Hyper TT 4wd 1/10th Truggy Thread
#2791
#2792
Here she is some new Trencher 2.8's! For BaShIn there great. I wanna ask you guys a ?. I was running the SCT 3800 in the truck on 3s until I got my new wheels. I figured it might be a bit much on the motor with these and 3s. So I installed a Novak 7.5 HV. I picked up a 15t pinion and it seemed to run well. Motor wasnt eben breaking a sweet in the 1/10 on 3s. But 10 mins into the run my new pinion fell off! And ofcourse I couldnt find it for the life of me. Well I had to make a 70 mile round trip to get it. I dont have $25 for another pinion and gas. The only other place I know that has a mod 1 pinion is a toy store/ hobby shop down town. Its 19t thou. Do you guys think 19/45 would be to much? I mean the 7.5 HV is intended for the E Maxx on 4s. So Im wondering if it could handle that high of gearing on 3s in the Hyper.http://
http://
http://
#2793
I ran my TT this weekend with RX8/SCX4 5.5 combo, and couldn't be happier, started with a stock esc set up and 12 tooth pinion, and was very dissapointed, but after reading and playing with pinions, ended up with a 17tooth and custom esc profile that rocks!! Ran in on a big outdoor track with the 4wd SC and had a blast !!
#2794
I'm running mine with a SC4x 4.5T and MMPro. I just couldn't get a good fit with the RX8. The MMPro is so small, that I just mounted it ontop of the center diff plate. Works for me. I'm geared at 14/42 running on 2S and she flies. It does seem like the front tires are lifting up slightlly....any recommendations to make it be more planted?
It took me a while to stop wheel spin with the balllistic 6.5 and then when I did I had the front lifting because of the rear traction and the fronts would balloon, so then I figured add weight to the front, this made it nose dive off the jumps.. So I scratched that, but after a few packs of adjusting the springs, shock and diff fluids as well as ride height I got it perfect... Thats most of the fun...
#2796
HEEEEELP....
Where can I find shims for the suspesion arms and also some pivot ball cups?(like these: http://www.amainhobbies.com/product_...e-EMXTMX1525-4 - there is too much play with the stock ones...)Or some conical shims?
The shims for the arms will eliminate the play they have.
Please help.
Please help.
#2797
Looking forward to hear about the Viper stuff in your truck. I've got a 10 and a 10R on it's way. Need to pick up a mod motor with more grunt though. I've only got the 17 & 13.5.
#2799
Well, Im currently running a MMP and Novak HV 7.5t (3000kv) on 3s geared 18/42. Things pretty darn fast, but I need to gear down a bit. It ran at 105 motor and 110 on the ESC. Im not shure about this gearing. It was chilly yesterday and I think that helped out on the ttemps a good bit. Ignore my above gearing questions. I thought the stock spur was 45t and the only Mod 1 gear that was locally available to me was 19. But I'll see the temps when ever it warms up and quits raining here. Sucks! Its been raining pretty much daily for a month now! I ordered another 15t pinion to change it back out if the temps get to high.
I also have to say that the Hyper is a really fun RC! Im mainly bashin right now. But I cant seem to leave the hyper inside. Things a blast! Handles like a buggy, but takes on the dirt like a truck! I need to ask.... I dont really have parts readily available to me. I like to have back up parts. Expescially with summer around the corner. I'll be out there every day beating my rigs. And parts I should stock up on?
And what weight shock oil and diff oil are you guys using. Like above Im knoticing my front wheels wont stay planted on the ground. I wanna fix this.
#2800
As far as fluids, Im always changing around, rite now Im 2K rear 2K center 5k front shocks are 30/30 but like I said I run powerstrokes... A few of the guys up here run the blue losi springs, 35 rear 30 front with the rear ofna option pistons...
#2801
Here's my rig....I hope the pictures work.
#2802
Just had a guy contact me about trading my Slash 4x4 for one of these...figure this would be a good place to get some insight on them.
How well do they hold up and are they fun to drive? I haven't seen any 4wd 10th scale truggies at my local track, but they run a lot of open/mod classes so I could probably run it with the 4x4 buggies or short course trucks if I got one.
Also, is there a 17mm conversion for this to run 1/8th scale wheels/tires?
#2803
#2804
That's true, this Slash is only 2 weeks old so I may just hold off and see if it sells. I may end up just trading him rollers if I did would a VXL system power one of these until I had the money to upgrade to something bigger? It seems like you guys are running some low turn/big motors in them.
#2805
