Like Tree4Likes
Old 05-02-2011, 05:33 AM   #2731
Toiffel's Avatar
Trader Rating: 52 (100%+)
I ran my TT this weekend with RX8/SCX4 5.5 combo, and couldn't be happier, started with a stock esc set up and 12 tooth pinion, and was very dissapointed, but after reading and playing with pinions, ended up with a 17tooth and custom esc profile that rocks!! Ran in on a big outdoor track with the 4wd SC and had a blast !!
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 05-02-2011, 05:51 AM   #2732
Trader Rating: 31 (100%+)
Send a message via Skype™ to vstrok
Read somewhere about boiling some components to make more durable. I don't feel like reading through 1000's of pages to find again. Can anyone tell me what the most important parts to do this to are? And how long to boil for?
VS
Ofna GTP2e - Tekin RX8 / Tekin 2250 kv
Ofna Hyper 10SC - MM Pro / Castle 6900 kv
Ofna Hyper 10TT - MM Pro / Tekin SC4X 5.5T
vstrok is offline   Reply With Quote
Old 05-02-2011, 05:53 AM   #2733
Trader Rating: 14 (94%+)
Originally Posted by AL3xGR View Post
Also after swapping from a KD36 7L motor to the Novak 4.5T 550 my temps were of course lower but runtime and top speed also reduced.Runtime from 25min to 12min(but went from 3s to 2s...) and top speed is about the same when I use 26/42 gearing.(from 17/42) But I like acceleration - I will increase timing one level in order to increase rpm - I don't have any problem if the torque goes down a bit.
Any ideas about how can I increase on-power steering? Maybe the front diff from 3k oil should go to 7k?
Depends what you have in the rear, I run 5000 front 2000 rear and center, camber -2 deg. and 1 deg. toe out.
My old track had 3 crazy turns one of which was at the end of a long down hill straight , and I was running 1000 rear 5000 front with good results... My friend runs 2000 rear and vasaline in the front he races well too... Its suck a pain to change the fluids I like the 2K 5K combo for all around racing...
10TT RSPro/6.5 ballistic proline shox, All CF & Alloy, B44.1 RSPro/7.5x12, FT t4.1 RSPro/8.5 X12 Octa, RC8te CE MMM/2200, RC8be RX8/1900, All have DS1015s. I Also Have 3 planes, 4 Helis, 2 boats , a Ton of cars, & 2 Tamiya tractors in boxes{someday Ill build'em} The kids have matching sv2/1406 4600 powered T4.1's & MMM powered LX1e buggies
turb06le240 is offline   Reply With Quote
Old 05-02-2011, 06:03 AM   #2734
tedstryker's Avatar
Trader Rating: 74 (100%+)
VS
front knuckles boil them for 20 min...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 05-02-2011, 06:06 AM   #2735
Camber -1deg,0 deg toe(maybe it should be -1deg)
3k front oil,locked center diff(50%power front,50% rear),3k rear oil
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 05-02-2011, 10:23 AM   #2736
Slash65's Avatar
What is the advantage of running a lighter oil in the center diff? I was going to put 5k in the center according to the setup on NitroHouse. What does running the lighter weight offer?
HoBao Hyper 10 TT
Sanwa MX-V
HobbyWing XeRun V2.1
Dynamite 6.5T
Slash65 is offline   Reply With Quote
Old 05-02-2011, 12:04 PM   #2737
I guess you need to really run what your track calls for, the more traction you have the heavier fluid in the center, if you have a smooth, low dust, high traction track, then you want 7-10K.. High traction low dust but bumpy 5K, dusty bumpy 2K.. Our track is low traction, I run 2K...
Running 2K, my front tires lift a little reducing traction making the fronts spin, which makes acceleration a lot smoother...
\The center is the easiest to change so its good to try a few different weights..
Old 05-02-2011, 05:16 PM   #2738
tedstryker's Avatar
question for guys who are running the rear strc hubs...how long have you been running them?...are they resulting in breakin the rear arms?
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 05-02-2011, 05:22 PM   #2739
Ive ran them on both tt and sc and never had an issue breaking rear arms, Ive broken a rear arm but I dont think the stock hub would have helped it...
Old 05-02-2011, 05:32 PM   #2740
tedstryker's Avatar
thnx man....
need some more input on this.....thinking about buying them
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 05-02-2011, 08:22 PM   #2741
pword's Avatar
Trader Rating: 25 (100%+)
Originally Posted by tedstryker View Post
thnx man....
ted, i've been running it for a while now and it's worth the money and hasn't caused to break the rear arm. you saw me how i beat my tt at the track today. tbone bumpers are great to have as well.
Nemo Racing USA | Agama | Bullitt | Beta | Critters | 46RC | Trains and Lanes
pword is offline   Reply With Quote
Old 05-02-2011, 08:35 PM   #2742
this is my project of TT
14.8v + novak 550 9.5t(2250kv) + RX8 + kyosho Qc + CVD's
any comments?
Kyosho RT5, kyosho SC-R, Kyosho Mad force VE 8s, Tekno Sct410,
TMM-25063 x2 Pro & Neu 2230-12 (On the way)
pirape is offline   Reply With Quote
Old 05-02-2011, 09:41 PM   #2743
Huntweiss's Avatar
I am thinking of getting this. What is the best gearing for 2s sidewinder sct 3800kv system? Is a traxxas servo enough power?
Losi Ten-SCTE-
Mamba Max Pro, 4 pole 3800, Aluminum Shock towers, Bar codes, Calibers, JR Sport Servo
Huntweiss is offline   Reply With Quote
Old 05-02-2011, 10:05 PM   #2744
Enough power, yes. Enough speed, no.
Old 05-03-2011, 07:02 AM   #2745
mattb83's Avatar
i boiled every plastic part on mine for 30min and i beat the crap outa this lil truck and i have yet to break anything and i drive it pretty much every day, mind u its never seen pavement and never will. oh ya and the t-bone bumper is the sh*T
mattb83 is offline   Reply With Quote
