Ball Diffs - how long do yours last?
#46
R/C Tech Elite Member
http://www.bfastrc.com/prolube.html
#50
#52
AE Is Killer Of All......
I use this and get 6MOnths free wear and tear before it even starts to get gritty.. And I Always sand out my rings and polish them , HinT HINT Green slime is also some great stuff ...Amazing Lube !
#53
I've got about a good year on the same B-fast Pro ball diff kit in my Ultima SC, and it look's like new. I however did not use the grease from B-fast. I used a mechanical grease. Extreme pressure "Sta-Plex" Premium Red Grease
it has a 500 deg drop point, which for us is a good thing. It means that the grease will stay where you want it. I first used it in my Baja diff, and never looked back. It is now in all my drive cup's , diff's anywhere it need's some lube!!!!!
#54
I ran B-Fast diff balls and rings for a whole year in both of my Kyosho RB5-SP and RT5. I used the B-Fast Pro diff lube and diff Pro grease in my diffs.
I would every two to three months. take the diffs apart. Clean and relube diff balls and clean and put new grease in thresh bearing.
Put the diff back in and break in your diff like they where brand new.
Your good to go
Your good to go
#57
What is that mystery lube in the picture It's mighty small on my side
#59
1/2 oz tube Super LubeŽ Synthetic Grease
