weller solder station
#16
60 watt will get up to 900 quicker and hold the heat even when soldering
a big thick object. A big thick object will suck the heat right out of a 40
watt station. In the wind out door at the track the 40 watt won't solder
anything a 60 watt will be better & 80 watt kicks butt in the wind.
I hope I'm posting clear enough about this. Typing sucks to explain things
LOL"
Enjoy your R/C racing...
#17
I like having an adjustable solder station so I can solder smaller wires without worrying about damaging the insulation etc. Thats why the wall plug in kind is no good IMHO.
But too answer your question, the 60 watter can handle a larger heat sink.
#18
IMHO 900 degrees is too hot. I used to use a 650-700F tip all the time (on a temperature controlled station). 60/40 solder melts at around 400F.
You need a higher wattage iron because it will recover its temperature quicker than a lower wattage model. When you are heating up a large wire or battery the tip's temperature will drop. A heavier iron will recover faster and you won't have to heat soak the parts for as long.
#19
thanks for the replies. it makes sense now. I'll spend the extra $20 and order either the Hakko 936 or TC 950.
I also need some solder and flux and i should be set.
#20
#21
#22
#23
I think the Team Checkpoint comes with two. You should be okay.
#24
A 60watt iron with a medium tip is what you need. It holds enough heat to do the job.
#25
$500 for a weller? No thanks.. maybe if it was my profession.
I use this one: http://www.radioshack.com/product/in...odsInSession=1
Look for them on sale for $65.
#26
Weller WES50
I have an older 50 watt Weller WES50 that has yet to let me down. Tho it has struggled with some of the larger gauged wire that is more common now as opposed to when I got it. They make a good station if you have access to tips. I'd reccommend one of their digital ESD safe models if possible.
#27
Don't forget to pickup a range of tip sizes...soldering with the wrong sized tip is like using the wrong screwdriver. $5-7 bucks for Hakko tips I beleive.
Hakko has some pretty good basic info about soldering/tip care in their rc area:http://www.hakkorc.com/rc_936_d.htm
#28
#29
Dont know what Duster is talking about , the tip is plenty big for doing RC type soldering and all of my joints come out very nice .
Bottom line is I personally wouldnt get anything less than 80 watts or better as the higher power irons/guns are easier too solder with and you dont have too heat up the parts as much to get a soild joint and they have no problem soldering larger wire either.
#30
Always use distilled water on your solder sponge to clean your tip while
soldering. If you can't then at least use bottled drinking water. Tap water
will kill a soldering tip real quick. I've been using the same tip for 20 years
because I use distilled water or bottled water evey time I solder..
PS: I use my soldering station almost every day...
Enjoy your soldering, good luck & have fun with your R/C racing..
