Like Tree4Likes
Old 04-18-2012, 10:36 AM   #3676
stuartd's Avatar
any of you guys know were i can get a 160mm long batt tray as i need one for my new batts to fit in the standard one is too short
stuartd is offline   Reply With Quote
Old 04-18-2012, 10:39 AM   #3677
dumbcomputers's Avatar
Just cut up the stock tray. That's what I did.
- Ten-Te
- Hyper 10TT
dumbcomputers is offline   Reply With Quote
Old 04-18-2012, 11:40 AM   #3678
stuartd's Avatar
i have for now but i was hoping not to as i dont want the battery to get damaged with it being exposed this is what it looks like now
Hyper TT 4wd 1/10th Truggy Thread-180420124299.jpg
Old 04-18-2012, 11:35 PM   #3679
I think your over-thinking it...I don't see much damage happening to the battery having that rear facing small area exposed.
- Ten-Te
- Hyper 10TT
Old 04-19-2012, 02:19 PM   #3680
aquito's Avatar
Hey guys quick question, I just purchased a roller ofna and will be putting my castle SCT 3800kv combo in it, what pinion gear should I use? I think the truck came with the stock spur gear it's a blue color one. Oh and I will be running a gens ace 2s 5000 40c..I will be using the truck for bashing and ocassionaly track events
aquito is offline   Reply With Quote
Old 04-19-2012, 02:58 PM   #3681
I would be careful about temps with the Castle SCT 3800KV combo for the motor. A friend of mine put one in his slash and used a 16T pinion and it would stop for a few minutes then go again. I called up Castle and can't remember if they said do not use more than a 15T or 14T pinion. I would start out with a 14T pinion. The latter information is for a 2S setup. I am using the Castle SCT 3800Kv in a Losi 810E and use
3S and a 11T pinion. Temps are about 142F.
SouthFloridaApp is offline   Reply With Quote
Old 04-19-2012, 03:01 PM   #3682
mkiiina's Avatar
Trader Rating: 69 (100%+)
You'll be fine. Think about the path something would need to take to hit that. Heck I have the whole side of my battery tray cut off so I can run my packs laying down with soft packs and still no problems!
mkiiina is offline   Reply With Quote
Old 04-19-2012, 03:04 PM   #3683
mkiiina's Avatar
I run that combo in my Hyper TT and its great. I'll check on the gearing when I get home. Mine runs cool and actually could be geared up some for more speed (our track isn't very big so I don't need a ton of speed).
You can't compare gearing between models as they have different drive ratios, different weights, different wheel diameters, and different purposes. Heck even the number of cells will change what gearing you should shoot for.
Old 04-19-2012, 03:11 PM   #3684
I have a Hyper 10SC and was speaking of experience with the Castle 3800KV on an outdoor track. I would think that the Hyper 10Sc and the Hyper TT would have the same gearing as they are almost identical. Evidently, my latter post was confusing as I now use the Castle 3800KV in a Losi 810E.
Old 04-19-2012, 04:02 PM   #3685
aquito's Avatar
So if I use a 12 pinion gear I would be fine then? Would it be atleast over 30mph with that setup on 2S?
Old 04-19-2012, 04:03 PM   #3686
Gearing is the same on a hyper 10sc but a hyper tt is lighter so you can gear higher. I own both.
slasn_48 is offline   Reply With Quote
Old 04-19-2012, 04:04 PM   #3687
aquito's Avatar
Ohh and I forgot to ask, I have a HobbyKing 120a esc and a Tacon 4420kV motor. I have it right now on my ecx ruckus, that thing flys on 2S. Do u guys think it would be overkill for the TT? If I use this setup what pinion har should I get?
Old 04-19-2012, 04:51 PM   #3688
mkiiina's Avatar
Yes that does make a difference (you mentioned you had it in a slash and quoted that gearing previously). I am running a 16T gear.
As for the 120a esc...the hk 120 would be overkill and it would be a problem getting it to fit also (made the mistake of trying once before). The HK 100a esc works great and is of similiar size to MMP
Old 04-19-2012, 05:44 PM   #3689
Check page 244 that's my tt. I run that combo with a 15t m1 pinion. Temps are barely warm with a 3s. You will love it.
budget man is offline   Reply With Quote
Old 04-19-2012, 08:05 PM   #3690
aquito's Avatar
How fast is it with that setup? I already ordered a 12t pinion and will run on 2s so probably will be slow as hell lol
