Like Tree9Likes
Old 03-01-2011, 08:30 AM   #2341
Daebech2475's Avatar
Trader Rating: 41 (100%+)
I am runnin a 14t with tekin 5.5, 550. Temps are perfect, and the thing is a beast! Not darting off jumps with nose up like alot of others with lower pinions.
Ofna X3 Sabre,Alpha A830/X3 Sabre-e,Tekin; Byrons/Futaba
Daebech2475 is offline   Reply With Quote
Old 03-01-2011, 09:30 AM   #2342
ndi_guy's Avatar
Trader Rating: 32 (100%+)
Default ?
I don't think anyone is having a problem with these things jumping nose up.
ndi_guy is offline   Reply With Quote
Old 03-01-2011, 12:23 PM   #2343
Originally Posted by macnkitty2002 View Post
Got to test my TT for the first time today. I am having some radio issues and I dont know whats going on.
The steering servo randomly recenters itself to a different position about every 10 seconds. I have it set perfectly straight on the bench, but I do a pass and come back and now the neutral setting is pointing to the right. I do another pass and it'll reset the neutral steering position to something else. It makes it impossible to drive on a track. I am using a Spektrum DX2.0 transmitter and an sr3000 receiver. I have a capacitor in the "aux" slot (this is supposed to help maintain voltage to the receiver) but that doesn't help. I'm using the Castle Sidewinder SCT 3800kv motor system.
Also, my motor temps are around 100F and my ESC is around 120F. Is this normal? I was using a 42/12, gonna try a 42/14 next.
Any help would be greatly appreciated!
its the sidewinder and the sr3000 disagreeing... I had the same problem had to add a BEC to fix the problem...
mightymutt1 is offline   Reply With Quote
Old 03-01-2011, 12:40 PM   #2344
Mine jumps nose up...
Also I see everybody saying run low kv and big gears, I done the opposite. I have a 3.5t 550 on 3s with 11t pinion when it catches traction if the wing would not touch on the way around it would do back flips like a flux. On 2s it's prefect for the track super snapy power and enouff top speed to air it out when necessary. Brought it to the dunes the other day with a full set of paddles was super fun on 2s on 3 any how you would ease into it to half throttle if you bliped it open it was on it's back
Sackamous is offline   Reply With Quote
Old 03-01-2011, 12:52 PM   #2345
You must post a video...ASAP
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 03-01-2011, 02:46 PM   #2346
macnkitty2002's Avatar
Got my truck steering problems sorted out. This thing is such a bundle of fun! Running 14/42 right now with the Sidewinder SCT system and a 2S 20C battery. Thinking about upping the pinion one more tooth to get a little more top speed out of it. That should help lower my ESC temps right?
Stock tires seem to work good for me as well. Not sure how they'll hold up at my track at home which tends to be dusty.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 03-01-2011, 02:59 PM   #2347
Erik in sac's Avatar
to those running the strc spur gear, did your truck already come with the stock plastic spur? And was it a noise improvement over that? Thanks
Ofna Hyper10 TT, Castle MMP/Ballistic 550 4.5T, Savox 1258, Spektrum tx/rx
Losi XXX BK/CR hybrid, Tekin RS/10.5T, Savox 1257, Spektrum tx/rx
HotBodies Cyclone TC WCE, Novak gtb2/Ballistic 25.5t, Savox 1251, FlySky GTB-3 tx/rx
Erik in sac is offline   Reply With Quote
Old 03-01-2011, 03:02 PM   #2348
it should but I would be carefull running with the 20C IMO
HB Ve8 HHH
DirtyCookieX is offline   Reply With Quote
Old 03-01-2011, 03:36 PM   #2349
LDOstrem's Avatar
I have a set of proline badlands I run on my TT on loose dirt and it jumps nose up A LOT. I didnt realize how much the larger diameter would affect it and if I release the throttle to fast mid jump it immediately dives. Not so graceful by any means!
Why doesnt anyone makeing desert buggy cage/body's or do I have to fab my own :/
LDOstrem is offline   Reply With Quote
Old 03-01-2011, 07:43 PM   #2350
scooterman19's Avatar
Default o
So Im thinkin the verdict is either the sct 3800 or the dynamite 3300....buyin it this weekend no matter what....I have two 4000mah 25c lipos will these be enough or do I have to goto 40C????? also if anyone can reccommend a less expensive servo that will be good...I would appreciate it
scooterman19 is offline   Reply With Quote
Old 03-01-2011, 07:57 PM   #2351
1Fastpede's Avatar
Trader Rating: 49 (100%+)
Yes mine came with blue plastic spur. I then added the strc spur and it is just as loud. the noise is from front and rear diff;s and every TT is louder/quieter then the next. my buddies is as quiet as my b4 2wd buggy but my TT sounds like a tank.
1Fastpede is offline   Reply With Quote
Old 03-02-2011, 09:45 AM   #2352
Why do you say be careful with the 20C?
Losi Rock Rey
Old 03-02-2011, 10:03 AM   #2353
castle recommends at the minimum use a battery with at least 25C constant. Honestly I ran the SCT system with a 20C battery and t it ran fine until I went with a 16T, frying the ESC. Could have just been a fluke incident though and had nothing to do with C rating...
HB Ve8 HHH
Old 03-02-2011, 10:07 AM   #2354
Wouldn't a higher C rating make the ESC run hotter? Or do low C ratings make the ESC work harder to pull current from the battery?
Maybe it's that with a higher C rating, the ESC has more power on tap from the battery and doesn't have to 'pull' as hard on the battery.
Losi Rock Rey
Old 03-02-2011, 10:25 AM   #2355
1Fastpede's Avatar
For C rating
Picture a straw
20C is like a coffe straw/stirrer
50C is like a mcdonalds staw. (ever notice how large dia they are)
One takes more effort to drink then the other.
