Like Tree4Likes
Old 12-30-2011, 06:30 AM   #3436
ambryatim's Avatar
Trader Rating: 18 (100%+)
I pieced my set up together....bought a used (almost new) Tekin SC4X 4.5 and a Speed Passion GT PRO v2.0 and it cost me $140 shipped for those two. Oh, I bought these 2 items from the for sale section here on RCTECH.
I am running 15T pinion and 2S and it is plenty fast. It temps at 135-140F on the motor and about 95F on the ESC and the battery is luke warm 80F maybe.
This is after about 15-20 minutes of running at my local indoor track.
ambryatim is offline   Reply With Quote
Old 12-31-2011, 05:01 PM   #3437
samlax77's Avatar
Trader Rating: 40 (100%+)
Originally Posted by .AJ. View Post
Quick picture update of my TT
How's the speed on that turnigy servo? looks decent.
Shake and Bake!
samlax77 is offline   Reply With Quote
Old 01-01-2012, 01:57 AM   #3438
Hey everyone,
Got my Hyper TT bump edition coming in the mail
Going to be running with
LRP SXX TC ESC
Hobbywing sensored 5.5t
CVDs in the rear
CNC upper stearing plate
Front and rear chassis braces
thicker steering achermann and a delrin spur gear
hitech metal gear servo
offroad and onroad wheels
Bought it 2nd hand barely driven on carpet only came with loads of spare parts shock towers, bulk housings, diffs and a standard brand new chassis
He chucked in a sanwa mx-3FHSS and 2x losi excelin 5200mah saddle packs aswell as a Ba6ac charger
Got the lot for $450 posted in australia, do you guys think this was a good deal? any recommendations for improvements on the car?
I am hoping it will be a good start for racing, I am new so don't flame too hard
Sehn is offline   Reply With Quote
Old 01-01-2012, 02:22 AM   #3439
.AJ.'s Avatar
Check this out
http://www.youtube.com/watch?v=zpyUkq44j9U
a very under rated servo
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 01-01-2012, 02:24 AM   #3440
.AJ.'s Avatar
does anyone else have this problem????
it happens alot with my TT
Spektrum DX4R Pro
Old 01-01-2012, 05:49 AM   #3441
I've had mine for a month now and haven't broke anything I did add a t-bones front bumper.I still have the plastic chassis braces and have not bent the driveshafts noseing in from 5+feet are you jumping houses?? maybe i've been lucky.
chris960 is offline   Reply With Quote
Old 01-01-2012, 05:53 AM   #3442
.AJ.'s Avatar
5ft? thats my problem then, nose dives at 12ft more like for me XD
Spektrum DX4R Pro
Old 01-01-2012, 06:10 AM   #3443
@ .AJ.
I had this problem with the 2 last motors I had.KD36 7T "L" size and Novak 4.5T 550.Try not to keep the throttle pressed when you land.
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 01-01-2012, 06:35 AM   #3444
.AJ.'s Avatar
Originally Posted by AL3xGR View Post
@ .AJ.
i cant see what difference that would make, i used to bend them when i was running a Castle 1410 as well, its just down to chassis flex
Spektrum DX4R Pro
Old 01-01-2012, 10:14 AM   #3445
mkiiina's Avatar
Trader Rating: 69 (100%+)
thats alot of chassis flex! especially when you have the upgraded braces.
sidenote: finally got to run my 1410 combo and its nuts how much power it has! i just to have to double, single ,single at my local track, now i can nail the double double (even overshoot it if im not careful) everytime.
mkiiina is offline   Reply With Quote
Old 01-01-2012, 11:28 AM   #3446
.AJ.'s Avatar
this should help with the chassis flex
Spektrum DX4R Pro
Old 01-01-2012, 03:01 PM   #3447
Of course the chassis flex is a factor,but also the shock and the stress caused when you land can be catastrophic.Try it,it really helps.
Phoenix ST
Old 01-04-2012, 01:49 AM   #3448
Hello people, I have my hyper10tt since February 2011, never managed to post his picture here.
Sorry for the English, I am Brazilian and not speak much ingles.Google translator is helping me a bit here.
I wonder if the hyper10tt you, you also noticed noise in the differential? My make much noise.
Mine is running with Velineon 3500.
thiago h.f. is offline   Reply With Quote
Old 01-04-2012, 06:26 AM   #3449
Trader Rating: 19 (100%+)
Holy COW!
I wonder if this is what i have wrong with mine. I am using the stock plastic yet. I noticed the upper arm holder brace in the front has a significant gap between the bottom of it and the steering post. Because it is plastic it moves, but i wanted to upgrade to the alum upper plate. I can see that being an issue and or causing the front diff housing to crack if i force it down. Right now i added 5x8 fiber washers and then 3x8 metal washers.
Your going to have a lot of drag in some surfaces with that hanging that low. Is there a way to use a turnbuckle off the front diff housing to the center diff brackets?
What kind of noise? The style of gears in this truck are known to be louder than other trucks.
muck is offline   Reply With Quote
Old 01-04-2012, 09:08 AM   #3450
It seems that the noise comes from the crown too ... I think it's normal.
Being mod1 think it makes more noise than the models with 48 pitch that i run.
