Old 10-14-2010, 07:47 PM   #1
Trader Rating: 40 (100%+)
Default what is the optimal speed for a truggy
good day everyone!
i have a ofna hyper st pro that is currently in the process of being converted to brushless.
the components i used are as follows:
hobbywing 2000kv motor
hobbywing xerun 150a esc
turnigy 4s1p 5000mah
hobbypro hyper 8 conversion (this needs a bit of modification to use it in the truck)
i wanted to know the optimal speed for a racing truggy since i want to buy the appropriate pinion for it.
thanx
URL: http://rccebu.blogspot.com/
RCebu is offline   Reply With Quote
Old 10-14-2010, 07:54 PM   #2
T. Herwig's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to T. Herwig
Hey there...not sure if this will help, but I ran my RC8BE at a fairly large track the past weekend, and it has a long straight away. With the gearing I had, I was running at about 44 mph (According to gearing calculator), and was slightly slower on the straight away than some of the faster guys. However, on the track as a whole, it did well. (This was in a buggy) I'd say anywhere in the 45-50mph range would be a good "speed" to gear for. Just make sure you take temperatures into account also!
Tyler Herwig
Tekno RC teknorc.com ∙ JConcepts jconcepts.net ∙ Spider Hobbies spiderhobbies.com ∙ SMC smc-racing.net ∙ Upgrade RC upgrade-rc.com ∙ Kustom RC Graphics kustomrcgraphics.com
T. Herwig is offline   Reply With Quote
Old 10-15-2010, 08:14 AM   #3
Default thanx
thanx Tyler350 for the swift reply
according to the speed calculator, i should be looking at a fairly large pinion 18 or 19 to get to that sweet spot. thanx again
Old 10-15-2010, 08:44 AM   #4
Trader Rating: 19 (100%+)
You don't need to gear much more than 35 mph for most tracks. 99% of tracks won't have a straight away long enough to get up to 45 mph.
You basically want to be able to grab full throttle and hold it for maybe 1 second on the longest straight.
I will guarantee that if you are geared for 45mph you will never see full throttle. At most gear for 38-40mph. Even then you are still probably never going to get to full throttle unless you have a 200 foot straightaway.
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 10-15-2010, 09:07 AM   #5
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
+1 too everything Russ said here .
Another benefit of gearing a little slower is there will be less heat build up and the battery will last a little longer .
Have you been ripped off by Brushless Hobbies ? If so go to BBB.org and file a complaint !
BashemSmashem is offline   Reply With Quote
Old 10-15-2010, 12:59 PM   #6
Default thanx
i feel better if there is a larger margin of safety
i also like the sound of using 16t (39.16mph) compared to using a larger pinion coz i reccon that the larger pinion will create another problem since there is only a small clearance left even when im only installing a 12t pinion right now.
thanx for everyone who responded!
i appreciate all the help guys and if you have additional suggestion, im still open to them
The New Werks B6 .21 Buggy Racing Engine! Werks Offroad Nitro Engine Forum 4335 08-25-2017 09:03 AM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
XRAY XT8 2009 Spec 1/8 Luxury Racing Truggy Kit davepull R/C Items: For Sale/Trade 36 05-16-2010 02:29 PM
E truggy ESC/Battery/Motor Recommendations Frank L Electric Off-Road 43 04-29-2010 12:42 PM
