Like Tree4Likes
Old 02-15-2011, 10:34 AM   #2176
Originally Posted by macnkitty2002 View Post
What is a good brushless motor and ESC setup for this thing? My preferred brushed motor is about a 17-19 turn, what is comparable in a brushless motor? Would that be about a 4.5?
Combining different brand motor and ESC is new to me, I've seen the Tekin ESC a lot on here with Mamba motor.
Trying out a new set up tonight for the first time:
Going from the Castle Creations SCT combo to a Ballistic 550 4.5T/Speed Passion GT2.0...
off topic but do I need to run the capacitor that came with my ESC?
HB Ve8 HHH
DirtyCookieX is offline   Reply With Quote
Old 02-15-2011, 11:46 AM   #2177
macnkitty2002's Avatar
Is this a good setup for the truck?
http://www3.towerhobbies.com/cgi-bin...?&I=LXZAF4&P=7
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-15-2011, 12:46 PM   #2178
Trader Rating: 42 (100%+)
[QUOTE=macnkitty2002;8657320]Is this a good setup for the truck?
http://www3.towerhobbies.com/cgi-bin...?&I=LXZAF4&P=7[/QUOTE
It would work, however it's not sensored and IF your going to go non sensored use the Castle SCT 3800 combo for $120 and get a Gen Ace 5000 Lipo for $40 from hobbyparts.com and you'll be happier in the end.
miket3 is offline   Reply With Quote
Old 02-15-2011, 02:40 PM   #2179
What's the difference between sensored and non-sensored? I'd just be bashing anyhow.
Losi Rock Rey
Old 02-15-2011, 03:08 PM   #2180
dspoo2's Avatar
i think you have it the wrong way around
David
B44.1 - Novak - Pro-Tek - Spektrum
RC10T4 - Novak - Pro-Tek - Spektrum
soon hyper 10TT
dspoo2 is offline   Reply With Quote
Old 02-15-2011, 03:09 PM   #2181
Which part?
Losi Rock Rey
Old 02-15-2011, 03:20 PM   #2182
dspoo2's Avatar
mamba max pro with a tekin sct 550 4.5
David
soon hyper 10TT
Old 02-15-2011, 05:28 PM   #2183
aegiswa's Avatar
Trader Rating: 14 (100%+)
The motor will have sensor assembly with cable running from the sensor to the speed controller - the benefits of using the sensors are smooth throttle especially at low speed and the ability to boost the motor with timing dynamically from the ESC.
Just bashing you might not need one, racing in mod classes it rates from pretty nice, to required anymore -
Most sensored motors will work on a sensorless ESC.
I'd look at something like this for bashing w/15-16T pinion:
http://www.amainhobbies.com/product_...Package-3800kV
Here they are pretty good with the 4 pole motors -
AegisWA <><
Ofna Hyper SC10 + 2S Kinetic/Ballistic 5.5 (550)
Ofna Hyper 10TT + 2S Kinetic/Ballistic 6.5 (540)
Team Associated - FT SC10 + 2S Kinetic/Ballistic 10.5
Mugen - MBX6 + Nova - hibernating 'till things warm up and dry-out....
aegiswa is offline   Reply With Quote
Old 02-15-2011, 09:20 PM   #2184
What about this combo?
http://www.amainhobbies.com/product_...r-Combo-3900kV
Losi Rock Rey
Old 02-15-2011, 11:34 PM   #2185
aegiswa's Avatar
I'd probably not go that route myself - Associate put those in like a B4/T4/SC10 RTRs - those vehicles are light compared to the TT -
I'd wait for the Castle to come back into stock or spend a few bucks more for something a little stouter. The Traxxas VXL works pretty good in these if your budget, couple guys were them running locally in the Hyper 10SC and TT - they are a cross between a 540/550 motor.
http://www.amainhobbies.com/product_...mbo-Waterproof
AegisWA <><
Old 02-16-2011, 02:26 AM   #2186
antonio_cadiz's Avatar
hello!
I need stiffer springs. Which model should I buy?
thanks
antonio_cadiz is offline   Reply With Quote
Old 02-16-2011, 03:03 AM   #2187
That's what comes in the stock RTR SC10, well it uses the reedy 3300. In any case I would not recommend it for a 1/10 4x4.
silentbob343 is offline   Reply With Quote
Old 02-16-2011, 11:54 AM   #2188
damn this combo is nice!
I am def a firm believer of how much smoother sensored motors are compared to non-sensored. Temps were ~148/motor, ~100/ESC, ~100 on the battery with a 16T and stock spur on defult settings on a full pack. I may go down to a 15T, we'll see.
HB Ve8 HHH
Old 02-16-2011, 12:00 PM   #2189
J. Schwarz's Avatar
Trader Rating: 49 (100%+)
going to try this
and a Tekin RS Pro
11 or 12 Tooth pinion should be the ticket!!
J. Schwarz is offline   Reply With Quote
Old 02-16-2011, 01:17 PM   #2190
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Had not seen them before but did some Googling, looks quality. Let me know how it works for you, always nice to have options.
heavyjeffd is offline   Reply With Quote
