Old 10-15-2010, 06:41 PM   #16
KniteWulfe's Avatar
Originally Posted by Anthony.L View Post
Cody, buy quality batteries and you can expect quality results.
I've owned Turnigy packs but always had the mentality they are "disposable". You get what you pay for!
+1 I have some that have lasted me forever but my last few packs have been losing an unacceptable amount of punch halfway through the pack after only about 10 cycles.
--Team JBRC-- My Cars: Mini Revo VXL, SCX10, RS4 Rally, TC3 FT, Losi Micro High Roller, Venom Creeper, MP9e, MBX5R-E, SC8E, JQ THE car, and TC3 100% Ti/ Alum Shelf Queen
Helis: SP II, 4G6S- HP-07, HM1#A, HK450GT
http://www.youtube.com/KniteWulfe
KniteWulfe is offline   Reply With Quote
Old 10-15-2010, 08:07 PM   #17
Try to charge them as Nimh for a few min. I had a battery that would not take a charge and said it was charged kinda what you have going on, my buddy threw it on his charger as a nimh and it has worked great since.
Lendel Smith
SikKustomz is offline   Reply With Quote
Old 10-15-2010, 08:30 PM   #18
KniteWulfe's Avatar
Cody, have you actually tested the voltage of each of the cells?
Old 10-15-2010, 09:32 PM   #19
Trader Rating: 37 (100%+)
I'm not sure how to do that. I have an Onyx 230 and a blinky balancer. I don't think I'm hi-tech enough for all that. I switched the ESC over to NImh mode and they still shut down after like 5 seconds. Not like low voltage cutoff though. It shuts the ESC completely off. I guess I will play around with them on the charger outside and see what happens. For along time one of them wouldn't even balance according to the blinky but has been lately.
Cody01 is offline   Reply With Quote
Old 10-16-2010, 02:14 AM   #20
KniteWulfe's Avatar
Yo really need to test the cells from the balance plug to diagnose this. You could have a bad connection too causing this. Re-solder or at least check the battery plug from the esc.
Old 10-16-2010, 06:22 AM   #21
I checked that plus both packs developed this problem at exactly the same time.
Old 10-16-2010, 08:07 AM   #22
thaghost's Avatar
im not sure about where you live but here in idaho everything is very wet and covered with dew in the mornings. any chance that they sat there wet all night?
HB D8
Tekno v3 conv.
Powered by Tekin
sposored by overtime............lots and lots of overtime
thaghost is offline   Reply With Quote
Old 10-16-2010, 11:53 AM   #23
Yes it gets dewy here too. Didn't consider that. Alittle dampness would smoke them huh? I''m just used to Nimh, you treat them any way ou want and they keep working.
Old 10-16-2010, 04:20 PM   #24
Trader Rating: 67 (100%+)
As posted before you need to get a volt meter and check the voltage of each cell in each batt. If that isn't possible try this. Set your charger to NIMH or NICAD, set charge rate very low (half amp or less) start the charger, if the pack starts to charge allow it to come up slightly, watch for heat, if no heating occurs, cancel the charge, and then try a Lipo charge.
If they still don't charge then I would say they are done.
I did this last week because I left one plugged in for several days (brain fade). The process brought it back and it is now balance and charges normally.
Also to clarify, water is a Lipos enemy.
nutz4rcyktw is offline   Reply With Quote
Old 10-16-2010, 05:15 PM   #25
OK, doing that now. Voltage is showing high like peaked range but mah shows low low.
Old 10-16-2010, 07:07 PM   #26
Lipos are not waterproof like nimh are. The shrinkwrap or hardcase would protect the cells from any light splashing, but dew or condensation would get into every nook and cranny.
Stregone is offline   Reply With Quote
