
I like 20degrees of kickup way more than the 25degree kickup. Felt better and for more traction I use the 1degree anti squat.
<Hephaestos RC> check out these URLs - www.rctech.net/forum/tags/spreadsheet.html
www.rctech.net/forum/racing-forum/775876-crmpl-off-road-track.html
Brands I like - JQRacing, Kyosho, LM Engines, Mugen Seiki, Graupner, Robitronic
30Tooth is offline   Reply With Quote
Old 11-21-2014, 06:45 AM   #21199
Thanks for advice!
I already did it in a such a way- replaced 20degr and put in it place 25degr shim + replaced caster blocks 10degr to 5degr and buggy on small high bite carpet track become undrivable - on each corner on entering the corner back of the car was not possible to keep on rails it spined out (tires where schumi minipins - a little worn, but still good for such a track) , so I started to think that I did it wrong...but yeah if thats is the right way to get 25degr. kickup, then I also like much better 20degr. kickup
What effect could give if I use 20degr. kick up with 5degr. caster blocks (instead of 10degr.) - will it make car more edgy or will it car cam down?
Old 11-22-2014, 04:06 AM   #21200
30Tooth's Avatar
No problem.
Edgy entering corners, at least on my testing. But I don't race on carpet yet, you should try changing caster just to see.
Old 12-22-2014, 02:27 PM   #21201
Rustynuts's Avatar
Trader Rating: 15 (100%+)
Does anyone have a good setup for a big 1/8 size track, mostly loomy dirt and rough? I have the Dustin Evans setup on it now but not sure if thats the best for my track. Here is the track
https://www.youtube.com/watch?v=1jpHbrK8n20
Rustynuts is offline   Reply With Quote
Old 12-22-2014, 05:26 PM   #21202
Trader Rating: 17 (100%+)
Any good setup for a 12-13 sec tight carpet track. Jumps are carpeted too.
joedeman1969 is offline   Reply With Quote
Old 12-23-2014, 07:33 AM   #21203
Rustynuts's Avatar
I'm the great THREAD KILLER
Sponsored Links
Tags
losi, tlr
Trains & Lanes On-Road season....Twenty Ten... Kitchen Racing Forum 1150 02-23-2011 06:01 PM
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 08:19 PM
SEO by vBSEO 3.5.0
