LIPO CUTOFF FAILED!!!
I guess my lipo cutoff was set and now when I go to balance/charge my lipo in says "low voltage" and won't let me go any further.
Anyone have a trick to bring it back to life or do I have a really cool paperweight?? Thanks in advance.
Just regular charge it rather than balance charge
If all cells are under 3V, then charge it's on Nimh mode until the cells are above 3.0V. Then switch to lipo mode.
thats nuts, I never heard of any lipos being brought back to life. I know that the old nimhs could be, and have dont it a few times, but never did lipos thanks for the tip.
If you do as the others suggest, do it close to a door where you can huck the pack outside after it catches fire.
If you try charging it do it at the lowest possible settting for nimh on your charger and keep an eye on it. Once you are up to six volts switch to lipo and balance charge it watching the whole time.
As said. Charge at .5 amps on nimh setting let it go for awhile till vole goes up then switch over to balance charge. It will take a LONG time to balance out but should be fine. Fair warning though. While doing this can bring back to life a dead lipo, you WILL be shortening it's effective life. But better than garbage.
Figure 1.3V difference between each cell. You might have 10 milli-Ohms of resistance. That'd give you 130amps of current.
I wouldn't recommend dong this unless you have resistors in between the batteries. You can get a 1 ohm 5W from Radio Shack. Put it in between the two positive leads. Without it you could have some serious current running between the batteries.
It's just a y-harness without the plug for the esc.
http://www.rcottawa.com/index.php?topic=4011.0
everything you need to know about reviving lipo's, many locals have used this as a guidline with sucess.
damn
damn, if only i knew this before. i accidently drain my lipo and had the same problem. i chuck them out.! as it would not charge on lipo. what i did was to charge for a few minutes before balancing them, man did it expand!!
If it's only 1 cell that's under 3.0V you can find it on the balanceplug with a multimeter and charge it until it's the same as others.
Btw, put your LVC a bit higher now ;-)
