Like Tree4Likes
Old 01-06-2017, 07:37 PM   #4021
tsair's Avatar
Originally Posted by CaliBayWolf View Post
I'm looking to up grade tha shocks and some other things I hate tha pop off shock set up...Anyone have any idea's ????
I'm not sure what you mean by "pop off shock set up", can explain a little better?
I'm investigating what other shocks fit, and have some ideas... In the meantime, 25wt Associated in the rear is loads better, the stuff that came with it is like molasses!
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is online now   Reply With Quote
Old 01-06-2017, 10:24 PM   #4022
Maybe its on tha older models(not sure) but tha shock pops on and off a ball like screw... Ofna part 19031 called a steel ball,shock...Just a pain to pop it on or off...
CaliBayWolf is offline   Reply With Quote
Old 01-06-2017, 11:42 PM   #4023
tsair's Avatar
Ah OK, I see. I just unscrew the cap head on the other side and leave the steel ball in the shock cap.
Razor RC blog:
Old 01-07-2017, 02:16 PM   #4024
Da*n gotta luv tha simple fix lol thanks...
Old 01-07-2017, 03:30 PM   #4025
tsair's Avatar
OK, truck is back up and running. Installed a bunch of durability upgrades. Integy billet knuckles and top brace, STRC aluminum hexes, TLR serrated/lock wheel nuts, and the T-bone bumper.
Hopefully this keeps it up and running for a while!
Razor RC blog:
Old 01-07-2017, 05:17 PM   #4026
robert@castle's Avatar
Originally Posted by Slash65 View Post
Well if I had decided to turn on a video camera yesterday, I would of a nice burning ESC for everyone to see! So now I am in the market for a new one. I am thinking either Castle or HobbyWing. Can I get some opinions as to which one I should go with? If you feel a particular combo is worth looking at I am all ears.
If you are wondering it was the Traxxas VXL that went up, I only installed that because it was all I had on-hand at the time.
I think you should go with a Mamba X with our 1410 3800kv sensored motor, but I guess I'm a bit biased.
Software Engineer for Castle Creations
I'll do my best to answer your Castle related questions
robert@castle is offline   Reply With Quote
Old 01-08-2017, 12:19 AM   #4027
I second that !! When is it available ?
https://www.facebook.com/kyrcrc/
slowsrc is offline   Reply With Quote
Old 01-08-2017, 06:54 AM   #4028
Slash65's Avatar
Sorry to hear about the ESC, hopefully the truck escaped unharmed! The HW is pretty big and heavy, if there were a lighter and smaller ESC, I would consider that.
Weights of my electronics:
http://razorrcblog.blogspot.com/2017...s-weights.html
When it happened, I was lucky enough to have it on the car stand with the body off. I immediately yanks the battery connection while heading out the door holding it by the wing and blowing on the flames. The smell hung around for a few days...
HoBao Hyper 10 TT
Sanwa MX-V
HobbyWing XeRun V2.1
Dynamite 6.5T
Slash65 is offline   Reply With Quote
Old 01-08-2017, 07:05 AM   #4029
Slash65's Avatar
What is the main difference between the Mamba X & Mamba X SCT?
HoBao Hyper 10 TT
Sanwa MX-V
Dynamite 6.5T
Old 01-08-2017, 10:46 AM   #4030
Slash65's Avatar
Looks like the SCT version is available.
http://www.castlecreations.com/en/su...bo-010-0161-00
HoBao Hyper 10 TT
Sanwa MX-V
Dynamite 6.5T
Old 01-08-2017, 01:57 PM   #4031
Nice. Think I want one of them for Pro4
Old 01-08-2017, 05:38 PM   #4032
Honestly, nothing. I'm not sure why we are branding it that way. It's just what we are calling the combos that come with the 1410 and 1415.
Edit:
Also worth pointing out that both the 1410 and 1415 are available with 1/8th(3.2mm) and 5mm shafts, and the 5mm shafts are longer than the old motors because there was some cars that the pinions were hanging 4-5mm of the end of the shaft to get the correct mesh. For most setups the 5mm shaft is going to be better because of the extra strength, but you'll need a different pinion.
Old 01-08-2017, 05:40 PM   #4033
The ESC only is shipping now. The motor combos should be shipping very soon. I think we just got the packaging for it on Friday, and that was the last hold up on shipping the combos.
Old 01-09-2017, 03:22 PM   #4034
tsair's Avatar
OK, this time I got to run 2 battery packs before I hit the pipe and snapped an upper arm. I wouldn't say it was a soft hit, but certainly something most cars would survive. The aluminum knuckles held up great at least!
The car was fun while it lasted, and gave me a big smile on my face. Oh well, new arms on order and I'll try boiling them to see if that makes them more flexible.
I also figured out some tuning information. Definitely ditch the front swaybar.
Rear blue Losi springs with 25wt AE oil works pretty well, I left the front shocks stock but it's definitely overdamped and probably a little oversprung as well. I'm going to try the blue Losi spring up front with 30wt AE oil next time I can get the truck running.
I also noticed a design flaw in the steering -- there is NO Ackermann steering whatsoever! In fact, I'd even say the front seems to have reverse Ackermann. This really hurts the slow speed, tight corners and 180 degree turns. A little toe out helps combat this issue, but that's a design flaw in my opinion. I have the 54mm Ackermann bar btw, I'll try swapping it out for the Traxxas part above. Maybe I can dial in a little more Ackermann with the adjustable part.
Wheels are basically parallel or even slightly reverse Ackermann at full-lock. It doesn't look that way in the picture, but trust me -- it is.
Razor RC blog:
Old 01-09-2017, 06:38 PM   #4035
I have a hyper 10sc which shares about 90% of the same parts. The best thing I did for my car was purchase a T-bone racing.com front bumper. Look into it....best money you will ever spend if it fits....
SouthFloridaApp is offline   Reply With Quote
