Like Tree9Likes
Old 02-18-2012, 12:17 AM   #3556
ambryatim's Avatar
Trader Rating: 18 (100%+)
I am offically jealous of you and your track!!!! That is AWESOME!!!!
Originally Posted by bjs1785 View Post
Well, as expected my 10TT was in when I got home from work at 5pm. As soon as I walked in with it, I opened it and started to tear it apart, then boiled the parts for 45 minutes. I also did a quick paint job (I got the idea off of another member here who posted a picture in one of the pages.) I had the colors available and I'm happy with the results. MMP and 1410 3800 will be in on monday. Right now just a tacon and sidewinder to try it out.
So far Im very happy with this roller!! Cant wait to get it to the track...
Pictures are of...
1) Truck torn down an hour after I got it to boil parts
2) Back together, Quick paint job on body
3) Backyard track, video coming soon... check out bjs1785 on youtube to see the backyard track now...
ambryatim is offline   Reply With Quote
Old 02-18-2012, 09:28 AM   #3557
Thanks! The track has been around for a couple years, always a work in progress!
bjs1785 is offline   Reply With Quote
Old 02-18-2012, 03:11 PM   #3558
Boadazofa's Avatar
Trader Rating: 33 (100%+)
My god that is better than most club tracks i have seen!!! bloody good job you have done there!! cant wait for the video!
Lone Wolf
Boadazofa is offline   Reply With Quote
Old 02-18-2012, 04:07 PM   #3559
Deaner's Avatar
I seen a hyperTT roller kit at my LHS yesterday, and was very impressed with its construction. I've really wanted a 4wd 10th scale to run on my backyard supercross track but have stayed away from the 4wd buggies as from what Ive heard they are fragile. My 2wd buggies and stadium trucks work well and are holding up well on my track, which I also run 1/8 scale buggy on. The hyperTT looks like it would be able to handle my track, and the price is very nice.
I've been reading this thread and seems like many different motor/esc combos work for many different guys. I'm wondering if someone can lend some advice? I've had good luck with Tekin systems and like the idea of the sc4x and a rx8 esc, but maybe the MMP system is the way to go? Don't really want to break the bank on this build. I'm completely unfamiliar with novak systems, but I'm not opposed to them.
I run a rx8 in my rc8be and it's been flawless. Just not sure if its overkill and money that I can wisely spend on spare parts?
Basically I'm interested in what the best bang for buck motor/esc combo is for the rig. Right now I'm leaning towards MMP 5700kv, or 4600kv system. Price is right and seem like people have had good luck with the MMP. Will be running 2c.
Just wondering if someone has any advice. Also would love to hear from you novak guys out there!
Deaner is offline   Reply With Quote
Old 02-18-2012, 05:31 PM   #3560
ndi_guy's Avatar
Trader Rating: 32 (100%+)
I ran a mmp, sc4x 4.5, 14t pinion, 65c 2s batteries. It was all I needed and then some.
ndi_guy is offline   Reply With Quote
Old 02-19-2012, 01:12 AM   #3561
hi all, I just got my first TT it's running a velineon setup. I was getting the steering dialed in and I noticed the right rear wheel is toed in to the left which causes the truck to hop to the right. I thought the hinge pin was bent but it's good. I was wondering if the rear lower arms holder is supposed to be flat. Any other suggestions or help with this would be appreciated.
OFNA Hyper 10TT
OFNA TS4
RC18B
redskull1944 is offline   Reply With Quote
Old 02-19-2012, 02:00 AM   #3562
cronmorg's Avatar
Default new set up is beast But!
had a problem with theses steering knuckles trying to find aluminum replacements to tighten it up any suggestions ?
Hyper TT 4wd 1/10th Truggy Thread-2.jpg   Hyper TT 4wd 1/10th Truggy Thread-3.jpg
cronmorg is offline   Reply With Quote
Old 02-19-2012, 07:57 AM   #3563
ambryatim's Avatar
Have not tried these but they are the only ones that I know of.....Aluminum Steering Knuckle.
Old 02-19-2012, 08:19 AM   #3564
ambryatim's Avatar
Here is mine....it has toe in also.
The toe is determined by the rear hinge pin plate.
It should be fine cause mine drives good like it is...double check to see if you broke a rear hub.
I drove with mine broken for a while before I noticed it was broken and it would do just as you have described especially under load. So, I upgraded...
Old 02-19-2012, 10:20 AM   #3565
.AJ.'s Avatar
Broke my front T-Bone today
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 02-19-2012, 12:09 PM   #3566
ambryatim's Avatar
^^^^How did you manage that???
Old 02-19-2012, 01:53 PM   #3567
ndi_guy's Avatar
Holy Crap. That must have been some hit to break one of those T-Bones.
Old 02-19-2012, 03:42 PM   #3568
cronmorg's Avatar
Default steering knuckles
yeah ambryatim i saw those the only question i have is where do you screww the the backing plates foe the pivot ball no bulkhead screws i have a message into the manufacture about it before i buy them. unless you guys know better let me know if you do
Old 02-19-2012, 04:09 PM   #3569
I just ordered a set for my new hyper, since they seemed to be a problem area... I use to have a revo 1/16 with integy steering knuckles which had plastic inserts that screwed in... (see picture below of the revo set with the plastic inserts).
It worked very well on the revo 1/16 and never broke, so I figured these were worth a shot
Hyper TT 4wd 1/10th Truggy Thread-unnamed.jpg
Old 02-19-2012, 04:36 PM   #3570
thanks for the help, I want to replace those hinge pin plates, they look like they've seen their share of bashing. I will also pick up those hub carriers. That's what I get for buying used but that's why I like buying used I get to work out kinks and learn my truck inside and out.
OFNA Hyper 10TT
OFNA TS4
RC18B
