Do they sell an adaptor for this? (pics inside)
Basically my Battery connections is the first picture, and I want an adaptor to make it fit to the connection in the second picture.. .
If you can just switch them to deans. I don't think they make a adapter for that connection.
no you have to switch buy some deans will improve the current going to the battery to the speedo
The white conn is a tamiya male and they've been known to melt with just moderate current. I had one melt on a 18th scale and got lucky that the pos and neg didn't touch. Otherwise it would have cost me the electronics.
You're better off replacing them with something better.
Make your own adapter, but should get rid of those tamiya's, they are junk.
Yup The plugs you want are either a Deans (Most Commonly used after market plug), Traxxas, or EC3. I have been using the EC3 more and more and am really starting to like them. And very easy to solder. The Traxxas end is the highest rated, but I hate soldering them because if you even get the littlest amount of solder past the solder area. You can't push the pin into the connector. Also they are very tight and sometimes hard to plug and unplug. The Deans are very easy to solder and easy to use. If you are just learning to solder some people melt the end and the pins get moved out of place. When soldering them I recommend connecting the male and female together then soldering them. That way the pins don't get moved out of place. Here is a picture of what I am talking about.
Super Moderator
Trader Rating: 31 (100%+)
I don't mean to be rude but how many threads are you going to start trying to get this one truck running! All this and you own a BAJA?????
