Like Tree4Likes
Old 12-06-2010, 08:15 PM   #1081
Originally Posted by G33Kster View Post
I was actually referring to two hardcase 5000mAh stick packs for some crazy 4S setup, but I'll keep that in mind as well. I can make a custom LiPo tray if I need to. Do you mind taking the dimensions for me?
That's going to be quite a lop sided setup. I'd suggest getting a cheap 2500mAh 4s pack unless you don't mind grinding the left side of your chassis to shreds
Starscreem is offline   Reply With Quote
Old 12-06-2010, 08:55 PM   #1082
G33Kster's Avatar
I'll have a 4074 motor on the other side to offset the weight
EDIT: I just checked, and assuming the roller is perfectly balanced left to right, the battery side will actually be about 80g lighter than the Motor/ESC/servo side.
"You haven't done a big enough jump 'till you've broke it!"
RC18T2 Team Kit /// Jammin X2 CRT Brushless /// Firestorm BL Conversion /// GTP Nissan E-conversion
FlySky GT-3 2.4GHz
G33Kster is offline   Reply With Quote
Old 12-06-2010, 09:46 PM   #1083
Originally Posted by offplane View Post
as a side note i cut the tray so i could lay my 5000 pack flat. you could do the same and stilll have 1/3 of the second battery on the tray?
With the tray cut like that to lay the pack flat does the body still fit properly??
Rc is meant to be fun. It's not formula 1 here folks.
Fleshgearf150 is offline   Reply With Quote
Old 12-06-2010, 10:41 PM   #1084
justbeastit's Avatar
Originally Posted by carcrazy699 View Post
2 2s lipos wont fit in the case. i tryed doing that and you would have to cut one side of the tray off for them to fit
I actually run 2 4000mAh 40c turnigy batteries from hobbyking in parallel (8000mAh 2s pack) to run long practice sessions with my hyper 10sc. Since the battery box is exactly the same as on the TT you could use a series connector to make a 4000mAh 4s pack that will stand up and still fit under the body of the TT. I don't know if I can post pics yet but if you want me to I'll try.
justbeastit is offline   Reply With Quote
Old 12-06-2010, 11:35 PM   #1085
Wow, nothing like an 8th scale motor in a TT
You may want to eventually beef up the shocks too then. I hear TMAXX/EMAXX shocks work well on the 10sc so they should work good for the TT as well.
Old 12-07-2010, 06:19 AM   #1086
Just got in my new body that i have been waiting forever for. Got out the trusty airbrush last night and went to town. Now all my cars match.
Hyper 10SC
Team Terribles, Mike's Hobby Shop Carrolton Tx.
Up and coming factory team driver
slowslug is offline   Reply With Quote
Old 12-07-2010, 08:56 AM   #1087
Trader Rating: 478 (100%+)
I tried to cut the battery tray to lay the battery flat like in my Hyper10 and I don't like it. A part of the battery is exposed and hangs over the side of the chassis. I have another stock tray that I'm going to put in. So, if you are thinking of doing the same thing I'm giving that idea a thumbs down.
QDRHRSE is offline   Reply With Quote
Old 12-07-2010, 10:59 AM   #1088
Trader Rating: 36 (100%+)
I cut mine as well, and hacked the chassis to move the tray fwd. I was a bit bored LOL.It does overhang the chassis a bit, but I am running hard case LiPo, so I'm not too worried. I'll take some pics in a bit for referrence.
NitroOB4You is offline   Reply With Quote
Old 12-07-2010, 11:32 AM   #1089
Default Pics
Old 12-07-2010, 05:33 PM   #1090
ses601's Avatar
Trader Rating: 29 (100%+)
hey guys, i am just waiting for mine to come in at the LHS.....just wondering if a velociti 7.5r and gtb will hold up in this?
thanks!
TLR SCTE 2.0
ses601 is offline   Reply With Quote
Old 12-07-2010, 06:50 PM   #1091
G_WORD's Avatar
Trader Rating: 112 (100%+)
thanks!
it will be fine....i use a 8.5 tekin and i have the travel down from 150 to 100.
Crispy Critters Hobby Shop & Raceway
Mugen MBX7R / AE B6D / TLR 22-4 2.0
G_WORD is offline   Reply With Quote
Old 12-07-2010, 07:26 PM   #1092
ses601's Avatar
thanks!
TLR SCTE 2.0
Old 12-07-2010, 07:46 PM   #1093
guys gonna be ordering one of these to try out friday. Any tips? is it anything like the hyper as far as shock limiting, steering mods etc...? im gonna be running a MMP with the sct motor for now.
tacomaster is offline   Reply With Quote
Old 12-07-2010, 08:10 PM   #1094
IDK about tips... mine works flawless in box stock form! All I did was put some calibers on it and its dialed! I love this truck... its quite fun.
Old 12-07-2010, 10:42 PM   #1095
Shock limiting isn't necessary, steering mods seem to be less popular over here but they transfer over if you want to put the work in.
HPI Savage: Ofna .32
Tamiya Nitrage: LRP ZR.30 Spec 2
Ofna Hyper TT: Tekin SC4x 4.5, Tekin RX8, 3s 5000mah LiPo
HyperTT is offline   Reply With Quote
