Novak Kinetic Competition
#16
The Tekin has the smallest footprint out there. I run the Kinetic and it has been fantastic. It has more features than the Tekin and the Castle ESCs. Critical features to me are Current limiting, Dynamic Timing, and Throttle curves. The Novalink is easy to use and has hints built in. The Novak Kinetic is lighter too.
Novak or Nothing!
Novak or Nothing!
If novak could have the technology to make the Kinetic the same size as Tekin I`d have one to try . Until then Tekin all the way !
#17
Tekin doesn't have throttle and brake curves. It clearly has dynamic timing and current limiting which are the two most important features. I personally like changing the throttle curve in the ESC and not just relying on the EXPO feature in the radio.
#18
This is my first real ESC and I'm using a 13.5 Ballistic, I put it in my T4 running mod class. First thing I noticed was that it felt really smooth. At the track I didn't do any adjustments on the ESC untill the second qual then I started to use the cool functions like the timing. This thing really came alive! I really like how I can adjust when the timing system to where it kicks in!
#19
Yeah this thing is as good as tekin now.
#20
*Looks at Hotwire* It actually does have throttle curves and such, not so sure on the brake curve, but I can dial that into my radio
#22
I love Novak stuff but have seen a high rate of failures from the Novak Kinetic units that the local track sells at its store. I have a box full of GTBs and although they work flawlessly, a Speed Passion or Tekin with advance and boost will make a much slower motor as fast. A for example, a Tekin RS with a 13.5 can easily outperform a GTB with any 10.5. In fact I run a fancy ESC with a 17.5 motor in a class that allows for a 10.5 and have no trouble keeping up. I'm a little soft on punch but have all the speed that I can use. Its weird. The new technology works through the sensors so somehow less is more. I have 3 of the Speed Passion ESCs and have never had a a Tekin equiped car/truck rocket away from me...only better drivers have been able to pull away. Speed/power is never an issue. That being said, I just bought a Tekin RS to try it out so I will let everyone know eventually.
Anyway from personal experience I would steer away from the Novak Kinetic until they improve its reliability some more. The concensus is to buy a Tekin....I can also recommend the Speed Passion stuff too.
#23
Just make sure whatever you buy is legal in whatever class you're running. Tekin, with all it's software updates, is having trouble being/staying legal in ROAR "Sportsman" class.
May not matter in the backyard or at the club level, especially if you're racing wallets/checkbooks, but at organized events.....it matters.
#24
hi again
it looks like i will keep the gtb for a back up i found a deal on tekin rs pro so i pick it up.... i sent my mamba max pro for the sensor plug again and if the overtime picks up i will get novak kinetic, i have alway good luck with novak
i have seen havok 3s problem from alot of people alast year. so this is why i asked the question
#25
Company Representative
#28
Assuming that escs burn up because the controller, itself, is defective is misleading because esc problems are just as likely caused by defective batteries, servos, soldering or bad connectors. Just about everything that can go awry in your electronic set-up will show up as a controller problem.
#29
well if you get 2 kinetic from madison wi. let me know what happen i know they been racing for 8 year with gtb
we all know that novak stand behind there work at novak
i had a havco pro last year and had problem with it i sent in to fix them sold it ebay to get another gtb
i`m not here to bash i just want some to put with little problem i just suck when stuff die and have send it in and miss racing for three weeks for the turn around
#30
We understand how frustrating down time is for racers! This is why we maintain a fast turn-around time for customer service. These new-gen escs (from all mfgs) introduce timing complexities that can create many additional issues unknown with our GTBs.
I think that unless a racer really has the patience and comprehension to study and understand all of the potential of DTA controllers, he should stick with a GTB. Unless these timing escs are adjusted and used correctly advanced timing can ruin motors and create costly damage.
