XXX-T CR set-ups
#16
If no weight is specified on the sheet, don't add any. None should be needed. Casper's setup is a little heavily damped (he likes it that way), if you feel that it's too heavy then drop oil weights. You can go as low as 27.5f/30r ind it'll still work really well.
#17
I will try plaing with the oils a bit. A heavily damped car would be more responsive than a lightly damped one which would be more forgiving, correct?
#18
It depends on traction. It can go both ways.
