Like Tree4Likes
Old 07-08-2011, 07:53 AM   #3016
avva's Avatar
Originally Posted by mister_g View Post
Our class mandates stock shocks with open springs and oils. I'm currently running 30 front with blue cut 10sc springs and rear 25 with stock orange.
I run foam tyres so they contribute very little to soaking up bumps.
A 16 should give a good mix of accletation and speed.
Thanks. I am thinking of running this battery with it:
http://www.hobbyking.com/hobbyking/s...FApproved.html
would it work well?
"Now I get it, you have to drop a match in the engine before you start the car................
avva is offline   Reply With Quote
Old 07-08-2011, 08:19 AM   #3017
Trader Rating: 73 (100%+)
would it work well?
It will work fine. I run this one.
I have both and the 40c have better punch.
mister_g is offline   Reply With Quote
Old 07-08-2011, 09:12 AM   #3018
avva's Avatar
Thanks.
Old 07-08-2011, 08:40 PM   #3019
avva's Avatar
Will a 13T work with a 3800kv because ofna includes a 13t with the 80% assembled no electronics kit. sorry for asking so many questions......im kinda new to hobby rc cars in general. ive really only used rtrs so far and that doesnt require that u know anything about rc cars.
Old 07-08-2011, 08:43 PM   #3020
avva's Avatar
Originally Posted by FangsCPO View Post
I would recommend you switch out the ESC for a Castle MMPro. Alot of guys that I race with are using that combo with great success. Just make sure the motor is the 4 Pole Motor.
can i use a 120A hobbywing (xerun/ezrun) 1/10 esc? cause the the mmpro is somewhat $$$.
Old 07-09-2011, 12:15 AM   #3021
dumbcomputers's Avatar
Joining the 10TT family
Picked a 10TT up last week. Spent most of the week trying to figure out where to mount the ESC. This is what I eventually ended up with, which I'm really happy with.
dumbcomputers is offline   Reply With Quote
Old 07-09-2011, 12:24 AM   #3022
avva's Avatar
-dumbcomputers
what kv motor?
Old 07-09-2011, 12:29 AM   #3023
-dumbcomputers
what kv motor?
Castle 1410 4-pole 3800kv I had from a previous car.
- Ten-Te
- Hyper 10TT
Old 07-09-2011, 06:21 PM   #3024
13 will be a tad slow. Give it a try you have nothing to lose. A new pinion is only $10 should it not work.
Yes you can.
Old 07-09-2011, 10:20 PM   #3025
Question #1 (Mister G posted previously)
Here is a start - these are the most commonly broken parts i see during racing.
** Front knuckles
** Rear hubs - don't waste time with plastic get alloy ones.
** steering top plate - don't waste time with plastic get an alloy one.
** Front arms.
** Front hinge pins and bushes
** Front hinge pin holders (front and back)
Question #2 - The Castle MMPro and 3800 kv 1406 Motor (4 pole) - Check E-Bay price are way better than any where else.
Question #3 - Don't know, once again, if you are on a budget, keep what you've got for now.
Question #4 - I'm using a Futaba BLS451 - other options out there I'm sure.
Question #5 - If you are on a budget, than stick with the lid you have.
Good Luck!!
Given I've been quoted on the spares needed, ill answer a few other questions
As suggested The Castle MMPro and 3800 kv 1406 Motor (4 pole). Run it on a 16 pinion and it will be quick and run very cool - highly recommended!!
Ofna Hi-Down Force Wing part# 40906 to 40909 (4 colors) http://www.ofna.com/body-wings.php
I have been using one of theese - http://www.hobbyking.com/hobbyking/s...idProduct=8771
Its been going strong since a week after the TTs were released. It has seen 2 seasons of racing and at least 1 hour of practice a week. Value for less than $20
Associated t4 shells from proline and J Concepts, fit well if cut correctly - search this thread...
Cheers Matt
ok greak thanks... why dont they sell MMP with a 3800KV combo??
also i see people running slash rear tires looks nice but seems to look more like the tires are in more closer to the body.. is there a off set hex 12mm adaptor they sell that will fit? make it bit wider out...
thanks ill be ordering my parts soon..
ohhhwee is offline   Reply With Quote
Old 07-10-2011, 04:37 AM   #3026
RatsacK's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to RatsacK
Well, mine should turn up any day this week. So excited!
But, I've only currently got a eZRun 60A ESC and I read just a page back that people were having thermal issues I guess I need a 120A I will be using a Velineon motor (3500KV) so I think the motor should be fine.
Anyone running a 60A ESC without issue? Should I be fine to run it for a week or 2 until a new ESC arrives?
Team C 2WD SCT
Axial SCX10 Honcho
LRP S10 Drifter
Spektrum DX3C
RatsacK is offline   Reply With Quote
Old 07-10-2011, 07:35 AM   #3027
avva's Avatar
Yes you can.
thanks.
Old 07-10-2011, 02:18 PM   #3028
Pkal's Avatar
Guys, any suggestions on a 3s pack to use with a MMP/3800kv? I'm looking at the Turnigy Nano-Tech 5000mah 3S 35~70C Lipo Pack (Dimensions: 150x49x26mm) but I'm not sure if it will fit (may be a couple of mm too long)?
http://www.hobbyking.com/hobbyking/s...dProduct=17253
Pkal is offline   Reply With Quote
Old 07-10-2011, 02:58 PM   #3029
LDOstrem's Avatar
You can run it with the 60 but I wouldnt do any serious bashing with it. An 1/8 scale track might even be to much. I blew two 60A esc's before I got the point and bought a 100A. Now it only heats up when Im doing speed runs and such with buds, but still pretty cool considering. Maybe set the timing and such low on your 60a, that may help.
Why doesnt anyone makeing desert buggy cage/body's or do I have to fab my own :/
LDOstrem is offline   Reply With Quote
Old 07-10-2011, 10:00 PM   #3030
FangsCPO's Avatar
Actually the Slash 4X4 Tires/Wheels are perfect since the off-set puts them right where the Stock Hyper 10TT tire/wheels would be.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
