+New+ Losi 8ight-e Problem Help please
Ok I am going nuts over here and need some help. I got a new 8ight-e about a month ago and have not been able to use it as I was waiting for parts (batteries, transmitter etc). Well I finally got everything I needed yesterday so I got everything setup I calibrated the ESC etc.
Here is the Issue: The motor does not seem to be working when I pull throttle the lights work on the ESC green solid for the gas and solid red for the brake and solid blue when on but the motor does not turn or try to turn. servo works fine for steering so it should be binded correctly. this is the setup: 8ight-e W/ Xcelorin ESC and 1700kv KO Propo Eurus and Receiver Jr Z9100 HVS Hyperion 4s 5000mah THe only other thing I was thinking of doing is buying a Tekin combo today and then send off the Xcelorin stuff to be repaired or replaced because I am sure the turnaround for repairs probably takes a little bit of time. Any suggestions would be GREATLY appreciated as it seems it may be just something I am doing wrong. Thanks for your time Dan |
try reprogramming everything again...and just double check that all the connections are correct and in all the way...sensor wires and what not
