Like Tree4Likes
Old 10-08-2010, 02:40 PM   #91
lbckevin's Avatar
Trader Rating: 91 (99%+)
I am running my TT with a Tekin RS Pro and a 6.5 (smaller 540 motor) . Plenty of power and light weight.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-08-2010, 08:20 PM   #92
QTOWNCRAWLER's Avatar
Originally Posted by rfleck View Post
Anybody running a Novak HV 5.5? I was thinking of getting out of my Short course and into this. This looks to be more of a race truck!
I'm running a 4.5 HV ballistic in my TT & lovin' it. Plenty of speed with a 12 tooth pinion, gobs of torque, & I can run pack after pack with NO heat issues.
Pushin' it with a Castle MMP. Had to mount it on top of the servo plate, wouldn't fit under the body mounted on top of the center diff. I like this placement though. Puts the esc weight low & forward compared to mounting it on the diff plate.
AE B44 FT
Losi XXX-CR
Kyosho Ultima SC-R
Ofna Hyper 10TT
QTOWNCRAWLER is offline   Reply With Quote
Old 10-08-2010, 08:35 PM   #93
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Originally Posted by -R2- View Post
hub to hub is just under 9 3/4 width.
Thx. This is right before the hex, right?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 10-08-2010, 08:44 PM   #94
teeforb's Avatar
Hub to hub (end points), the ten-t is les then 10 1/2 width. So probably less than 3/4 in difference total.
Old 10-09-2010, 12:23 PM   #95
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally Posted by Drusillus View Post
I emailed Nitrohouse and asked them a similar question. He was their response.
Thanks for showing that email response, helps make my choices a bit easier. Looks like the 550 motors would be more efficient= cooler temps. Weight would be my only concern.
No problems with MMP's with these motors? They seem to work ok on my 1/8 stuff though.
How are your temps with the 540 6.5? How's the RS Pro holding up?
BOLISARIO is offline   Reply With Quote
Old 10-09-2010, 12:31 PM   #96
BOLISARIO's Avatar
Sorry for not getting back on here to answer your question, but I've only change the center diff oil to 5k and the changed the shock oils to 35wt Losi all the way around. The arms have a new location on the rear and I have mine in the middle but if you changed to the outside hole check for overall shock travel it migh be a lil short so you will have move out some of your shock end. The new thing on the car are the pillow balls if you have'nt noticed they have a flange at the end of the treading that's there to prevent the ball from popping the treads and going inward in the event of side impact and causing the threads to drive inward and getting more than you want camber. The other thing I have done was move the bat. tray foward it has helped the rear end bucking and gives me more free space to mount my esc on the other side rather on top center diff, it's too close up there and I'm afraid if I case a jump right on the top of the body then my esc will absorb a critcal hit and may not last in the long run. I need to post a pic so I will do this very soon.
On the manual, it shows that the center diff has 5k oil already in it. Is it a misprint?
When you moved the battery tray forward, did you have to drill new holes for it's new location or is it adjustable stock?
Any way you can post some factory set-ups(with better detail than in the manual) for the local like WCRC and OCRC?
Old 10-09-2010, 11:16 PM   #97
lbckevin's Avatar
Temps were fine....I did cut out the front winshield to let more air flow over the speedo...We ran it for 12 minutes without a problem.
Kevin Smith
Old 10-10-2010, 01:23 AM   #98
thecman26's Avatar
Trader Rating: 99 (100%+)
A ton of great info here! I will be getting one of these asap!
1 quick question, is it easy to get to the motor mount screws to adjust gear mesh, it looks a little tight from what I have seen, thanks!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-10-2010, 06:56 AM   #99
Ordered mine, should be here this week. Thinking about the Novak hv 4.5 motor, did they have issues with the Silver version of the motor? Wondering because i almost only see the black version for sale now.
speedworks is offline   Reply With Quote
Old 10-10-2010, 07:56 AM   #100
teeforb's Avatar
Hv is fine. U just can not disassemble it like the black ballistic motor.
Old 10-10-2010, 01:59 PM   #101
Good deal, just ordered the 4.5 SC version of that system. Im thinking of a 12 or 13t pinion for the setup.
Old 10-10-2010, 02:34 PM   #102
What kind of temps are you seeing at the motor and esc? Are you using the external heat sink on the motor?
Old 10-10-2010, 02:51 PM   #103
mc4798's Avatar
Where you race at ? Would love to take a look and compare it to my sparrowhawk.
mc4798 is offline   Reply With Quote
Old 10-10-2010, 07:28 PM   #104
HEAT's Avatar
Trader Rating: 26 (100%+)
Raced mine this weekend n it just didnt hav any on power st , pulled th front diff out n it just had a lil bit of grease in it n im guessin th rear is th same way !
Goin 2 try 5-5-2 n see how that feels
HEAT is offline   Reply With Quote
Old 10-11-2010, 09:49 AM   #105
BOLISARIO's Avatar
Can these keep up with 4wd 1/10 buggies? Those things are so super quick and nimble but very fragile.
