Hyper TT 4wd 1/10th Truggy Thread
#2836
No,this is wrong.If you have a higher C rating(more amp capability),the voltage will go down more difficult and the battery will be cooler(and maybe have a little more punch and runtime).With higher C rating it'll be more difficult to hit the cut-off limit.
#2838
Hi i recently buy a Hyper TT RTR but i buy to the combo ESC and motor castle 6900, i use the pinon 14T evething is ok but now the trouble is when i have 5min of runtime the stop and the light in the esc was red and yellow , what is that overheat ??? what pinon i have to use ???
#2839
Whay pinion i have top use with a hyper TT RTR with castle CCreation Sidewinder v2 and 6900 motor ?? thx for help new in electric cars
#2840
I take it your using 2s? I would start with a 10 or 11, I run a ballitic 6.5 with an 11 and thats only 6400kv... your much better off with a 4600 4 pole... that 6900 is going to be tough..
#2841
Thx for the advise yes 2S i will try a a 3800kv
#2842
#2843
other question can i use 25c Lipo batt 2s with my sidewinder V2 and 3800kv i will have a good performance ???
#2844
Do you race or bash? For bashing you will have a ball with it, if you race it all depends on the rest of the field, its definitely enough power to move the truck around quickly. a friend of mine runs the 4 pole 4600 on 2s and its a rocket ship, Ive seen him launch 6ft off of a jump that my x12 powered t4.1 only gets 3-4 feet off of.. another member on here {mitchell} has some pics of his 3800 tt ballooning his tires to double there size in the dirt, with the same exact esc you have...
#2845
Is for club racing
#2846
Then thats going to depend on your track size and setup, Im going to say your probably better off with the 3800... Also check out the tacons
http://www.hobbypartz.com/96m210-3660-4000kv-6t.html
http://www.hobbypartz.com/96m211-3660-3500kv-7t.html
Depending on your tracks size, turns and traction.. I have used both of them above motors, there a little longer but awesome especially for the price!!! Buy one of each and see how you like them...
If you oder from hobbypartz.com use coupon code "Hobbymodel" and get 5% off.. Good luck...
PS you will need 5mm pinions for them motors, there the same size as a 540 except longer with a bigger shaft...
#2847
Wow!! These Hyper TTs are really starting to draw some attention in San Diego. Quite a few guys have gotten them or are in the process of getting one.
There's even a class for them at SDRC Raceway, San Diego's new indoor off-road track. Oh yeah!!!
#2848
Kyosho Quick connect on my rear wheels
#2849
Nice motor. Is that the mew zero turn?
#2850
