Help needed - rc10t3 diff issues
So I received a t3 roller just last week that's been giving me some diff issues. The diff bolt seems to keep backing itself out regardless of how tight I make it even after I disassembled the diff, and cleaned/re-lubed everything. Upon tearing the diff down again to install an AE diff rebuild kit I realized that the original 6 ball bearings for the diff bolt That sit on the "passengers side" outdrive won't budge at all let alone fall out. This is probably the problem I'm having.
With the long intro complete, has anyone had this problem and if so can you give me some advice on how to get those out. The "jam a tiny screwdriver in there" idea hasn't been successful.
Thanks everyone!
Thanks everyone!
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Are you talking about the thrust bearings?
They're the ones on this instruction sheet that sit around the diff screw.
http://www.hpiracing.com/graphics/instr/a508.jpg
Honestly, a diff outdrive isn't all that expensive, and should be in stock at your LHS since the T2, GT, T3, and T4, B3 and B4 all use the same outdrives. It'd be a hell of a lot easier than trying to chisel that sucker out, and potentially damaging the outdrive anyway.
Is the diff apart and the outdrive its own entity now? If so go in on the "inside" of the outdrive that faces toward the gear/bearing and try tapping it out that way with a small allen wrench.
Thrust bearings, yup that's them.
Kinda tough to get a hold if them the otherway. Well I guess before I spend 7 dollars to ship a 2 dollar part I'll try as much as I can from home, heh.
Do you think soaking it in gasoline or similar liquid would hurt anything? I might be able to loosen some old grit and grim stuck in there that way.
Hey, can't hurt, right? Give it a shot.
Do you have a local hobby shop? If so, give 'em a call and ask if they've got the outdrive.
Just a quick note the B3,T3 out drives are diffrent than a B4 or T4 and you need a dealer that sells thunder tiger parts. because i don't think associated has the part number in stock but thunder tiger dose.
Did the gasoline/wd40 soak and had it again. One hit and they were out! Thanks again folks for the advice
Strange...isn't the diff gear and the diff rings all the same parts though?
Do you know the actual differences in the diffs? Just curious. Good to file that info in the back o' the brain for future references.
B2 is the only one that was 2.40:1 if ThunderbirdJunkie recalls correctly.
At least right here the pile of B2 diff gear packages say "fits b2 tranny ONLY"
Also, I believe Custom Works brand outdrives would work as they are identical to B2/B3/T3 ones. If the OP knows a hobby shop that can get custom works parts he could go that route as well.
Thanks guys, looks like ya learn somethin new every day
B2 b3 and t3 have the same diff gear, i know lol i just replaced mine not too long ago. I have a ton of them, most of my diff gears just say b2 on them, but there are a handful that are marked b2/b3/t3.
