Like Tree4Likes
Old 12-01-2010, 08:04 PM   #1021
prettyboy's Avatar
Trader Rating: 59 (100%+)
Originally Posted by ses601 View Post
gotcha, thanks. newb question i guess i may be borrowing/buying that 12 tooth if its cool
Well as of right now I have the 12 on it. I also down sized my motor from the 6800kv to the 5800kv so we will see where my temps are on Sunday..
(ORIGINAL) HIGH POWERED HOBBIES RACE TEAM MEMBER
prettyboy is offline   Reply With Quote
Old 12-01-2010, 09:03 PM   #1022
Well this is my first post on these forums, and I can assume I'm going to get thrashed for doing this, but here are some pics of my typical TT.
Weight isn't too bad 2483g roughly on a scale, which is somewhere around 5.4lbs I believe, that is fully loaded with 5000mah 3s.
She is about finished, waiting on some odd and end parts.
BTW I do not race sanctioned events, I am 100% aware that there are much better and cheaper viable options for competitive racing, as there are better platforms to use the Monster on than a 1/10. I just love the 1/10 truggy platform and am set on getting this to perform reliably on the occasional twin 3s series use, which I already have fitted and complete, just too heavy for me to be worthwhile, for now...
sbcI355 is offline   Reply With Quote
Old 12-01-2010, 09:07 PM   #1023
Yosh70's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Ray Rabe View Post
As for spare parts, get some extra front steering blocks, front and rear arms. Those are the main three parts i sell everyday for people with TT's... Thanks guys,
Ray
Sorry but are you talking the steering knuckles? Just trying to get a list together for ordering.
TLR 8T 1.5, AE SC10, TLR 22SCT
Yosh70 is offline   Reply With Quote
Old 12-01-2010, 09:19 PM   #1024
Hey guys, first post on these forums, just posting some pics of my typical TT.
Don't flame me, I do not race sanctioned events, or competitively for that matter. I am well aware there are many other smarter and cheaper viable platforms, but I love the 1/10 truggy platform.
Weight fully dressed with 5000mah 3s is 2483g, right around 5.5lbs.
I have twin 3s fitted and ready for use sooner or later, but its just too heavy for me to be worthwhile at this time.
BTW the 6s use would be to lower temps and current draw, and extend runtime, not to demolish the poor truggy. Punch would without a doubt be dropped and gearing would be corrected.
Anyways, anybody have any advice on proper pinion size for the 2200kv on 3s for 40mph in the straights? I would assume 17-ish? I also am having some trouble getting some good info on springs, I need to compensate for the weight increase I already have, let alone if I go 6s.
Thanks in advance guys.
Hyper TT 4wd 1/10th Truggy Thread-pc010014.jpg   Hyper TT 4wd 1/10th Truggy Thread-pc010015.jpg   Hyper TT 4wd 1/10th Truggy Thread-pc010018.jpg
Old 12-01-2010, 09:44 PM   #1025
Originally Posted by HyperTT View Post
Hello everyone, first post. Just bought my TT last week haven't even run it yet. Done a couple of different things to it already. Replaced the rear dogbones, aluminum hop-ups, etc. New to electrics and was wondering how much drag should be in the drive train. I already swapped to the delrin spur from STRC but it still seems like there's some noticable drag once per revolution of the spur gear. I can also visibly see it's slightly warped and/or out of true by a small margin. Is this ok? What's the proper fix? Should I keep cranking on those little screws? I'm afraid I'll strip it.
Thanks - Derrick
Bump, any ideas?
I also have about 1mm of vertical slop in both my steering posts. Is this normal?
HyperTT is offline   Reply With Quote
Old 12-01-2010, 09:48 PM   #1026
Yes sir! I would get at least two sets of them for sure. That is the weakest part of the car..
MikesHobbyShop.com - CelphDesigns.com
Ray Rabe is offline   Reply With Quote
Old 12-01-2010, 10:39 PM   #1027
offplane's Avatar
Default what up!
got mine together! ran it around on the deck a little to see how my 13 tooth gearing was, motor( velociti 6.5) was'nt too bad but the spedo(older GTB) was hot, so i'm gona try an 11 or 12 tooth. i was gona do the ball stud mod, but changed my mind and just bent my own 54mm rod. it seems to turn good. i can't wait to get to the track and try it out! i think i'll get some panther tires. also as you can see in the picture i cut the side of the battery box so i could lay it down flat and get the CG a bit lower.
Hyper TT 4wd 1/10th Truggy Thread-2010-12-01-21.43.08.jpg
offplane is offline   Reply With Quote
Old 12-01-2010, 11:39 PM   #1028
Just a couple pics of my setup.
Hyper TT 4wd 1/10th Truggy Thread-hyper-tt-1.jpg   Hyper TT 4wd 1/10th Truggy Thread-hyper-tt-2.jpg   Hyper TT 4wd 1/10th Truggy Thread-hyper-tt-4.jpg
Old 12-02-2010, 05:04 AM   #1029
Toiffel's Avatar
Trader Rating: 52 (100%+)
^^^^I rechecked my spur (STRC) and it's not warped, there might be something wrong there, also checked, and truck rolls free no drag at all.
Kinda stumped on what it could be.....
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 12-02-2010, 09:09 AM   #1030
Thanks for the response, it's very slight but it's visible. Once per revolution it hits a low spot if you will. was much much worse with the stock spur but still exists with the STRC. Could be as simple as putting an extra turn on it but I'm hesitant with the plastic parts. Would you mind checking your steering posts?
Old 12-02-2010, 08:47 PM   #1031
S/X Runner's Avatar
Trader Rating: 37 (100%+)
So I put the STRC spur on to fix the leaking center diff issue...It's still leaking. I didn't counter sink the holes for the 3mm screws you are supposed to use (per DJ) instead of the stock 2.6mm screws. I actually tried to counter sink a STRC spur and I F'ed it up. So I got another one and just used the stock screws. I basically gave up and put the steel spur on the diff. Holy crap!!!!! This TT sounds like a freaking chain saw!!!
Some pics...
S/X Runner is offline   Reply With Quote
Old 12-02-2010, 09:06 PM   #1032
ebasher219's Avatar
How are those tires at norcal?
TLR SCTE-BCE Chassis-Tekin Pro4 4000kv-Savox 1258tg-Proline F150 Flo-Tek
Mugen ECO-BCE +3-Tekin 1900kv-Savox 1256tg-Proline 2012 Bulldog
TLR 22-JConcepts Punisher
ebasher219 is offline   Reply With Quote
Old 12-02-2010, 09:16 PM   #1033
S/X Runner's Avatar
They are ok when it is dry. Holeshots or step pins when it is wet.
Old 12-02-2010, 10:11 PM   #1034
What tires are they?
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 12-02-2010, 11:08 PM   #1035
From the pin shape they look like Subcultures to me although I didn't think they made them for trucks. Only SC and 1/8th scale... But I could be wrong.
At least be honest with yourself...
Dgee is offline   Reply With Quote
