Hyper TT 4wd 1/10th Truggy Thread
#2117
hi guys how r u?
I have pick up a 1/10th hyper tt pro to have bit of fun with and some occasional racing. I install an lrp sphere comp esc with a 6.5t motor.
I have reset speedy to the 3pk controller and all works good.
The problem is i have set the punch control to the lowest and apply alot of -expo on the throttle and it still accellerates pretty hard of the mark with the slightest input. which i think will put alot of stress on the driveline. aswell as make it pretty hard to drive in slippery conditions! At first i thought the speedy hadn't calibrated properly so i reset it again and put in the nuetral point, full throttle and full brake points again. But it is still the same!
Does anyone here know any tricks with the 3pk to tame it down a bit or is this how it is with these new generation electric buggy/truggy when they dont have slipper clutches?
the only way i can think of is to put a bigger pinion on and reduce the top speed
at the moment it has the std 13t pinion.
thank for any help or advice you can give me!
#2124
Could someone post the exact length and width of the Hyper 10 TT's chassis?
I don't want the dimensions ofna has in their site.(the don't measure chassis...)
#2125
I ask because I want to convert my mini ste to hyper 10 tt.Anyone?
#2127
hi guys how r u?
#2128
R/C Tech Elite Member
#2129
hi guys how r u?
And a bigger pinion will give you more top speed. Not less.
As for "calming" down the bottom end, it wont help a lot unless we're talking 6-10 teeth. Electric motors have a lot of instantaneous torque as we all know.
Try upping your punch control and leave your throttle end point. Should be good after that.
#2130
If your radio has curves, just put a negative throttle curve in.
