Hyper TT 4wd 1/10th Truggy Thread >
Like Tree48Likes
Old 03-04-2011, 03:02 PM
  #2386
Yosh70's Avatar
Trader Rating: 17 (100%+)
Originally Posted by bagged69chevy
Well..
I got my TT yesterday.. Spend an hour or two getting it running.. Decided to take it into the front yard and take it up and down the block a few times..
So i decided to come down the street full speed, up my drive way, onto the lawn, (this is tall fluffy lawn, not golf course lawn).
Well when it hit the edge of the lawn it flipped up into the air and landed on its lid. (Mind you i didn't have the body or the wing on)
so i turned the truck over, and the shock tower was bent to hell, the rear chassis brace broken, and my rear center drive shaft was bent. Pretty sweet first outing.
Cant wait to hear about the second outing.....should be even sweeter.
I have to say tho, if you're going 35-40 mph and hit the edge of a lawn enough to send the car flying thru the air, it was obviously a RAISED edge. I cant see any RC going thru that unscathed.
Yosh70 is offline
Old 03-04-2011, 03:05 PM
  #2387
Yosh70's Avatar
Originally Posted by utah300rum
I went to the track the the day with the TT......I was nervous since everyone says how fragile they are......going down the back straight clipped the pipe and WHAM into a railroad tie!
BUT.....the TT took it like a champ......off I go again after a few laps I decided to get brave and try to triple the jumps.......cased the top of the thrid and flipped high into the air, end over end, over end over end down the track it goes for about 20 feet
Walked over and flipped it back on his wheels and off he went
So far the little guy took 2 pretty rough hits......100% stock 10TT just boiled all the arms, carrier and knuckles.
I dont think this little guy is the toughest out there by any means....but I dont think they are made of glass like a few guys make them out to be either.
I've read about boiling the suspension parts before, sounds like a good idea.
I have also ordered T-Bone Racing's front and rear bumpers.....with a 9 yr old driving it, you can never have enough protection.
Yosh70 is offline
Old 03-04-2011, 03:14 PM
  #2388
scooterman19's Avatar
Default ok
OK Im confused lol...went to nitrorcx and found two hobbywing EZrun systems and one is a 5.5 turn@6000kv and the other is [email protected] thought that the lower the turn the lower the KV???? they both have a great price but dont know what one to go with....knowledge needed Helpppp
scooterman19 is offline
Old 03-05-2011, 03:15 AM
  #2389
The lower the turns the higher the kv, smaller turn means faster.
hoousi is offline
Old 03-05-2011, 06:38 AM
  #2390
jaybird95's Avatar
Trader Rating: 14 (100%+)
Post
Originally Posted by ndi_guy
I don't think anyone is having a problem with these things jumping nose up.
My TT would jump nose up all the time. I tried a little design change and moved the battery tray up 1". This thing now jumps perfect and I gained a ton of steering.
jaybird95 is offline
Old 03-05-2011, 12:57 PM
  #2391
Trader Rating: 41 (100%+)
What up peeps? I just bought me a used Hyper TT and was wondering is there anymore set-up sheets on this truggy other than the one on Nitrohouse? Thanks,
Are the blue springs softer/harder than the orange kit springs?
rifraf is offline
Old 03-05-2011, 01:09 PM
  #2392
pword's Avatar
Trader Rating: 30 (100%+)
Go check BBQ's setup in post #2002. followed it and ran it last night and truck runs, turns and jumps great. just needs clay suburbs tires.
pword is offline
Old 03-05-2011, 01:22 PM
  #2393
Thanks,
rifraf is offline
Old 03-05-2011, 07:30 PM
  #2394
Has anyone tried to run a 550 motor with a Tekin RS ESC? If so,what KV and how well did it work? Thanks,
I wished I could run a 550 motor with my brand new tekin RS..
rifraf is offline
Old 03-05-2011, 09:39 PM
  #2395
G_WORD's Avatar
Trader Rating: 124 (100%+)
tekin told me the RS is not good for a 550 motor. you should use the RS PRO
G_WORD is offline
Old 03-06-2011, 01:10 PM
  #2396
ok went with the 5.5 hobbywing.....see what happens!!!!
Old 03-06-2011, 02:22 PM
  #2397
justbeastit's Avatar
Use a small pinion with that high kv of a motor. Keep a good eye on the temps. Might need a fan depending on your driving style/conditions.
justbeastit is offline
Old 03-06-2011, 06:56 PM
  #2398
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
I run a mmm/2650 in my 10th scale CRT.5 it's a beast
84 GT 5.0 is offline
Old 03-07-2011, 07:31 AM
  #2399
my friend won the bigfoot this weekend with a tekin 4.5 550 motor with a rs pro in it.
slowslug is offline
Old 03-07-2011, 09:57 AM
  #2400
-R2-'s Avatar
You guys in Tx. sure have alot of TT racing over there, wish I was out there racing with you guys.
-R2- is offline
