Like Tree4Likes
Old 11-08-2010, 11:28 AM   #586
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally Posted by losi b View Post
Ray built a turnbuckle and attached it to long ballstuds with spacers. Give Ray call and he'll give you the part numbers. Btw, it works great.
Does Ray have an email address that I can contact him with?
BOLISARIO is offline   Reply With Quote
Old 11-08-2010, 11:33 AM   #587
ambryatim's Avatar
Trader Rating: 18 (100%+)
You can go here and PM him and he should get back to you. He is not working today.
But, as far as email...I dont have one for him.
ambryatim is offline   Reply With Quote
Old 11-08-2010, 11:35 AM   #588
BOLISARIO's Avatar
Originally Posted by -R2- View Post
The case is not the prob. the delrin just doesn't like the 2.6mm screw, I think because when you screw down the 2.6 it has not bottomed out and continues to dig into the spur causing the warping.
The 2.6mm screws work perfect with the metal spur.
Or couldn't you just replace the spur with an STRC spur gear. Much better quality spur gear and with a lot less flex. Mine does not leak with it but I will double check.
Old 11-08-2010, 11:55 AM   #589
ambryatim's Avatar
Here are some crapy phone pics of my HyperTT no ESC/Motor yet.
Old 11-08-2010, 12:14 PM   #590
lbckevin's Avatar
Trader Rating: 91 (99%+)
Guys...
Why spend alot of money to fix it...Get some silicone or gasket maker and be done...Not one leak. You can get it at Target, Walmart, Autozone, Pep Boys, Lowes or Home Depot...it was $ 2.99
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 11-08-2010, 12:16 PM   #591
Trader Rating: 27 (100%+)
Originally Posted by lbckevin View Post
Guys...
thanks for the tip. I just found out this weekend mine leaks.
Scx10
Tekin fxr
Futaba 4pl
whjdm069 is offline   Reply With Quote
Old 11-08-2010, 12:31 PM   #592
Toiffel's Avatar
Trader Rating: 52 (100%+)
Guys...
ok, that will fix the leak, but what about the warping?? Will that cause any sort of decrease performance wise???
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 11-08-2010, 12:41 PM   #593
ambryatim's Avatar
The silicone/gasket maker is a band-aide at best.
I would think it would cause the Spur (Derlin) to wear prematurely (if it was warped severely)....so IMO I would fix the warped, Spur or Diff case then worry about the leak....But, if you fix the warped portion then you will also fix the leak.
Old 11-08-2010, 02:56 PM   #594
G_WORD's Avatar
Trader Rating: 112 (100%+)
Is the Spur (Derlin) warped before or after using the truggy
Crispy Critters Hobby Shop & Raceway
Mugen MBX7R / AE B6D / TLR 22-4 2.0
G_WORD is offline   Reply With Quote
Old 11-08-2010, 04:37 PM   #595
Trader Rating: 101 (99%+)
Guys...
Thanks Kevin!
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 11-08-2010, 07:14 PM   #596
jrz93's Avatar
Default shock shafts
ordering some spare parts and ran into an issue
does anyone know which it the proper part number for the shock shafts is ?
ofn21062 .....or
ofn21138????
thanks
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 11-08-2010, 07:30 PM   #597
G_WORD's Avatar
ofn21062 .....or
ofn21138????
thanks
OFN21062
Old 11-09-2010, 08:42 AM   #598
Toiffel's Avatar
Any option shock shafts??? looking for TI ones???!! Something a little smoother.....
Old 11-09-2010, 02:40 PM   #599
ambryatim's Avatar
Not trying to change the subject, but would the Speed Passion GT 2.0 Pro be a good ESC to use??
I am thinking of this or a Mamba Max Pro.
Old 11-09-2010, 02:45 PM   #600
SaladFork's Avatar
That would work fine for anything down to 3.5T. I would take the GT 2.0 over a MMP.
TLR | AE | AKA | Viper |
SaladFork is offline   Reply With Quote
