Hyper TT 4wd 1/10th Truggy Thread
#1066
I have the STRC jammin parts on my hyper 10sc with the bearings and it is silky smooth and not to mention bullet proof. This is definitely on my list of upgrades for my TT. My STRC kit comes with 2 upper servo saver pieces. One looks to be a lot thicker than the other. I know the "tips" thread on rcshortcourse says not to use the Jammin upper half but mine has worked well with the thicker strc aluminum upper arm (the one that goes directly to the servo). Hope this helps.
#1067
Found a link to do this in the Hyper 10SC forum, anyone tried it yet? I just bought the parts in aluminum from strc, hoping it works out well. I'll probably try and mount the drag link on the bottom like we're doing with the Ray Rabe mod right now.
EDIT: Apparently I can't even post links to other rctech threads, but it should be post 3829 in the Hyper10SC forum.
#1068
sweet!
ran it at the track today, and it is easy to drive! no bad habits that bug me. my older ss5800 gave up but it was on its way out i think. i'll ordered some pinions, so i can try my 6.5 again. also thinking 4.5 550 mnight be a good choice?
#1069
For those of you still on the fence about these things, all I can say is dont wait, go buy one. I finally got to use mine for the first time today and all I can say is WOW. Such a fun truck to drive.... and they handle like they are on rails especially if you are used to short course recently.
I ran the Sidewinder SCT system in it and its got all the power it needed. I was running the box stock suspension/diff setup just with Caliber tires which are the hot ticket at this track. I ran the truck today on a track that is about 125 feet wide and 70 feet deep so its pretty big. The truck is also durable. I head-on'ed an 1/8 buggy at the end of the straight (he was parked) and the hyper was fine. The only thing that happened all day was I did pop a ball cup off of the spindle so I will be doing the captured pin mod here soon. Anyways, if youre on the fence, dont wait... go buy one!
#1070
I ran mine yesterday, two 5 min heats and a 6 min main. Despite how tight and crunchy the pinion to crown mesh is, I didn't notice any ill effects. I'll hafta to a tear down during the week though, I can't stand this and hafta see if I can find a way to make em work together more nicely.
#1071
#1073
yo!
well i smoked my poor ss 5800 but i got a novak balistic 5.5 and a 15 tooth, it barely gets warm. no track test untill this weekend, but i can tell you the 550 is the way to go. they also have a bigger front bearing and a 5mm shaft, so you can use 1/8 scale pinions!
#1074
#1076
2 2s lipos wont fit in the case. i tryed doing that and you would have to cut one side of the tray off for them to fit
#1078
specks
148mm*34mm
#1079
its 34.5 mm inside dia with half an inch to spare length wise with standard stick pack
#1080
as a side note i cut the tray so i could lay my 5000 pack flat. you could do the same and stilll have 1/3 of the second battery on the tray?
