Hyper TT 4wd 1/10th Truggy Thread
#2506
If anyone in here runs on carpet, what tires are you using? The stock ones have to much side bite causing it to traction roll to much! Also the stock ones dont last to long on our track!
#2507
#2508
#2509
Best of both worlds
Hay I have a hyper tt just wondering if any one has tried to convert the tt to hyper sc it does not look to hard. I know the chassis is a little different but I can't git the measurements don't know if it is the same length. The only thing I do know is the shock tower is a little taller every els looks like it will boult right on.Any help would be appreciated thanks.
#2510
#2511
Went to order a savox 1258 and they are out of stock. Would the 1257 be enough for the TT? It is 133 oz and .07 on the speed.
Chad
Indy
Chad
Indy
#2512
Those specs are perfect IMO for this truggy.
#2514
#2515
Chad
#2516
duratrax.com/tires/1-10truck.html
Chad
Indy
#2518
Hey can the guys running the 540 5700kv motors tell me what you are running on your pinions? I have a 550 5750kv on a 11 tooth pinion and it's quick, but runs cool to the touch. Stripped the rims hexes on the factory wheels the other day and threw on some old school stampeed tires I had lying around. These are huge and heavy and it rides whellies down the road now on 2s, kinda like it did on the factories with 3s. The motor is warm now, but I can leave my hand on it as long as I want so it's not hot. What you guys think I should run with factory siZed tires?
Also like the ride hight and looks like this what you think it would do with 1/8 truggy tires?
#2519
12 or stock 13
#2520
