Like Tree4Likes
Old 12-01-2010, 06:30 AM   #1006
Toiffel's Avatar
Trader Rating: 52 (100%+)
Thumbs up
Originally Posted by xrayrc View Post
Marshon your a barney cruizin got u covered spare parts wheels steering mod stuff springs just give me a buzz at shop 201-445-8080 and I will make you a care package for friday... Stevey charles out
Another benefit of being a Barney !!!!!
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 12-01-2010, 06:37 AM   #1007
marshon50's Avatar
Ok, will call u once I get final clearance to race Friday from the Misses!!! Definitely want a wheel set......
Thank you sponsors:
Werks Racing, 30% Race Blend Nitro Fuel, Werks B6 and Pro, B5 and Pro, B2, Pro Clutch
Hobby Pro USA, Agama USA, VP-Pro, Beta Racing Tires
Hobbymasters, Red Bank, NJ
Venom Group
marshon50 is offline   Reply With Quote
Old 12-01-2010, 07:07 AM   #1008
Hi, just got my TT yesterday from Nitrohouse.
I believe these are shipping with the thicker ackerman wire now. I purchased the upgraded ackerman when I ordered the TT, and they are the same black thicker wire.
Anyone know what 17mm work yet to run buggy tires? Looks to be the same thickness as the AKA slash 4x4 hub adapters, but not sure...
Into scalers now.
tedovt is offline   Reply With Quote
Old 12-01-2010, 07:21 AM   #1009
Toiffel's Avatar
Wire is same thickness, length of it is different, one is 54mm other one is 53mm or something similar, that is what changes the ackerman angle.....
Old 12-01-2010, 01:16 PM   #1010
offplane's Avatar
Default aka?
I had the aka adapters on my slash 4*4 and they sucked. Never stayed thight. Imho.
offplane is offline   Reply With Quote
Old 12-01-2010, 02:47 PM   #1011
-R2-'s Avatar
Mine has a Havoc Pro SC with a 6.5 Velocity motor with 12 tooth pinion. Timing is at stage 2.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 12-01-2010, 05:39 PM   #1012
Default newbie
just got my tt tonite....
had an extra slash 4x4 so i put the motor,esc and servo in my tt.... problem is my steering is backwards... i go right it goes left..ect... there has to be a setting to reverse this.. i am using a spektrum dx3s controller... sorry for such a newb question. any suggestions much appreciated.
westshore is offline   Reply With Quote
Old 12-01-2010, 06:00 PM   #1013
Slash65's Avatar
If the polarity of the servo is correct, I would check to ensure that servo reversing is not enabled on the transmitter. More than likely it is.
HoBao Hyper 10 TT
Sanwa MX-V
HobbyWing XeRun V2.1
Dynamite 6.5T
Slash65 is offline   Reply With Quote
Old 12-01-2010, 07:23 PM   #1014
ses601's Avatar
Trader Rating: 29 (100%+)
uh oh - i didnt realize they came with a mod 1 spur i guess i wont be running it with my velociti 7.5 this weekend....
TLR SCTE 2.0
ses601 is offline   Reply With Quote
Old 12-01-2010, 07:34 PM   #1015
ambryatim's Avatar
Trader Rating: 18 (100%+)
^^^ You could always run the 13T pinion that it came with, just keep an eye on your temps.
ambryatim is offline   Reply With Quote
Old 12-01-2010, 07:36 PM   #1016
ses601's Avatar
ohh i didnt realize the stock pinion would fit the shaft, i automatically related mod 1 with 1/8 setups. based on R2's post, i would guess a 13 tooth would be good for the 7.5
TLR SCTE 2.0
Old 12-01-2010, 07:44 PM   #1017
ambryatim's Avatar
All depends on your track.....might be too much....I am running a Tekin 6.5 and using an 11T....it is plenty fast for me and clears the triple at my track with speed/power to spare.
I would just double check temps to be safe. But, it should work ok.
Old 12-01-2010, 07:47 PM   #1018
prettyboy's Avatar
Trader Rating: 59 (100%+)
If you check out A-main parts list for the 10TT you will see all the pinions. They are mod 1 but for 1/10 scale. I have 12,13,14 so if you need 1 let me know on Sunday..
(ORIGINAL) HIGH POWERED HOBBIES RACE TEAM MEMBER
prettyboy is offline   Reply With Quote
Old 12-01-2010, 07:49 PM   #1019
ses601's Avatar
gotcha, thanks. newb question i guess i may be borrowing/buying that 12 tooth if its cool
TLR SCTE 2.0
Old 12-01-2010, 07:52 PM   #1020
Originally Posted by Toiffel View Post
This only confirms with what I said, the only visible benefit of doing the mod, is eliminating any slop in the steering, because as for adding more steering doesn't really do anything that you coulnd't do with changing the wire. Kudos for trying something different, keep the ideas coming...
I am sure it gives the TT more overall steering. Everyone that has tryed my mod over the Ofna 54mm link LOVES it. Everyone I talk to says it has alot more inital steering... i will post pics and the exact lengths all my turnbuckles are front, rear, rack and the turnbuckle that is connected to the servo arm. I hardly have time to do this as it is SUPER BUSY in the shop EVERYDAY!! I will try to keep everyone informed as to what i do as far as mods.. As for spare parts, get some extra front steering blocks, front and rear arms. Those are the main three parts i sell everyday for people with TT's... Thanks guys,
Ray
MikesHobbyShop.com - CelphDesigns.com
Ray Rabe is offline   Reply With Quote
