Like Tree4Likes
Old 11-19-2010, 09:35 PM   #811
carcrazy699's Avatar
Trader Rating: 48 (100%+)
Originally Posted by S/X Runner View Post
The rubber is pretty soft. If your track is hard at all, they will wear very quickly.
i use the stock tires on hard packed clay and they wear perfectly. they hook really good also. only downfall is the foam breaks down when they are getting close to being done
Losi Ten-T
Losi M8T
Lost M8DB
carcrazy699 is offline   Reply With Quote
Old 11-19-2010, 09:45 PM   #812
S/X Runner's Avatar
Trader Rating: 37 (100%+)
I forgot to say "clay". If your running in wet clay the tires will last. If your running on a dry track, they won't last.
S/X Runner is offline   Reply With Quote
Old 11-19-2010, 10:09 PM   #813
yeah dry track they will be gone quickly lol
Losi Ten-T
Losi M8T
Lost M8DB
Old 11-19-2010, 10:51 PM   #814
ebasher219's Avatar
What tires would you recommend for a hard packed track?
TLR SCTE-BCE Chassis-Tekin Pro4 4000kv-Savox 1258tg-Proline F150 Flo-Tek
Mugen ECO-BCE +3-Tekin 1900kv-Savox 1256tg-Proline 2012 Bulldog
TLR 22-JConcepts Punisher
ebasher219 is offline   Reply With Quote
Old 11-19-2010, 10:52 PM   #815
is it clay? if clay try barcodes gold compound or proline suburbs
Losi Ten-T
Losi M8T
Lost M8DB
Old 11-19-2010, 10:55 PM   #816
S/X Runner's Avatar
...or wishbones. If its dry try some enduros, or bowfighters.
Old 11-20-2010, 07:29 AM   #817
Questions:
Has anyone put 17 hex adapters on to run buggy tires? I know someone asked dozens of pages ago.... What brand of adapters work?
Would a Novak 13.5 SS motor do okay (I believe it's a 3300 540)? I have one laying around. Had in in my rock racer, but took it out...
Thanks in advance,
Ted
Into scalers now.
tedovt is offline   Reply With Quote
Old 11-20-2010, 07:43 AM   #818
Originally Posted by tedovt View Post
Questions:
Thanks in advance,
Ted
I've got a set of RCmonster 17 hexes that fit perfect but no buggy tires yet. Soon I wear the stockers out I'll switch over.
Cody01 is offline   Reply With Quote
Old 11-20-2010, 08:25 AM   #819
dspoo2's Avatar
Questions:
Thanks in advance,
Ted
1+ i was going to ask the same, and im sure you could find it in the 10cs or scrt threads
David
B44.1 - Novak - Pro-Tek - Spektrum
RC10T4 - Novak - Pro-Tek - Spektrum
soon hyper 10TT
dspoo2 is offline   Reply With Quote
Old 11-20-2010, 09:49 AM   #820
If anyone can help I am looking for more off power steering
I am running 1 degree of toe out
30/wt front and back
stock springs
all shock locations and arm locations at stock
http://www.youtube.com/watch?v=Nfvd7...layer_embedded
Here's a video of my rig
TIA for any setup tips
danyak101 is offline   Reply With Quote
Old 11-20-2010, 09:51 AM   #821
have you changed the diff lube? if not try 5/5/1 also try the steering ackerman mod with the tie rod or get the new one from nitrohouse
Losi Ten-T
Losi M8T
Lost M8DB
Old 11-20-2010, 10:00 AM   #822
S/X Runner's Avatar
Here is Dan's video...
+ YouTube Video
Old 11-20-2010, 10:04 AM   #823
I haven't the time to read 55 pages of this thread but the hyper 10tt just got released here in the UK and it's almost tempting me away from the hyper 7.5 1/8 buggy i was going to buy and make brushless.. looks really sweet. OFNA in the US are what we in the uk call HoBao, right? they make the hyper 7s etc here.
also wanted to add - anyone who thinks any RC car is not tough.. think about it.. say you jump 3 feet high with a 1/10 scale RC.. try jumping the equivalent in a real car (30 feet high) and you'll see how tough they are.. lol
- Does being on fire count as fixed? -
skree is offline   Reply With Quote
Old 11-20-2010, 12:46 PM   #824
prettyboy's Avatar
Trader Rating: 59 (100%+)
Originally Posted by Ray Rabe View Post
Hey man, ill try and take some pics of my car as well as get the exact part numbers for each part tomorrow when I get to work. (you can do that when you work in a hobbyshop)
Hey Ray did you ever get the chance to look up the part numbers on the steering mod ?
Thanks Rob
(ORIGINAL) HIGH POWERED HOBBIES RACE TEAM MEMBER
prettyboy is offline   Reply With Quote
Old 11-20-2010, 01:12 PM   #825
Thanx for embedding that vid for me SX
I will try to shoot some footage of the 10TT's tonight at OCRC so more peeps can see just how fun these rigs are and how well they handle.
Some mod's I have made to mine are:
All the SNG Carbon stuff including chassis which cut about 3/4 of a lb off the overall weight!
Aluminum Chasis braces
Rear hub carriers
Rear CVD's
Upgraded center diff spur (it still leaks but its coming out of front seal around outdrive) diffs are currently 5-7-2
Moved batt box all the way forward and mounted ESC behind the batt box for lower cg
dremelled away some material on the front diff for greater steering rack throw
PS on tires I think the stocker pre-mounted fuzzys x4 at 29.95 are by far the best deal and work pretty much everywhere I have been run it so far (OCRC, Outback, Delta/Norcal)
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
