Like Tree4Likes
Old 06-11-2011, 03:20 PM   #2926
I just got a Hyper 10TT yesterday ay my LHS. I have a small track in my backyard that I made to run my Slash 4X4 on. The Slash is the only RC car i've driven and it jumps really well, level every time. The Hyper wants to nose dive almost every time I jump with it. Can anyone give some advise on what to do to the truck to make it jump more level?
Losi Ten SCTE
Jammin SCRT
Slash 4X4
mxr300ex is offline   Reply With Quote
Old 06-12-2011, 12:59 AM   #2927
Pulse_'s Avatar
What tires do you use on the Hyper TT for:
- racing on clay?
- bashing?
- racing on astro turf?
Does it need any upgrade?
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 06-12-2011, 09:09 AM   #2928
RCaddict0's Avatar
Trader Rating: 85 (99%+)
Send a message via AIM to RCaddict0
- racing on clay?
- bashing?
I run 2.8 PL trenchers bashin in the neighborhood, I havent raced it yet, but the stocks feel like they hook up ok in dirt. No upgrades yet! Trucks tuff!
E Maxx Brushless ~ Rustler VXL ~ Rally VXL 1/16
Ruckus Brushless ~ Stampede VXL
* Hobbywing Powered *
RCaddict0 is offline   Reply With Quote
Old 06-12-2011, 09:26 AM   #2929
LDOstrem's Avatar
Keep on the gas a bit after takeoff. If anyone has managed to get their TT to fly level on every jump you'd have to copy every aspect of their setup down to exact battery weight, engine setup ect. Just learn to drive what youve got, takes practice.
Why doesnt anyone makeing desert buggy cage/body's or do I have to fab my own :/
LDOstrem is offline   Reply With Quote
Old 06-12-2011, 01:51 PM   #2930
Pkal's Avatar
You could try CML Distribution (cmldistribution.co.uk) as they maybe able to help you.
Does any one know where is the place in Europe I can find it for the best price?
Pkal is offline   Reply With Quote
Old 06-12-2011, 10:00 PM   #2931
FangsCPO's Avatar
That's a common issue with this rig, I solved it by installing a Tekin SC4x 4.5T. The additional weight balanced it out better for me. I recommend if you are running a 540 can, make sure your battery tray is toward the rear and your battery sits in the battery hold pushed towards the back. That should balance out things for you.
Also, learn to tap on the throttle just enought to get the nose up when hitting jumps.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 06-13-2011, 05:57 PM   #2932
Trader Rating: 73 (100%+)
For all you guys asking about diff oil, download this document and read the diff section. Actually worth reading the whole lot its very interesting!
Tons of info - the document gives a lot of insight on how changes will affect your car.
http://www.teamxray.com/teamxray/sho...p?file_id=4461
Cheers Matt
mister_g is offline   Reply With Quote
Old 06-14-2011, 07:25 AM   #2933
goatsblood666's Avatar
Just got my Hyper 10tt last week, body has been painted, diff fluid switched, threadlock on some parts... Novak 550 system arriving this week, as long as a savox servo...I can't wit to get this bad boy up and Runnung!!!! Pics to come...
goatsblood666 is offline   Reply With Quote
Old 06-16-2011, 08:55 AM   #2934
FangsCPO's Avatar
Congrats on your purchase. This rig is alot of fun.
TLR Team Driver
Old 06-16-2011, 11:38 AM   #2935
I will also post some pics of mine.I have a Novak 550 too.(Hyper Mini STe to Hyper 10TT conversion!!!)
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 06-16-2011, 01:30 PM   #2936
antonio_cadiz's Avatar
Is this CNC Aluminum Steering Bellcrank for Jammin SCRT10 good or is it needed do any transform? for Hyper 10tt
http://www.nitrohouse.com/Car-Hop-Up...duct_info.html
thanks
antonio_cadiz is offline   Reply With Quote
Old 06-17-2011, 02:30 AM   #2937
Thumbs up
its works good i have it on my tt
hoebag is offline   Reply With Quote
Old 06-17-2011, 11:11 AM   #2938
Pkal's Avatar
Finally switched to a MMP (from the Sidewinder SCT) with the SCT 3800kv motor and it's a great combo. I've filled the diffs with 5-7-2 and it's geared at 18/42 (for bashing) and it's so smooth. I love this truck, can't wait to try it on 3S.
Out of interest, has any one switched out the standard shocks to something else, not that they need replacing?
Old 06-17-2011, 11:38 AM   #2939
RCaddict0's Avatar
Im really disapointed in my Favorite RC now. The center diff has been leaking like crazy since I got it. Its been leaking since preassembled by the factory. Ive tried to rebuild it 10 freakin times! I finally broke down and ordered a new housing and gasket. Well Im waiting fot it I managed to get the leaking to a minmum and was running it and dont ask me how But the hinge pin at the top left a arm just fell out! The pin and bushings all just fell out somewhere somehow. I was just runnin in the yard a noticed the wheel was wobbling. Nothing loose. broke or stripped. Completely confused and angry now as its gonna cost me like $15-$20 now for a whole new hp set and bushings! Anyone dealing with either of this?
Old 06-17-2011, 12:30 PM   #2940
LDOstrem's Avatar
Ive had all of that happen shortly after getting it. Take a close look at your front upper plate(assuming its still the plastic one) its most likely cracked or broken, thats why you lost your hinge pin. Get an aluminum one from Nitrohouse or other site. When you get that new housing and gasket dont overtighten them, and Id suggest using a sealant. I used an automotive pcv gasket sealant, you dont need a lot. You may be able to get a sample of it for free at the autoparts store. And im pretty sure you bent an axle. I actually snapped a couple right where the pin goes through. Youll prob also break your wing mount, front hub carriers and rear chassis brace. Good times all around!!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
