Old 11-15-2010, 02:29 PM   #1
Trader Rating: 25 (100%+)
Default Here is AE SC10 Mid Motor Conversion pic
I did all the work to make AE SC10 Mid motor conversion.
RustyRC is offline   Reply With Quote
Old 11-15-2010, 02:46 PM   #2
That look's pretty good, ...... what was all needed to purchase to make it a mid-motor? Do you have any pics along the way maybe a right-up. I would give that a try for sure.
Ultima SC / Tekin RS / Murfdog 13.5
SCRT10 / kinetic 2s / 6.5 HV
Tekno SC8e Project
Team Terribles
gottabaja is offline   Reply With Quote
Old 11-15-2010, 02:51 PM   #3
BuggyKing's Avatar
Trader Rating: 17 (100%+)
wow very nice. Let us know how it handles on the track.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 11-15-2010, 02:52 PM   #4
racer53's Avatar
sweeeeeeeeeet
"Whatever can go wrong, will go wrong"...Murphy's Law...Murphy was an optimist.
/ FT RC10B4 / FT RC10T4 / Driven just about everything else /
/ Mike's Hobby Shop...Carrolton Texas /
"All short course drivers aren't hackers,but all hackers are short course drivers"
racer53 is offline   Reply With Quote
Old 11-15-2010, 03:02 PM   #5
Default SC10 Mid motor pictures
I add two more pictures to see.
Old 11-15-2010, 03:03 PM   #6
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
That's awesome, Rusty! Looks great!
T-BirdJunkie is offline   Reply With Quote
Old 11-15-2010, 04:01 PM   #7
trx-1racer's Avatar
Did you just spin the rear clip to face forward instead of rearward? If so, the motor spins the srong direction for proper weight transfer. You need to add a counter gear between the pinion and spur to correct.
www.shortcoursehobbies.com
T-RCE Slash 4x4 - Kyosho SC-R - TLR 22
Think you're fast? Try racing in Arizona, it's like going to the Nats every weekend...
trx-1racer is offline   Reply With Quote
Old 11-15-2010, 04:17 PM   #8
Or reverse the motor's rotation.
Old 11-15-2010, 04:42 PM   #9
Default radio
I thought that spektrum dx2s radio have access the reverse function.
Old 11-15-2010, 05:05 PM   #10
trx-1racer's Avatar
Actually reversing the motor will make the vehicle travel the correct direction, but inertia will be going the wrong way for proper weight transfer under acceleration.
Thats why all of the mid motor conversion kits have 4 gear transmissions...
I'm not saying it wont work, just not as well. I'm not trying to put your work down, just letting you know what else might be needed.
Below is a pic of my LMX losi mid motor conversion and you can see the external counter gear to get the motor spinning the right way. The X-Factory kits and Schumacher Cougar SV use the 4th gear inside the transmission.
Old 11-15-2010, 05:05 PM   #11
greasemonkey74's Avatar
I think what TRX is getting at, is the physical centrifugal force of the motor spinning is reversed. Instead of that force applying weight, it may be reducing the applied weight. Hold a motor in your hand and give it power - it's going to want to twist one direction. You reverse the motor it's twisting in the opposite direction which may lead to a difference in traction. Granted the centrifugal force generated by the motor is nowhere near what is generated by the tires spinning, it may still have an effect. Yes, you can just switch two wires on the motor, or change your radio settings, but in essence, the forces on the chassis are still opposite from factory.
edit: what he said - beat me to it
no longer an rc racer
Matt H
greasemonkey74 is offline   Reply With Quote
Old 11-15-2010, 05:13 PM   #12
Next page for switched plate and motor.
Old 11-15-2010, 05:28 PM   #13
Next page
Old 11-15-2010, 08:12 PM   #14
Originally Posted by RustyRC View Post
SPX Super reverse esc work? with access the reverse function on spektrum radio dx2s?
It works. with LRP SPX Super Reverse #80400.
Old 11-15-2010, 08:17 PM   #15
D-Rek07's Avatar
What is the benefit of having a mid-motor car?
B4.1-MMP, 10.5 Ballistic
SC10 4x4-RX8, 4.5 Tekin
D-Rek07 is offline   Reply With Quote
