Like Tree4Likes
Old 11-30-2010, 09:43 AM   #976
Trader Rating: 478 (100%+)
AMain had them Sunday night!
QDRHRSE is offline   Reply With Quote
Old 11-30-2010, 10:00 AM   #977
Toiffel's Avatar
Trader Rating: 52 (100%+)
I know the guys from Cruzin RC in NJ has six of them in stock, just call Ron/Steve @ 201-445-8080 they will take care of you!!!!
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 11-30-2010, 10:43 AM   #978
Slash65's Avatar
Originally Posted by Kylar View Post
Damn, does anyone have these in stock? I want one for my xmas present
The Barn Floor has them in stock...
http://thebarnfloor.com/catalog/prod...oducts_id=2106
I am hoping to buy one for my X-Mas as well.
HoBao Hyper 10 TT
Sanwa MX-V
HobbyWing XeRun V2.1
Dynamite 6.5T
Slash65 is offline   Reply With Quote
Old 11-30-2010, 10:45 AM   #979
Toiffel's Avatar
Another great place ^^^^
Old 11-30-2010, 11:03 AM   #980
marshon50's Avatar
My backorder just went through with Tower....so they may have them in stock as well.....try your LHS first, if Tower has em, Great Planes have em and almost all hobby shops deal w/ Great Planes...
Thank you sponsors:
Werks Racing, 30% Race Blend Nitro Fuel, Werks B6 and Pro, B5 and Pro, B2, Pro Clutch
Hobby Pro USA, Agama USA, VP-Pro, Beta Racing Tires
Hobbymasters, Red Bank, NJ
Venom Group
marshon50 is offline   Reply With Quote
Old 11-30-2010, 01:00 PM   #981
prettyboy's Avatar
Trader Rating: 59 (100%+)
Originally Posted by Toiffel View Post
Couple of things, 1st. If you don't have the same amount of throw left to right, there is a mechanical problem, either servo wasn't centered properly, or your steering linkage is out of wack.
So making any set up changes are not going to affect the servo movement. Make sure your steering assembly is perfect, then work on set up.....
Thanks guys for the help.. Ive been racing for over 8 years and I feel like a newbe asking but Iam stumped.. Must be having a brain fart..lol. I'll deff go over the steering to make sure all is correct and go from there.
Thanks Agian Rob
(ORIGINAL) HIGH POWERED HOBBIES RACE TEAM MEMBER
prettyboy is offline   Reply With Quote
Old 11-30-2010, 03:54 PM   #982
Yosh70's Avatar
Trader Rating: 17 (100%+)
So I just rec'd the Hyper from NitroHouse and everything looks good except the oil leakage from the center diff.....sorry if this has been asked but all I do is just replace the spur with a different one? Part #?
Now just waiting for the Castle MM/4600 combo ordered on a Black Friday special thru the Castle site.
Any suggestions on a good overkill servo?
TLR 8T 1.5, AE SC10, TLR 22SCT
Yosh70 is offline   Reply With Quote
Old 11-30-2010, 03:59 PM   #983
Prettyboy:
The steering linkage rod ends could be hitting the diff case limiting steering throw. I went to town on my diff case with a dremel and increased throw by about 10%. Make sure to check throw throughout the suspension range as well.
danyak101 is offline   Reply With Quote
Old 11-30-2010, 04:00 PM   #984
raydog's Avatar
Trader Rating: 148 (100%+)
Double up the Blue gasket and you should be good.
-Raydog
Team Associated - Reedy - Schelle Racing - Pro-line Racing - Upgrade-RC - Thunder Designs
www.StickyKicksRC.com - R/C Tire Conditioner and Traction Compound
raydog is offline   Reply With Quote
Old 11-30-2010, 04:06 PM   #985
jaybird95's Avatar
Trader Rating: 14 (100%+)
Post
Originally Posted by prettyboy View Post
Hoping someone can shed some light on steering for me.. I did the steering mod asper Ray and I relize that it realy dont give you more steering so my question is how do you get more steering out of this? Ive done some grinding on the pillow ball mounts,lower arms where the pillow ball screws in so it can get more throw but no matter what ive tryed I get a boat load of steering to the right and not so much steering to the left. Any help on getting more steering throw left and right will be great..
Thanks Rob
I'm having the same problem. I did the steering mod today and the rpm ball cup on the right is hitting the bottom section of the servo saver. I havent started grinding yet. Should the outer turnbuckles end up being different lengths?
jaybird95 is offline   Reply With Quote
Old 11-30-2010, 05:50 PM   #986
This is the only problem with the steering mod i came up with. You will have more throw to the right than to the left. In order to fix this adjust your turnbuckles first so you have 1 to 2 degrees of toe out, and make sure both turnbuckles are the same length. Next dremel the side of the ball cup where it hits the bottom servo saver and grind down the servo saver post as well. You could also try different ball cups like losi or associated which are alittle thinner. I personally have not grinded anything on my TT since i had it. I felt it had more than enough steering after the rack change. But if you want some more steering try 2,7,1 for diffs, and TAKE OFF FRONT SWAY BAR. That makes the biggest difference. I also went to a losi blue rear spring moved all the way out on tower and in on arm. That helped as far as jumping and turning. Othar than that you can actually adjust the length of the "rack" to adjust ackerman. Just keep playing with it, it takes time on new cars to get a "dialed" setup, and everyones gonna have their own opinions on what works "best". Hope this somewhat helped, Best of luck to ya man.
Ray Rabe
MikesHobbyShop.com - CelphDesigns.com
Ray Rabe is offline   Reply With Quote
Old 11-30-2010, 06:47 PM   #987
Toiffel's Avatar
Originally Posted by Ray Rabe View Post
This is the only problem with the steering mod i came up with. You will have more throw to the right than to the left. In order to fix this adjust your turnbuckles first so you have 1 to 2 degrees of toe out, and make sure both turnbuckles are the same length. Next dremel the side of the ball cup where it hits the bottom servo saver and grind down the servo saver post as well. You could also try different ball cups like losi or associated which are alittle thinner.....
Ray Rabe
lol.....funny, you kept this little tad of information just for yourself until now....
just having some fun with ya.....
This only confirms with what I said, the only visible benefit of doing the mod, is eliminating any slop in the steering, because as for adding more steering doesn't really do anything that you coulnd't do with changing the wire. Kudos for trying something different, keep the ideas coming...
Old 11-30-2010, 06:53 PM   #988
jrz93's Avatar
lol isn't that funnt bbq...n he from washington lol
marshon cruzin could bring u one to the track cancel that backorder n steve can bring one to you!!!!
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 11-30-2010, 07:02 PM   #989
Toiffel's Avatar
Stock spur is garbage, if u crank down on the screws to stop the leaking the spur will warp, your are better off either using the steel sc one or this one from Nitrohouse http://www.nitrohouse.com/Car-Hop-Up...duct_info.html
Old 11-30-2010, 07:05 PM   #990
G_WORD's Avatar
Trader Rating: 112 (100%+)
we still on for sunday? the barn will have a bunch more TT racing on friday i may do both.
Crispy Critters Hobby Shop & Raceway
Mugen MBX7R / AE B6D / TLR 22-4 2.0
G_WORD is offline   Reply With Quote
