Like Tree9Likes
Old 04-20-2011, 12:59 PM   #2671
-R2-'s Avatar
I love the TT nation, good looking cars guys.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 04-20-2011, 02:39 PM   #2672
Trader Rating: 31 (100%+)
Send a message via Skype™ to vstrok
Where/how is everyone mounting there MMP? I don't like how it sits so high and pushes up on the body..
Ofna GTP2e - Tekin RX8 / Tekin 2250 kv
Ofna Hyper 10SC - MM Pro / Castle 6900 kv
Ofna Hyper 10TT - MM Pro / Tekin SC4X 5.5T
vstrok is offline   Reply With Quote
Old 04-20-2011, 03:18 PM   #2673
utah300rum's Avatar
Trader Rating: 27 (100%+)
I mounted my esc on top of the servo....I made a small plate out of lexan and screwed it to the extra holes in the top of the Servo mounts...this allowed me to move the ESC slightly closer to the center of the truck, making sure the servo arm did not hit the ESC......then secured the ESC to the lexan plate.
I think some guys just tape it right to the top of the servo but I was worried about it hitting the Servo arm...then if you slid it over there was not much surface contact so I was nervous to use servo tape.
I made my plate wide enough that the ESC has lots of contact area for the tape and I used a zip ties around ESC & plate to make sure it wont come loose.
Spooky's Racing for Asphalt & Carpet, Blacksheep Raceway for off-road, Utah Mountains for bashing!
utah300rum is offline   Reply With Quote
Old 04-20-2011, 05:22 PM   #2674
Trader Rating: 14 (94%+)
Pics? I was going to custom machine a piece of carbon fiber to hold the esc from the servo plate to the battery box...
utah300rum, is that for .300 rem ultra mag? I have a SS model 700 that I did some work to in 300rum, Ive blown up my share of water jugs at 400 yards
10TT RSPro/6.5 ballistic proline shox, All CF & Alloy, B44.1 RSPro/7.5x12, FT t4.1 RSPro/8.5 X12 Octa, RC8te CE MMM/2200, RC8be RX8/1900, All have DS1015s. I Also Have 3 planes, 4 Helis, 2 boats , a Ton of cars, & 2 Tamiya tractors in boxes{someday Ill build'em} The kids have matching sv2/1406 4600 powered T4.1's & MMM powered LX1e buggies
turb06le240 is offline   Reply With Quote
Old 04-20-2011, 08:47 PM   #2675
RCaddict0's Avatar
Trader Rating: 85 (99%+)
Send a message via AIM to RCaddict0
Default Few more things
What springs are everyone using. I have the stock on mine, but would prefer them a tad stiffer. Any suggestions? Im just bashing. And with the advanced tech. to quieting my diffs... That sounds a bit complicated and a hell of alot of work. Anything simpler I can do just to quiet it up ? Even a little/
E Maxx Brushless ~ Rustler VXL ~ Rally VXL 1/16
Ruckus Brushless ~ Stampede VXL
* Hobbywing Powered *
RCaddict0 is offline   Reply With Quote
Old 04-20-2011, 08:58 PM   #2676
Blue rear losi and blk front losi
Hyper 10SC
Team Terribles, Mike's Hobby Shop Carrolton Tx.
Up and coming factory team driver
slowslug is offline   Reply With Quote
Old 04-21-2011, 01:27 AM   #2677
Yosh70's Avatar
Trader Rating: 17 (100%+)
Dont know about the diffs but the springs alot of people are running are the Hyper 10SC blue springs.....including myself.
TLR 8T 1.5, AE SC10, TLR 22SCT
Yosh70 is offline   Reply With Quote
Old 04-21-2011, 06:13 AM   #2678
RCaddict0's Avatar
Yea, I knoticed everone has blue springs on there Hypers. I just got mine lightly used and it has stock orange ones. Thanks!
And I dont have muck experiance with 1/8s or trucks built like this. Ive always owned Traxxas, AE, HPI 1/10's. Is that noise normal? Is it becouse of all the metal gears? My old MRC ZD 1/8 buggy was load as he!! to.
Old 04-21-2011, 12:32 PM   #2679
Yosh70's Avatar
If you're up to it, it wouldn't be a bad idea to go thru the diffs since it is a used RC. Clean and fill with fresh oil and try it then. Check the spur and pinion gears/mesh as well.
We took ours down to the church parking lot for its trial run and its doesnt seem noisy at all esp. compared to my Ofna buggy.
Old 04-22-2011, 05:38 AM   #2680
Could someone measure the max width of the body?(it's for my mini ste conversion...)
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 04-22-2011, 05:58 AM   #2681
There is an ebay auction with a bunch of parts, and almost everything needed for the conversion, just need a body and wheels, which is also offered
But anyway, the body is around 5 1/2 inches wide from side to side (139.7mm)
link to auction http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_682wt_1139
Old 04-22-2011, 06:15 AM   #2682
Thanks.Actually I'm designing my own chassis(with some mods).Also,the suspension arms are the same in size,right?
Phoenix ST
Old 04-22-2011, 06:33 AM   #2683
Yes same size arms..
Old 04-22-2011, 07:45 AM   #2684
OK.
Phoenix ST
Old 04-22-2011, 03:45 PM   #2685
Id like to see the chassis when you are done...
I seen a 10tt with a carbon fiber chassis {3.5mm flat plate and they used an aluminum wedge to get the angle for the front gearbox} but they used a complete middle diff from a B44 with the b44 motor mount, so they had a slipper, it seemed to work very well...
