Like Tree4Likes
Old 12-29-2010, 10:54 AM   #1381
Originally Posted by S/X Runner View Post
For street use, just leave the grease in there. It will work like a champ.
I have changed all greases to 7k front and center and 3k rear oils.(it seems good)But why you use 2k?(it seems too low)
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 12-29-2010, 11:10 AM   #1382
S/X Runner's Avatar
Trader Rating: 37 (100%+)
For the street, hat us perfectly fine. As soon as you put it on a track you will not have any steering. 7 in the front won't let the diff unload.
S/X Runner is offline   Reply With Quote
Old 12-29-2010, 11:23 AM   #1383
jeffrobmx's Avatar
here she is guys ready for battle
body was painted buy mel you can shoot him a pm on here he does outstanding work
AGAMA, HYPER 9E, 10TT :-)
jeffrobmx is offline   Reply With Quote
Old 12-29-2010, 11:53 AM   #1384
I run on a track (asphalt)
Phoenix ST
Old 12-29-2010, 12:23 PM   #1385
tedstryker's Avatar
Trader Rating: 75 (100%+)
Originally Posted by -R2- View Post
Moving the battery tray foward will help the push that you guys are getting in the car, I did this after a few runs and gives the car the steering you need and also takes away from the bucking that happens when the chassis slaps the edge of the jump, I have also put on the Hyper Sc blue springs and cut one round off the front springs so that I can use the preload to my liking this will improve the corner speed and less chassis pancake.
SORRY for the dumb question when you say battery tray....do you mean just the battery?......or moving the whole tray...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 12-29-2010, 01:32 PM   #1386
-R2-'s Avatar
Battery tray.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 12-29-2010, 01:36 PM   #1387
jeffrobmx's Avatar
Battery tray.
i have all my weight moved forward hope this works reciver is in front of batt tray... esc is ontop of servo
batt is up as far as possible
have 2 hole shock pistons front
3 hole pistons rear both 35 wt oil hope this set up iss good
Old 12-29-2010, 02:12 PM   #1388
-R2-'s Avatar
Old 12-29-2010, 03:10 PM   #1389
Trader Rating: 36 (100%+)
My TT is set up as in the pic above.
R2, could you please post a link or part # for whatever it is you guys are using to shim the diffs??? Thank You
NitroOB4You is offline   Reply With Quote
Old 12-29-2010, 04:25 PM   #1390
-R2-'s Avatar
HMMM?? Shim the diffs, I'm not sure what you are asking, because I don't use any shims other than the shims that came with the diffs.
Old 12-29-2010, 04:38 PM   #1391
Side to side in the case to help crown to pinion mesh. My F and R are both super crunchy. I've tried finding 10x15mm shims, but no luck anywhere.
Old 12-29-2010, 04:56 PM   #1392
tedstryker's Avatar
Battery tray.
what did you use to hold the tray..or did you drill new holes..
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 12-29-2010, 05:35 PM   #1393
HYPERBOY's Avatar
All you need to do is trim the side of the tray, You don't cut through the bottom so no need for new holes
James Grossaint
HYPERBOY is offline   Reply With Quote
Old 12-30-2010, 05:11 AM   #1394
TAT76's Avatar
Hey guys, I've been reading threw the pages and the TT seems to be a pretty good truck. I'm looking for a new rig to play around with. I dont race but do go to the local small track to run or my backyard track. Also some little bashing at gravel pits, camp sites when camping in the summer. How do you think the TT will handle it?
For a power plant I'm thinking an ezrun system since I dont need huge speeds and I've had good luck with them. Anyone have any input on them in the TT?
Hows the aftermarket support? Any word on bodies?
Thanks guys for any help.
Using my RC's to stay alive during these hard times...
TAT76 is offline   Reply With Quote
Old 12-30-2010, 05:35 AM   #1395
I think you will need something more than an ezrun to power this thing (and have a cool motor)It handles great everywhere.
Phoenix ST
