Old 10-16-2010, 02:11 PM   #1
Trader Rating: 17 (100%+)
Default Strange Truggy Problem
When ever I get on the throttle while turning left, it will straighten out and not turn, even with my radio at full lock left. Off power it seems to turn normal. Has anyone had an issue like this? It worked fine yesterday, then I put in a front smart diff and a different servo, but that servo was too much and made the whole truck stutter on and off. So I put the original servo in and now this. Any ideas? I tried 2 different batteries and made sure connections were tight.
Trialser is offline   Reply With Quote
Old 10-16-2010, 02:54 PM   #2
I just tried a different receiver, same thing. Then I tried recalibrating, now it does the same thing in both directions and everytime i blip the throttle the steering will go either way. Also, when I turn it on, with each beep the esc makes, the servo will go back and forth. Forgot to mention, I am running a MMM combo with Hitec servo. I cant think of anything else to try, and help would be greatly appreciated.
Old 10-16-2010, 03:05 PM   #3
mister-e-meat's Avatar
sounds like your servo saver try tightening it a little thread lock should hold it in place.
its easier to make excuses than laps...
mister-e-meat is offline   Reply With Quote
Old 10-16-2010, 03:11 PM   #4
I took the servo horn off and could still see the servo moving. It's like the trottle trigger is telling it to go and turn at the same time.
Old 10-16-2010, 07:50 PM   #5
Would a glitch bister solve this?
Hot Bodies D8 Truggy Greg B Nitro Off-Road 10028 08-16-2017 05:44 PM
Truggy bodies? DOMIT Nitro Off-Road 49 01-20-2010 06:17 PM
Help my throttle servo hums when i turn on the truggy GASMAN123 Nitro Off-Road 18 09-27-2009 11:31 PM
