Like Tree4Likes
Old 10-21-2010, 08:15 AM   #211
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally Posted by teamstrc View Post
Hi Guys,
We added a Hyper TT section on our website. Quite a few parts from the Hyper 10SC interchanges with the TT
http://www.teamstrc.com/index.php?ro...ory&path=57_61
Steve
Hey Steve, can you make an adjustable battery plate for the TT that let's us move the battery tray forward, unlike the SC where you can adjust backwards?
BOLISARIO is offline   Reply With Quote
Old 10-21-2010, 08:18 AM   #212
???E-Racer's Avatar
I'll be picking one of these up soon.
Nice motor mount Salad Fork...
Novak, Viper, LRP
4wd Slash Platinum,4WD SC10,Stock Slash Latemodel Oval,Losi Slider,E-firestorm Bomber, Team Terribles,www.rkhobbies.com,GOLFLAND USA
???E-Racer is offline   Reply With Quote
Old 10-21-2010, 12:01 PM   #213
SaladFork's Avatar
I just sold the last one...
However, I was holding one for myself in-case I got the TT. If for some reason I don't I will let you know.
TLR | AE | AKA | Viper |
SaladFork is offline   Reply With Quote
Old 10-21-2010, 12:35 PM   #214
common guys post more pictures!!!
anyone else tried mounting the motor on the opposite side like the durango?
Kyosho RT5, kyosho SC-R, Kyosho Mad force VE 8s, Tekno Sct410,
TMM-25063 x2 Pro & Neu 2230-12 (On the way)
pirape is offline   Reply With Quote
Old 10-21-2010, 05:54 PM   #215
Trader Rating: 37 (100%+)
Just ordered a 10TT. Will be running in the 1/8 Buggy/Truggy class and the only electric in the class. I have no worries though. My Hyper 10SC is the only electric in our SC class and I do real well with it. Everyone else is running SC8 nitros. I had one but didn't like it and went back to the Hyper 10SC. No need for 1/8 or nitro in my opinion, these Ofna rigs are real screamers.
Cody01 is offline   Reply With Quote
Old 10-21-2010, 07:46 PM   #216
carcrazy699's Avatar
Trader Rating: 48 (100%+)
just got back from the track and the tt is awsome. very fun little car. the only thing i need to do is soften the rear and get the ball ends cause mine keep poping off. also need to stock up on front knuckles since mine poped out. i really hope they make aluminum ones or rpm comes out with some that would be awsome
carcrazy699 is offline   Reply With Quote
Old 10-21-2010, 08:04 PM   #217
PinoyCali's Avatar
Default Rs speed control
Hello,
Is anybody using rs esc with 6.5t on your TT?
Rs 208 default set up ..running 5-7 minutes temp is 161.
Is 160 ok? Any set-up advice?
PinoyCali is offline   Reply With Quote
Old 10-21-2010, 09:02 PM   #218
Trader Rating: 101 (99%+)
Originally Posted by PinoyCali View Post
Hello,
I had the same question and emailed Randy Pike at Tekin (yesterday). He responded back very quickly and said if we choose to use the RS esc with a 6.5t, definitely solder a 2nd capacitor on it and watch temps/gearing to be on the safe side.
Hope that helps!
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 10-21-2010, 09:27 PM   #219
PinoyCali's Avatar
Hope that helps!
Hi..
What size of capacitor and where to solder?
Thanks..
Old 10-21-2010, 09:35 PM   #220
SaladFork's Avatar
Hi..
Thanks..
http://www.amainhobbies.com/product_...FX-R1-series-2
Instructions included.
Old 10-21-2010, 09:41 PM   #221
what shock springs does everyone run on these? i need to soften up the rear of mine but have no idea what springs to look at
Old 10-21-2010, 10:10 PM   #222
BOLISARIO's Avatar
Just got the motor ERC mount in yesterday. Thanks for the quick shipping. I mounted a 6.5 Tekin with a 12t 3mm mod1 pinion and noticed the pinion sticks out 2-3mm. So about 3/4 of the spur gear meshes with the pinion. Will that be more than enough? The back of the pinion is already hitting the ERC M-Blox(the cam) and can't push it in further.
[IMG] Uploaded with ImageShack.us[/IMG]
Also, is it okay to use the motor mount without the bearing? The bearing is sized for 5mm shaft motors.
Old 10-22-2010, 12:42 AM   #223
lbckevin's Avatar
Trader Rating: 89 (99%+)
Hi..
Thanks..
We have the Tekin caps in stock at WC.
PS. I ran the Tekin RS pro with a mod motor...The pro runs alot cooler.
I also cut cooling holes in the front winshield and rear window.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-22-2010, 06:49 AM   #224
lockmouth's Avatar
Trader Rating: 33 (100%+)
Use HB pinions.. they are shorter than all the others. They work perfect with the Elite mounts
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 10-22-2010, 06:52 AM   #225
I used a file and about 30 minutes of my time and I fixed the issue
but not time to wait for the new bottom part
