Old 09-08-2014, 02:28 AM   #21181
Errokk's Avatar
Originally Posted by gixx View Post
Hello,
I've been having some issue with the 22 steering and was wondering if anyone on this forum can provide some help. I have adjusted steering trim to ensure the the car is running at a straight line when no steering input is applied. I have also adjusted the end point so that at full left/right turn the steering diameters are the same size (left turn circle = right turn circle).
My issue is that when applying power during a right turn, the turn is significantly tighter (smaller in diameter) than when apply power during a left turn. I've been struggling to fine a solution to this problem for quite some time but to no avail.
Try raising your ride height in the front a little and maybe lowering the rear slightly. There are plenty of setup changes you can make to gain/reduce on/off power steering.
Less negative camber in the front
Softer front spring
Lighter shock oil
Lay the shocks further over to get more body roll
More droop
Lower roll center
The list goes on and on. I'd start with the most simple changes first (ride height).
Love racing! I just suck at driving!
Garage:
Ten SCTE, MBX6 Eco, Xb4
Errokk is offline   Reply With Quote
Old 09-08-2014, 02:47 AM   #21182
Blue 31's Avatar
Hello,
Have you checked your diff? Or the other rear drive components for binding of any kind?
If the steering and front end are all even the turn can be effected by the drive.
The problem is not the problem. Your attitude to the problem is the problem!
www.adelaiderc.com.au - Team Driver
sales@adelaiderc.com.au
ARCR Member
TLR 22 2.0, TLR 22 1.5, TLR 22T, Hobao Hyper 10SC.
Blue 31 is offline   Reply With Quote
Old 09-08-2014, 03:33 AM   #21183
dmatter's Avatar
Hello,
Usually a busted inner hub bearing or over tightened wheels. But, make sure all suspension components are free front and rear and make sure the exposed shock shafts are the same length left and right.
dmatter is offline   Reply With Quote
Old 09-08-2014, 06:04 AM   #21184
Shock length is different left to right if the car is not mechanically OK, or tweaked suspension.
www.rctech.net/forum/racing-forum/775876-crmpl-off-road-track.html
This is not the sig you are looking for.
30Tooth is offline   Reply With Quote
Old 09-08-2014, 06:52 AM   #21185
Softer front spring
Lighter shock oil
More droop
Lower roll center
Readjusted all the camber on all 4 wheels and that seemed to have solved the issue. I thought I have adjusted the camber on the car, but guess not. Thank you for all your help.
Cheers
gixx is offline   Reply With Quote
Old 09-08-2014, 06:57 AM   #21186
Default Stock Gearing
Hey guys whats the best gearing for a stock running a MM car with a Trinity Killshot has a 12.5 rotor..Not a real tight track...Thanks
Curtis May
TLR Racing|Team Losi|Xcelorin|NitroTane|NitroTec|Grandview Hobbies|A-Main Bodies|Fastraxx Hobbies|Fastlane Graphix|M2C Racing|Motor Saver Filters
CurtDawg is offline   Reply With Quote
Old 09-08-2014, 03:03 PM   #21187
Errokk's Avatar
Cheers
Glad I could be of assistance. I'm not a pro by any means lol! Cheers
Garage:
Sponsored Links
Tags
losi, tlr
Trains & Lanes On-Road season....Twenty Ten... Kitchen Racing Forum 1150 02-23-2011 05:01 PM
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 07:19 PM
SEO by vBSEO 3.5.0
