Hyper TT 4wd 1/10th Truggy Thread
#2491
Time to get the ruler out again I guess. As far as ride height I had drop both the front and rear as low as they go to get both front and rear a arms level with everything loaded up. After dropping the truck it seems to level out perfect. Are even f and r arms the way to go on this thing?
#2492
Will slash rear offset wheels work???
#2498
The thing also like a washer or so under the outer ball on the steering link.
#2500
I'm trying to get more off power steering out of my tt. Running 3-5-1 in the diffs front to rear, 35wt Losi Oil in all 4 shocks, stock orange springs around, upgraded ackerman bar, still no where near enough off power steering. Can't dial in any more drag brake as I lose too much time in the air adjusting attitude, got it with just the right nose down now. Any ideas how to get more off power steering? On power is good, just so little travel on the steering.
#2501
raise the rear......
#2502
Sorry, forgot to mention I did that already! Moved the rear shocks into the upper holes on the tower but still have the ride height 2mm higher in the rear. Can anyone save me some time and tell me how many holes are in the stock shock pistons? Cant remember......
#2504
I will give you guys a little set-up help...I went thru all the same things as posted to get it to turn in....
The main problem with these is the lack of front weight, and weight transfer. To fix this, lay the battery down, and re drill all the holes so its nearly touching the front steering post. Mine almost touches it. Now grind the front diff case for max turning radius. I also run a custom V-shaped steering link for more ackerman, but I don't have too many extras, but the rest I posted should help a ton
For the shocks, drill the rears out to .048" in all four holes and put 40wt oil in them. For the fronts drill two holes to .048 and two to .062" and put 50wt oil in them.
The sway bar is needed, but the stock .080" one is too stiff. Get some .060" wire and bend a lighter one and install it straight up on the links...Truggy will now drive as good as gets. All the other set-up options on these squirrley little trucks really doesn't do enough to help gain the kind of racing feel they need at the speeds they go.
Oooh and my diff fluid currently is 5/7/2, but going to grease in all of them soon because I am tired of replacing oil. I have not driven a better handling one than mine, so I would go this rout if your serious about racing. Mine has spent some time on the scales and gone thru a bunch of changes, but this works.
#2505
ive driven this truck 2 race days only so far at 2 different tracks 35 wt shock oil front & rear 551 diffs box stock set up truck works qualified second first race outta 10 second race diff track same set up tqed these trucks work outta the box........
