Like Tree4Likes
Old 11-14-2010, 09:28 PM   #706
ebasher219's Avatar
so of the 1/10 sensored motors what turn motors are people preferring? ive read of people using the 6.5-10.5 motors
TLR SCTE-BCE Chassis-Tekin Pro4 4000kv-Savox 1258tg-Proline F150 Flo-Tek
Mugen ECO-BCE +3-Tekin 1900kv-Savox 1256tg-Proline 2012 Bulldog
TLR 22-JConcepts Punisher
ebasher219 is offline   Reply With Quote
Old 11-14-2010, 09:30 PM   #707
carcrazy699's Avatar
Trader Rating: 48 (100%+)
im running the 6.5r velociti from novak. later on i will try the ballistic since i can rebuild it unlike this motor
Losi Ten-T
Losi M8T
Lost M8DB
carcrazy699 is offline   Reply With Quote
Old 11-14-2010, 09:32 PM   #708
D-Rek07's Avatar
Do you guys use 550 motors or 540 motors in these?
B4.1-MMP, 10.5 Ballistic
SC10 4x4-RX8, 4.5 Tekin
D-Rek07 is offline   Reply With Quote
Old 11-14-2010, 09:34 PM   #709
im running a 540 motor with no issue at all. i have very good low end power and tons of top end
Losi Ten-T
Losi M8T
Lost M8DB
Old 11-14-2010, 10:16 PM   #710
Trader Rating: 50 (100%+)
but the hyper mini ste was a brushless crt.5...i thought hobau, hong nor, hyper, ofna and jammin were all the same thing (like hpi and hotbodies...and how they made the hpi vorza which is an electric hotbodies d8)
im confused about how they both use most of the same parts...i know the hyper ste, the scrt-10 and the crt.5 share most parts...cant wait to find someone that used this chassis on a crt.5 so i can make a chassis order...from the pics this chassis looks a tiny bit longer than the crt.5 extended chassis
/\/\/\thats a sweet looking track btw
streetsports is offline   Reply With Quote
Old 11-14-2010, 10:51 PM   #711
ebasher219's Avatar
what are your temps? and what size track do you run on?
Old 11-14-2010, 10:54 PM   #712
i run at ocrc here in huntington beach. not sure the size though. my temps without my fan run about 140-150 depending on how agressive i am with it. with my fan on it runs at 125-130. i run my sxx with the profile 10 which i need to bring it down 2 or 3 steps and see how it does. i can definatly hold with the big boys on the track
Losi Ten-T
Losi M8T
Lost M8DB
Old 11-15-2010, 04:47 AM   #713
xrayrc's Avatar
Trader Rating: 61 (100%+)
Originally Posted by Toiffel View Post
I need more steering........we had to slow down to a crawl in the middle section.http://www.youtube.com/watch?v=-350p...layer_embedded
Toiffel ray rabe's post is on the money I ran on that same track sunday with the rear shocks all the way out on tower and in on lower arms I switch to hyper10sc rear blue springs and it turned better than changed front tires to flipouts and almost ran 20 laps we turned 17 on friday truck is better now still running stock grease and 5k in diffs shock oil is 35f - 30r let me know if you need more help see you friday bud
Thanks to my sponsors Team Associated, Reedy, Jconcepts, Venom Group
Cruizin With RC's & Raceway
xrayrc is offline   Reply With Quote
Old 11-15-2010, 04:51 AM   #714
I run at Mikes Hobby Shop in Carrolton TX. Im running a Tekin RS Pro and Novak SS 8.5 and i can pull on the 550 can guys On the straight. Temps are 150 on the esc and 115 on the motor with a fan.
Hyper 10SC
Team Terribles, Mike's Hobby Shop Carrolton Tx.
Up and coming factory team driver
slowslug is offline   Reply With Quote
Old 11-15-2010, 07:15 AM   #715
Toiffel's Avatar
Trader Rating: 52 (100%+)
k....that's on the list of changes, if you have any more springs can u bring them on friday!!!
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 11-15-2010, 01:58 PM   #716
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally Posted by Ray Rabe View Post
Hey guys I just wanted to let everyone know what to get for the steering mod I did which works great! I was the yellow OfnaTT in the video at Mikes Hobby Shop. All you need to buy are;
1. Any 1" turnbuckle (Lunsford or Associated and since they come in a pair, you can split the cost with a buddy since you each only need one turnbuckle )
2. Lunsford LONG ballstuds
3. Long RPM ballcups
4. Two washers roughly 5mm (I used my old limiters that came with my Losi shock rebuild cartriges. It comes with two in a pack, use the BIGGER one)
Now for the steps installing the rack;
1. Take out the crappy silver "rack"
2. Put one washer under each ballstud and screw it in from the bottom of the steering posts, NOT THE TOP (the new rack will be under the front coupling instead of the top like the old one)
3. Screw your RPM ballcups on turnbuckle till it bottoms out. Yes screw all the way in till it stops. Pop the ballcups on the ballstuds under the front coupling. (The easiest way to do it for me was pop on one side first, than slide the turnbuckle under the coupling and pop on the other)
4. Make sure you have no subtrim in your steering and recenter your servo. After recentering your servo adjust your toe in/out accordingly to your preference, than adjust your enpoints on your radio to limit or add travel. Drive it and you should notice quite a difference!
I hope I didnt make this sound to difficult to understand! But if ya got any questions feel free to ask. Thanks guys,
Ray
Can you post pics of your mod so we can get a good visual of what is needed and how it is mounted?
BOLISARIO is offline   Reply With Quote
Old 11-15-2010, 02:16 PM   #717
ebasher219's Avatar
thanks i was there last week for a few hours so i have a good idea of the size. thanks for the info
Old 11-15-2010, 02:57 PM   #718
2680's Avatar
couple questions:
1. has anyone run these with short course tires and made it more of a buggy? would this hang with 1/8 scale buggies? was looking at the kyosho dbx ve, but this looks like it might be a better choice.
2. i am confused on the pinions... are they different than 48p? if so, and i purchase one, would i need to get a pinion with it, or does the kit come with one?
3. any gearing advice for a sidewinder 4600kv, running sct tires? track is med size, somewhere btw 1/10 and 1/8 scale... we run both.
thanks guys!
HPI-Hotbodies: VE8, Blitz, Savage FLUX 2350
Losi: XXX-SCB, Mini-SCT, Nightcrawler
Associated: B4.1; Traxxas: Slash 2wd
Racing at www.CCRCR.net
2680 is offline   Reply With Quote
Old 11-15-2010, 03:13 PM   #719
Originally Posted by 2680 View Post
couple questions:
thanks guys!
1. i dont think anyone has put sc tires on it yet but i could be mistaken. And yes this will keep up with some 8th scale buggies if the right motor is put in and geared right but some 8th scales are insanely fast. The dbx is more of a beginner car than a race car. i had one and it would take alot of tuning to get it right for a track.
2. these are 32p mod 1 pinions. it does come with a 13t pinion with the kit but depending on motor and track you will have to get other pinions
3, no idea on the gearing for the sidewinder combo. im running a 11t pinion with a 6.5 motor on a med to large track
Losi Ten-T
Losi M8T
Lost M8DB
Old 11-15-2010, 03:44 PM   #720
Trader Rating: 37 (100%+)
couple questions:
thanks guys!
I know once these stupid tires it comes with are wore out I'm throwing 17mm hexes on and some 1/8 buggy wheels. That way it will handle well and truly like a mini truggy.
Cody01 is offline   Reply With Quote
