Like Tree4Likes
Old 11-24-2010, 08:00 AM   #886
ambryatim's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Toiffel View Post
Anyone????....Bueller....Bueller.......
Mine is right at 54mm from the center of the ball cups.
ambryatim is offline   Reply With Quote
Old 11-24-2010, 08:08 AM   #887
ambryatim's Avatar
Ok, So I installed my new "drag link" and here are some pics and explanations.
First You need to remove the upper hinge pin bracket.
Once off, you can just pull the bell cranks off and the old wire!!
I just rotated the arm to gain access to the under side of where the wire used to go thru. And installed the ball stud with spacers.
You should have these spacers in with the new body clips that came with the truck. I used all (4) of them one thick and one thin per side and they were just shy of 4mm thick.
Side view
Servo Saver side
When assembling the ball cups onto the turnbuckle, just screw the ball cup up to the end of the threads.
Tried to get a good picture of it installed.
After you get the ball studs installed reassemble everything....now would be a good time to replace the bell crank bushings with bearings. Then once assembled snap the new drag link in place and enjoy.
Old 11-24-2010, 08:18 AM   #888
S/X Runner's Avatar
Trader Rating: 37 (100%+)
Nice write up!!
What size are the bellcrank bearings that are needed?
S/X Runner is offline   Reply With Quote
Old 11-24-2010, 08:27 AM   #889
ambryatim's Avatar
Originally Posted by S/X Runner View Post
Nice write up!!
5x8x2.5 You will need 4 of them.
Old 11-24-2010, 08:29 AM   #890
Excellent write up thanks for the info. Much appreciated
danyak101 is offline   Reply With Quote
Old 11-24-2010, 08:36 AM   #891
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
thanks for the write up and pics.
what did you notice instantly with the truggy after the mod?
BOLISARIO is offline   Reply With Quote
Old 11-24-2010, 08:42 AM   #892
ambryatim's Avatar
Have not had a chance to drive it yet....I will let you know as soon as I run it, probably this weekend, After Turkey.
Old 11-24-2010, 08:46 AM   #893
S/X Runner's Avatar
That's what I figured, same as the SCRT. Thanks bro.
Old 11-24-2010, 02:04 PM   #894
Trader Rating: 101 (99%+)
Default All done...
Finally got the body back from Darkside Designs... Raced it last Sunday and had a great time getting bounced around with the 1/8e buggies!
The Tekin RS Pro with 6.5t (540) motor was perfect. Motor temp'd at 144*F after 7 minutes and I had a very useable power delivery on the indoor/clay track. The new ackerman bar is a great improvement over stock and is the best bang for your buck. Debating to add the graphite shock towers & center brace? For now though, it is definitely a fun alternative to my 1/10 scale 2wd & 4wd buggies!
Thanks for keeping this thread full of useful info!
Richard
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 11-24-2010, 02:45 PM   #895
ambryatim's Avatar
Richard
NICE BODY!!!
What was your pinion tooth count??? I have the Tekin Redline 6.5 and will be using a Speed Passion GT 2.0 Pro for the ESC. Are you using the stock rotor in the motor or a 13mm??
Old 11-24-2010, 02:56 PM   #896
Default Pinion...
I used the STRC 42T Delrin spur gear with a 12t pinion. I also added an AE FT aluminum heatsink with some air vent holes in the body (Front & Rear windshield), to help keep temps down... I have pretty conservative esc settings and even when I got aggressive with the timing/boost, it still never got over 150*F... Cheers!
Old 11-24-2010, 03:10 PM   #897
jrz93's Avatar
The only ones people have come up with are some RPM wheels (revolvers). No pics, no measurements...just someone who said they fit. I'm sure they fit and might be really close to the stock offset, I'm not gonna waste my money to find out though.
these fit
http://www3.towerhobbies.com/cgi-bin...2&I=LXPZD0&P=K
so do these...available in different colors
http://www3.towerhobbies.com/cgi-bin...2&I=LXRSK4&P=K
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 11-24-2010, 03:12 PM   #898
Default Chassis skids?
Has anyone found a rear chassis skid? I have around 40 packs through the truck and the rear of the chassis is showing alot of wear. The front is showing some wear but, the rear is wearing like an 8th scale.
losi b is offline   Reply With Quote
Old 11-24-2010, 03:51 PM   #899
S/X Runner's Avatar
Originally Posted by jrz93 View Post
I'm sure they do. There is a ton of wheels out there that will "fit". It's the offset and the width of the wheel we are looking for. Not one person has shown what is the same as the stock offset and width. I know the width is just 2.2 truck, but some don't seem to get it. It's the offset on these wheels that everyone is posting that is not known.
Old 11-24-2010, 06:23 PM   #900
Evo X Revo's Avatar
Trader Rating: 17 (100%+)
over 50 pages and i still dont know what combo i want to put in this little truck..was thinking mmp so i can utilize some 3s packs i have..no idea what motor to get since ive been running strictly nitro..
mostly going to race it though..what are the majority of people using? mostly for a high bite small - med size track. also want enough motor to mess around on some 1/8 tracks when summer rolls around again. rather go bigger and tune it down, in case i decide to use the system in something else 4x4. ie. b44.1
thanks for any input..
Tekno ET48
Tekno SCT410.3
Tekno EB48.2, .3
Tekno Nb48 (coming soon)
Evo X Revo is offline   Reply With Quote
