Old 11-10-2010, 03:08 AM   #1
djtroy's Avatar
Default HELP ME with xp sc450-bl b4.1 rtr esc
I bought a RTR b4.1. I am totally lost with this thing and all the beeps and chims. I read the manual but I am totally stumped on how to get the right settings on my ESC. I was playing with it now I dont have reverse. I want it set to max power and lipo with reverse. Its now set to no reverse and its very glitchy and slow.
xp sc450-bl
______________________________________________________________________
Hotbodies VE8 - MMP / Tekin 1900KV
Team Associated Factory Team SC10 - Orion Vortex 10.5 / MMP
Team Associated SC8E RTR (Mamba Max 2200kv Combo)
Spektrum DX3R / 3x3100 Rec 2.4ghz
djtroy is offline   Reply With Quote
Old 11-10-2010, 08:34 AM   #2
Turn on transmitter, hold throttle to full, turn on car. You'll hear 6 beeps. Throttle to neutral, 4 beeps, throttle to reverse, 4 beeps. Wait 5-10 seconds and the series of setups will start. First 1beep -1beep, then 1beep-2beep, then 2-1, then 2-2, and so on. When you hear the one that you want pull and release the trigger. You'll hear 4 beeps (I think) and that setting will be programmed in.
Sound's like you want
1-2 for lipo
2-1 for 0 drag brake
3-4 for max throttle profile
4-2 for 1 second reverse delay.
Turn off car and then transmitter and you should be set to go.
Hope this helps
Vic
PM also sent
Big Vic is offline   Reply With Quote
Old 11-10-2010, 09:58 AM   #3
Neu_Racer's Avatar
Trader Rating: 211 (100%+)
They can be tough to learn on but once you get the hang of it programming is easy. Don't give up and ask the LHS for help. I know how to do it and even seeing the type above was almost confusing (just woke up though. )
The delay in beeps between menus is longer than the delay of settings within a given menu.
Neu_Racer is offline   Reply With Quote
