Like Tree4Likes
Old 02-20-2011, 12:17 PM   #2221
Slash65's Avatar
Default Different wing
Is the CRT .5 wing a direct bolt on or is there modifications to be made?
HoBao Hyper 10 TT
Sanwa MX-V
HobbyWing XeRun V2.1
Dynamite 6.5T
Slash65 is offline   Reply With Quote
Old 02-20-2011, 03:37 PM   #2222
Trader Rating: 73 (100%+)
CRT .5 comes with no holes drilled so its an easy fit, drill and screw on.
However many others and myself feel it looks a touch small.
Cheers matt.
mister_g is offline   Reply With Quote
Old 02-20-2011, 03:52 PM   #2223
Slash65's Avatar
Cheers matt.
thanks
HoBao Hyper 10 TT
Sanwa MX-V
Dynamite 6.5T
Old 02-20-2011, 04:21 PM   #2224
ndi_guy's Avatar
Trader Rating: 32 (100%+)
Default tough
I think the Ten-T wings look the best as well. Just my .02 worth.
My 12 year old and I took our TT's to the track yesterday for a while. It was a new layout and tough as heck. We both suck as drivers but are learning fast. We absolutely beat the daylights out of them and the only broken part was a rear arm on mine. I think our day would have ended much sooner were it not for the T-Bone front bumpers. They took a ton of abuse.
MAN, THESE TRUCKS ARE FUN.
ndi_guy is offline   Reply With Quote
Old 02-20-2011, 06:23 PM   #2225
10TT Roller + Hopups for sale
iThinman is offline   Reply With Quote
Old 02-20-2011, 07:29 PM   #2226
thecman26's Avatar
Trader Rating: 98 (100%+)
Ok, took mine to the track and got 10-12 laps of practice, truck was good, still REALLY squirly, turned down my steering rate to 40% started to help on that but then pillow ball kept pulling out on the right side. IDK why... Wasnt hitting stuff... I just may switch to a C-Hub setup which I prefer (way more durable). Anyone else try this yet? Love the truck though, jumps great!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 02-20-2011, 07:54 PM   #2227
macnkitty2002's Avatar
Noticed that the pillow ball retaining screws back out pretty easily on these things. Any ideas on how to prevent this? Was thinking a dab of silicone on the threads might help keep it in place.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-20-2011, 08:10 PM   #2228
thecman26's Avatar
I really wish that the cause of my headache bu they are pulling righ out and its not easy to get them back in. I have never been a fan of pillow balls anyways, from my brief experimentation with the Sportworks Mayhem and Turmoil...
I will see about getting parts to do a C-Hub swap on mine and report if this helps.
Old 02-20-2011, 08:40 PM   #2229
Farmer_John's Avatar
Originally Posted by MoonDeville View Post
What Punisher body is that and can we get a few pics of where you had to trim? I was thinking of doing just this. Thanks
Moon
It is the T4 lid. Essentially, cut off the spoiler mount and a lot of the rear quarter panels. Also cut a rectangular slot much in the area the stocker is cut for wing clearance. And finally had to cut for clearance for the rear shock tower.
I set the location by resting the front of the lid against the front bumper.
You'll need to clearance the front wheel wells and in front for bumper clearance.
The one further change I'm going to make are for taller front mounting posts, it's a bit tight with the stockers.
But, it does look good on the track.
Farmer_John is offline   Reply With Quote
Old 02-21-2011, 01:26 PM   #2230
Just wanted to share some pics of my custom painted lid by Sk3tch. I wanted the theme to match my screen name and personal nick name
Originally Posted by Sk3tch View Post
Here ya go DirtyCookieX! (another RCS rip effect)...
www.offthehwal.com
HB Ve8 HHH
DirtyCookieX is offline   Reply With Quote
Old 02-21-2011, 09:08 PM   #2231
Got my truck all together tonight and I'm rather proud of my handywork considering I have limited resources and most of my gear at home (I'm currently at college). Numerous zip-ties helped tie down my gear but it looks pretty clean to me. Seeing as I got this truck second-hand, I am missing some stock items namely the pinion gear. That is the one thing I need right now to run the truck! The guy sent me a 14 tooth pinion that is too large for my Castle Sidewinder 3800 motor. The inside diameter of the pinion is 5mm and of course the motor is around 3mm. The spur gear is 42 teeth, apparently he switched out the stock blue spur.
My question is, where can I get a pinion gear that will work for me and what size pinion should I get for general purposes? I want to get this thing going!
Losi Rock Rey
Old 02-21-2011, 09:29 PM   #2232
all you need is an adapter sleeve to go inside the pinion. I know Robinson racing makes one which most hobby stores should have...
HB Ve8 HHH
Old 02-21-2011, 09:35 PM   #2233
Awesome! Is this all I need?
http://www3.towerhobbies.com/cgi-bin...?&I=LXURT7&P=7
And is a 14 tooth pinion good with the 42 tooth spur and my Sidewinder SCT motor combo?
Losi Rock Rey
Old 02-21-2011, 09:43 PM   #2234
yup thats all you need.
As for the gearing, it should be plenty fast. I suggest getting one of these to check temps
http://www.duratrax.com/caraccys/dtxp3100.html
which can be found on ebay for pretty cheap.
HB Ve8 HHH
Old 02-21-2011, 09:57 PM   #2235
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Is 42t the stock spur?
14t pinion will possibly run really hot, especially for racing.
I'm running a 12t and plan on going 11t.
heavyjeffd is offline   Reply With Quote
