Like Tree4Likes
Old 12-10-2010, 07:31 PM   #1141
ebasher219's Avatar
Originally Posted by sheldon637 View Post
Someone needs to do an E conversion for the Losi ten-t. id like to see how the 2 trucks match up.
LOSI TEN-T e
TLR SCTE-BCE Chassis-Tekin Pro4 4000kv-Savox 1258tg-Proline F150 Flo-Tek
Mugen ECO-BCE +3-Tekin 1900kv-Savox 1256tg-Proline 2012 Bulldog
TLR 22-JConcepts Punisher
ebasher219 is offline   Reply With Quote
Old 12-10-2010, 11:47 PM   #1142
julius_makewar's Avatar
Okay fellas, some feedback for you. I have had my 10TT a few weeks now and after some initial testing I guessed at a setup for racing. To stop nose diving I moved the rear lower suspension arms spacers to the front. both front and rear suspension arm spacers. This moved more weight to the back of the truck. I neglected to move the upper arm spacers therefore increasing castor (I will change this). I used Losi 40wt oil in the front and 30wt in the rear Ride height was set slightly higher in the front and slightly more droop in the front. motor was a 4300kv using 14t pinion. I also used the polycarb wing bolted onto the white plastic wing to get a much better wing profile-more downforce.
So, at the track there are a couple of us which get 11 laps regularly in 6mins with 8th nitro buggies. Most 10th scale cars(all classes) get 9 and sometimes 10 laps. This little beasty was 10 seconds off of getting 11 laps. 10 laps in 6mins 10secs. Too say I was impressed is an understatement. More tweaking to come.
Cheers All
Model Motorsports International-Mugen Seiki, Contact Tyres,
Neo+ (SA's own high performance fuel).
Ryper Hobbies-AKA
RCHobbyzone-LRP, Sanwa, Scott's RC Designz
Shadow Racing - RC
julius_makewar is offline   Reply With Quote
Old 12-11-2010, 07:11 AM   #1143
Send a message via MSN to xrider
Anyone know which DE Racing skid plates will fit the 10TT?
xrider is offline   Reply With Quote
Old 12-11-2010, 07:34 AM   #1144
jrz93's Avatar
yes the one for hyper sc
the ofna crt.5 is the best wing for performance tested so far
conversion kit for ten-t (plus mike is a great guy!)
http://www.rc-monster.com/proddetail.php?prod=rcm10tkit
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 12-11-2010, 07:57 AM   #1145
Originally Posted by JayRC66 View Post
I wanna put my 1/8 buggy wheels on the truck. What adapers did you use? Part number, maker? Please
The adapters are the AKAs for the 4wd slash. People have issues with the wheel nuts coming loose, but I haven't ran into this problem yet. Use loctite! Also, there needs to be a little shimming with the aka adapters to eliminate some slop in the front hubs. You can use the wider spacers that come with the adapters, but you need to grind the spacers down slightly to get the hex pin to go through. It's a very easy thing to do.
I am surprised not more people are putting buggy tires on these yet.
Hope this helps.
Into scalers now.
tedovt is offline   Reply With Quote
Old 12-11-2010, 05:08 PM   #1146
1Fastpede's Avatar
Trader Rating: 48 (100%+)
Who has these in stock?
1Fastpede is offline   Reply With Quote
Old 12-11-2010, 05:17 PM   #1147
love the look of this truggy and the weight. Does the drivetrain support the use of a t8 1400kv on 6s?
Looking for a rocket ship...with wheels
airboy808 is offline   Reply With Quote
Old 12-11-2010, 05:43 PM   #1148
I would say this Truggy is more suited for 540 motors and 2 cell.
Whosold is offline   Reply With Quote
Old 12-11-2010, 05:45 PM   #1149
racer x 1's Avatar
Trader Rating: 27 (100%+)
all thats needed is 6.5 540 can and a little tekin love on the esc. most of the local guys at my track all run something different butt a few are on tekins and they are not lacking in the hp department at all!
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 12-11-2010, 05:51 PM   #1150
I concur on the 540 6.5, i will reinstall that combo, just loved how it ripped. May use a 5.5 or a delta wind for plain wot runs if this pleases u more. With the castle sct my face falls asleep, today i watched 2 ae t4s overtake me on the straight while running a 16t pinion.....
hoousi is offline   Reply With Quote
Old 12-11-2010, 07:11 PM   #1151
Is the metal spur for the Hyper 10SC a direct replacement and the same size as the stock plastic Hyper 10TT? If not, is there a metal spur for the 10TT that is the same size as stock? Got a part number? I like knowing that nothing is going to happen to my spur gear ever and want to get a metal one for this thing. Plus I love the sound!
Rc is meant to be fun. It's not formula 1 here folks.
Fleshgearf150 is offline   Reply With Quote
Old 12-11-2010, 07:59 PM   #1152
JayRC66's Avatar
Hope this helps.
Not many peeps now about the adapters in my area. But they will now. Thanks for the info.
Jovanny S.
Losi, Serpent, Schumacher, Ofna.... yea I got a little bit everything.
JayRC66 is offline   Reply With Quote
Old 12-11-2010, 08:01 PM   #1153
JayRC66's Avatar
http://www3.towerhobbies.com/cgi-bin...&I=LXYAG8&P=ML
Jovanny S.
Old 12-11-2010, 08:50 PM   #1154
1Fastpede's Avatar
Sorry i meant the Car itself!
Old 12-11-2010, 09:37 PM   #1155
Slash65's Avatar
http://thebarnfloor.com/catalog/prod...oducts_id=2106
HoBao Hyper 10 TT
Sanwa MX-V
HobbyWing XeRun V2.1
Dynamite 6.5T
Slash65 is offline   Reply With Quote
