Hyper TT 4wd 1/10th Truggy Thread
#3691
Hey guys which one of this servos would be ok to run on my TT?
HXT
http://www.hobbyking.com/hobbyking/s...HXT_Servo.html
HobbyKing
http://www.hobbyking.com/hobbyking/s...ing_Servo.html
HXT
HobbyKing
#3692
I haven't clocked it but trust me that motor is a beast. The fan doesn't even kick on. But it did with the 5700 four pole. I could gear up some more. Honestly you may want a larger pinion. That motor is not stupid fast but its strong and reliable. It has the torque to gear up and keep cool. Try different pinions and enjoy.
#3693
#3694
Yes let me know where I can buy that servo I would be interested..what r the specs?
#3695
#3696
new body the olour is abit brighter than in the pics its supposed tobe maroon not brown
#3698
just got my strc steering bellcrank partially fitted no screw`s so cant get it all fitted up properly yet. hopefully in a couple of days the rest will come and then all finish it off
#3699
since no-one make s a carbon fibre front tower iam going to make my own here is the proto-type i made from some plastic sheet. just one thing todo is lower the shock position as ive got it sitting too high right now i also made it abit higher than standard about 1cm as iam running the 16mm shocks and they dont get enough travel but this will help out alot.
#3700
Like this?
http://www.snrgraphite.com/index.php...dff70b028ad2c2
#3701
Constantly bending my rear center dogbone on big air landings. Seeing if an additional rear brace helps or not. Waiting for a longer 3mm screw (3x45mm) to come in for a full test.
#3702
#3703
They sell them out nitro house just look under hop ups.
#3704
alittle bored too much rain to run anything so i made my own mudguards just for the rear right now i know i could have bought them but like i siad i was bored. oh and are the carbon center braces any good
#3705
Hey guys I recentrly got a TT as a roller and I just finished installing my electronics, the car runs like a dream but I have a loud noice when turning..can someone help me out identify this problem?
Here's the video
http://www.youtube.com/watch?v=Vkh9Fe7G2i4
Now do u guys think my spur gear is too close to the chassis and that might be it?
Here's the video
