Like Tree4Likes
Old 02-08-2012, 10:14 AM   #3541
cmace23's Avatar
Trader Rating: 26 (100%+)
I just bought a hyper tt with the following
1.Mamba max pro brushless system 5700kv motor
2.Hitec hs-985mg steering servo
3.carbon upper and lower trays,servo brace, and shock towers.
4.strc chassis braces f+r
5. cvd f+r
6.spectrum sr300 receiver
7.strc center diff holder
I dont know how well the 5700kv 2 pole motor will be on this truck but i plan to go the 550 route if that motor doesnt pan out. Also id like a faster servo any thoughts?
HOTBODIES D8Te | HOTBODIES D8e | HOTBODIES HHH VE8/SC | E-REVO BE | LCG SLASH 4X4 | HHH | TEKNO | CASTLE | THEHAWKPIT.COM
cmace23 is offline   Reply With Quote
Old 02-08-2012, 10:58 AM   #3542
mkiiina's Avatar
Trader Rating: 69 (100%+)
5. cvd f+r
Nice looking Hyper TT! Check out the hitec 7965 for a faster and more powerful servo. I run it in my and its pretty nice. The 5700 might actually be pretty good depending on the conditions you are running. I ran a Novak 550 5.5, EPIC 550 5.5, and currently a 1410 castle and all were good.
I still have the epic just laying around if you are interested.
mkiiina is offline   Reply With Quote
Old 02-08-2012, 11:46 AM   #3543
ambryatim's Avatar
Trader Rating: 18 (100%+)
cmace23..........
I would go with a SAVOX 1258TG good price and good performance. (That is what I am running)
And for the motor...I am using a Novak Ballastic 550 4.5T with my Speed Passion GT PRO ESC and a 15t pinion and all my temps are within 90*-110*F range.
The 5700 will probably do ok, but you will have to watch your temps.
ambryatim is offline   Reply With Quote
Old 02-10-2012, 09:27 AM   #3544
jaybird95's Avatar
Trader Rating: 14 (100%+)
Thumbs up
A friend of mine is running his with the 5700 and is alot faster than I am. He also runs a fan because it runs a little warmer. I run the 550 4.5 and its alot of torque for this little ride. I would run the 5700 and see how you like it.
SC10 4x4 / Tekin RX8 / XP1015 / Pro 4
RC8be / Tekin RX8 / XP1015 / Tekin 1900 Airtronics M11x
jaybird95 is offline   Reply With Quote
Old 02-11-2012, 10:26 PM   #3545
suparajicon's Avatar
I was planning to buy a Hyper 10TT,but just if I can use the electronics I previously had in my B44. What concers me is the motor,I have a Novak Ballistic 6,5T 540 size motor. But this car uses Mod 1 pinions right? Any possibility of using 64 pitch in this car? thanks!
Living in a banana republic
suparajicon is offline   Reply With Quote
Old 02-12-2012, 12:38 AM   #3546
.AJ.'s Avatar
Yea its mod 1, and 64dp is'nt a option and even if you could get a spur to fit, it would last a few seconds before it got stripped with such a fine tooth pitch
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 02-12-2012, 08:05 AM   #3547
ambryatim's Avatar
It comes with a 14t or 13t pinion for a 540 sized motor, Unless you are getting a used one. Just make sure they include it.
Originally Posted by suparajicon View Post
I was planning to buy a Hyper 10TT,but just if I can use the electronics I previously had in my B44. What concerns me is the motor,I have a Novak Ballistic 6,5T 540 size motor. But this car uses Mod 1 pinions right? Any possibility of using 64 pitch in this car? thanks!
And AJ is right it will be chiclets in a matter of minutes or days. Depending on how hard you drive.
Old 02-12-2012, 05:53 PM   #3548
Ricky165's Avatar
Does anyone know where to get yellow dish wheels for this car?
I was pointed towards the Losi 22T wheels, how do you think those will work? Any better options?
Ricky165 is offline   Reply With Quote
Old 02-17-2012, 12:42 AM   #3549
.AJ.'s Avatar
HPI do yellow dish rims which are the correct offset
Spektrum DX4R Pro
Old 02-17-2012, 02:38 AM   #3550
AUSSIEMIKE's Avatar
Smile
Originally Posted by turb06le240 View Post
OK, well I finished this up Monday, and took it up and down the street a little yesterday but the real test was today, I took it to the track with the kids and there t4.1's... I spent a pack getting it dialed a little, actually ended up moving a lot around, and suprisingly the shocks were pretty easy to setup and they are awesome... I went all day with out breaking anything, until walking to the truck holding it by the wing, I dropped it on its face and finished the front shock tower off....
I am only running a 3300 540 motor rite now, but its still peppy, the truck flies pretty level, and the turning is great, I can see the tire choice is going to be critical and I dont really like how the bod mounts on these things, but besides that the truck is a beast...
I would say besides doing a real good job with the diffs, the shock and steering upgrades made huge differences...
Hi mate.
Can u truely tell me that doing the diffs as u have will make them quiet and get rid of the typical TT drivetrain noise? I am doing mine now.
Also wat benefit is there by machining the area behind the drive cup as i see that as a little unimportant?
Would really appreciate ur response...
----Michael----
TLR22 / Dualsky XC800TF ESC / Dualsky 6.5 sensored;
Yokomo B-MAX4 II Factory Team 2011 / Dualsky XC850TF ESC / Dualsky 5.5 sensored;
TD DNX408 converted to E / Turnigy 1900KV / 160A Turnigy ESC;
Spectrum DSM2 Radio Equipment on all vehicles.
AUSSIEMIKE is offline   Reply With Quote
Old 02-17-2012, 03:06 AM   #3551
AUSSIEMIKE's Avatar
Hey guys, Im going to start the ultimate 10tt build, any ideas for hop ups, heres the ideas I have so far...
Starting with a Bump lightened chassis
-STRC-
Delrin spur
CNC Hex adapters
Graphite center upper plate
CNC stand offs
CNC front steering plate
CNC center diff bulkhead
CNC RR carriers
scrt10 bulkhead complete
-SNR-
Graphite servo plate
Graphite shock towers front and rear
Graphite lower plate
-Lunsford-
Titanium shock mounts
Front and rear turnbuckles
Servo to saver turnbuckle
Proline powerstroke shocks
AE long shock bushings
Elite RC motor mount
CVDs in the rear
SS screws
CNC Chassis braces front and rear
CNC Hinge plates all 4
Aluminum diff pins
DE skid plates
downforce black wing
Plus Im going to put bearings in the front steering, and install 6mm balls with screws through them on the front turnbuckle assemblies {also I'll use the entrie scrt bellcrank set up, I made bushing/spacers that fit in the bottom and lower the ackerman bar to clear the drive cup, it makes the front end silly smooth.
And I had to do a lot of playing around with the shocks to figure out the best way to build them for the tt, but the finished product turned out perfect and simple... {now I can do it in 20 minutes, but it costs a little over $100 to do it correctly...
The diffs, were easy, Ive done them a bunch of times, I coat the gaskets with indian head and double them up {the diffs are a little tight with one gasket when there new}, then I polish the thin washer that goes between the pin and oring, and fit the case with the drive cup by machining the rear face of the case {where the bearing sits} a small bit, kind of a touch and feel until its rite, taking off very small amounts at a time...and lastly I used 5000 weight in the rear and center and 1000 in the front... The diffs are super quiet and smooth...
Well, thats where I am so far, I got the shocks set up {tryed them on a friends tt for a weekend}, 3 brand new diffs built, and the steering done}, let me know if there is anything you can think of that I missed...
Hi mate
Can u go into more detail about exactly wat u do wen machining the rear of the case? Im a CNC machinist and cant fully understand wat this will achieve?
Are u talking about the outdrives or the main drive cup with the pinion gear?
This doesnt make sense. Please explain as im building my diffs like urs atm and i hope that drive train noise will be gone too? Especially after the effort?
----Michael----
Old 02-17-2012, 07:54 AM   #3552
Just spent the past few days reading all 237 pages. UPS drops off my 10tt today, putting in mmp and 1410 3800kv. Can't wait to try it on our backyard track.
bjs1785 is offline   Reply With Quote
Old 02-17-2012, 07:57 AM   #3553
macnkitty2002's Avatar
Hey guys,
Selling my 10TT. Check it out here!
Ofna Hyper 10TT ARTR: Upgrades, Castle, Hitec, Hyperion Lipo, spares, tires
Great deal considering everything you get. Well taken care of and upgraded extensively!
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-17-2012, 10:02 PM   #3554
Well, as expected my 10TT was in when I got home from work at 5pm. As soon as I walked in with it, I opened it and started to tear it apart, then boiled the parts for 45 minutes. I also did a quick paint job (I got the idea off of another member here who posted a picture in one of the pages.) I had the colors available and I'm happy with the results. MMP and 1410 3800 will be in on monday. Right now just a tacon and sidewinder to try it out.
So far Im very happy with this roller!! Cant wait to get it to the track...
Pictures are of...
1) Truck torn down an hour after I got it to boil parts
2) Back together, Quick paint job on body
3) Backyard track, video coming soon... check out bjs1785 on youtube to see the backyard track now...
Hyper TT 4wd 1/10th Truggy Thread-photo22.jpg   Hyper TT 4wd 1/10th Truggy Thread-photo.jpg   Hyper TT 4wd 1/10th Truggy Thread-track2.jpg
Old 02-17-2012, 10:07 PM   #3555
cmace23's Avatar
^^ That's a awesome backyard track!!!
