Like Tree4Likes
Old 02-09-2011, 02:42 PM   #2101
HYPERBOY's Avatar
I have been driving Dj's at huge 1/8 tracks with no problems, I can't imagine what people have to do in order to break one.....Blows my mind considering Dj calls my their crash test dummy of cars.
James Grossaint
HYPERBOY is offline   Reply With Quote
Old 02-09-2011, 04:55 PM   #2102
Trader Rating: 17 (100%+)
Originally Posted by HyperRacing View Post
I am not aware of any other upgrades right now.
As for the questions regarding the dog bones and axles there are currently no upgrades for these parts.
The STRC cv shaft is a replacement for the stock cv shaft only and still uses the stock cv axle and cv joint hardware (pin and barrel)
Thanks, but I called them bones meaning the CV shafts. Will you be selling these hardened CV shafts with the CV axle and hardware as a set? I would rather buy 2 complete sets and be done, instead of buying a set of CVDs for the rear AND 2 sets of shafts to upgrade them.
burnineyes is offline   Reply With Quote
Old 02-09-2011, 05:48 PM   #2103
utah300rum's Avatar
Trader Rating: 27 (100%+)
burnineyes......I think he answered your question a couple posts back
Spooky's Racing for Asphalt & Carpet, Blacksheep Raceway for off-road, Utah Mountains for bashing!
utah300rum is offline   Reply With Quote
Old 02-09-2011, 06:48 PM   #2104
Trader Rating: 36 (100%+)
Originally Posted by Glowster21 View Post
Hey all, My TT is showing up today and I have a couple quick questions. For those of you running 540 motors, what are you running and what type of gearing? Also, anyone tried the rear hub carriers from a Jammin SCRT10 to see if they will work? Reason I ask is I have an extra set of alloy carriers for the Jammin and would put them on if they fit with little modification. Last, what seems to be the breaking point on these? I see there have been some issues with the servo saver assembly, anything else seem to be weak?
I'm currently running an RS/Redline 8.5. I tried a Murf 6.5, thermalled the RS about 4 minutes in. Motor stayed cool though. I'm pretty set on the stock 13 T pinion. I've tried a 16, and while it didn't cause thermal issues, it was quite hot and I could feel a loss of performance.
STRC makes Alum carriers for the Hyper 10SC which are a direct fit. Not sure on the Jammin parts.
As noted in previous posts, the pillow ball retainers seem to be a problem. Also the servo saver. STRC makes an Alum saver for the Jammin that can be modded to fit.
NitroOB4You is offline   Reply With Quote
Old 02-09-2011, 07:12 PM   #2105
utah300rum's Avatar
anyone have a write-up or instructions on how to mod the Jammin servo saver onto the 10TT.
I would like to know how involved it is before I order the Jammin servo saver......no one local has one so I cant look at it to compare.
Thanks,
Kalani
Old 02-09-2011, 07:25 PM   #2106
Thanks, I actually had his response quoted in my post. The whole part about dogbones and stub axles made me think he did not get the question right, but he did say they are only offering the axle shafts. I guess I was just complaining more than actually asking the same question over again with clear language.
Old 02-09-2011, 07:31 PM   #2107
utah300rum's Avatar
I just found a write up in the 10SC section...searched "strc steering" and found a write-up with pics...looks pretty easy.
I noticed it said to re-use the stock upper servo saver arm..... now I am curious what part is breaking on the stock servo saver?
hopefully not the upper arm
Old 02-10-2011, 10:38 AM   #2108
macnkitty2002's Avatar
Interested in getting one of these. I've always liked the 1/10 4wd class but was not attracted to the 1/10 4wd buggies because most of them are so race oriented and fragile looking. When I saw the Hyper 10tt it really caught my eye and the price is right too!
I see NitroHouse has the Pro combo with a Novak GTB2 and 6.5 Ballistic motor for $350. The motor and ESC themselves would be $185 so you would save $35 by doing the combo. Is the 6.5 motor pretty fast? How many turns would it compare to in a brushed motor? I would just be bashing it, and my preferred brushed motor is about a 20 turn.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-10-2011, 11:37 AM   #2109
-R2-'s Avatar
My TT has the Havoc pro Sc with the Velocity 6.5 and is really good on speed, I used 2 stage on timming and gets 21 second lap times at OCRC. I won last night against 4wd SC's by two laps, car is awsome and I have good time everywhere I run it. I've taken it to Hod Rod's,Pegasus Hobbies, Revelation, OCRC and WCRC. Stock tires, Holeshots and Barcodes have been the car and work well.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 02-10-2011, 11:41 AM   #2110
How does the truck hold up durability wise? What kind of parts should I have on hand for bashing purposes? I almost never break stuff but I generally carry some spares just in case.
Parts availability is mainly through NitroHouse right? Where is the best place to buy this? I haven't seen any used rigs on eBay. Is the NitroHouse Novak combo a good deal?
Losi Rock Rey
Old 02-10-2011, 11:42 AM   #2111
im running gtb1 with a lrp 6.5, very good speed on the stock 13t pinion or 12t for a lttle more low end vs top end, i prefered it speedwise to the sct combo i tried out.
Serpent Cobra E RTR, HB VE8, Summit, Vaterra Kemora/Kalahari, XRAY X10, XRAY X12
Buying and selling as tracks open and close
hoousi is offline   Reply With Quote
Old 02-10-2011, 12:01 PM   #2112
1Fastpede's Avatar
Trader Rating: 46 (100%+)
With lots of system choices for these little truggies, here is one option. Tekin RX8, 4.5 550 Novak ballistic motor, 14T pinion, 2 cell lipo. No speed advantage over the guys with 540 motors, maybe more torque though. Absolutely no heat issues with this set-up.
Attachment 655416
What springs are you using? hard(white) hyper10sc? the front also look like a rear spring length.
Mine seems to chassis slap hard after some landings. with stock springs mainly the front
1Fastpede is offline   Reply With Quote
Old 02-10-2011, 12:11 PM   #2113
I have not received mine yet so I cant answer your durability questions. But I ordered mine from Amainhobbies along with a Viper 8.5, and I was able to use a $25 off coupon I found on this forum. Including shipping I paid $275 for Truck and motor. Advantage Hobby had a sale and as a first time customer I was going to get the truck for $186 shipped, but the sale ended a day before I got paid. I have since received emails about other sales, so it might be worth a look. Nitrohouse is not much more, and I believe you can get a discount on the lightweight chassis if you purchase it at the same time. I personally dont like Novak, so the combo wasnt for me.
My truck should be here tomorrow, I am getting anxious!
Old 02-10-2011, 12:18 PM   #2114
So you didn't get an ESC with that deal right? Only the truck and the motor?
Losi Rock Rey
Old 02-10-2011, 12:24 PM   #2115
That is correct, I am using a Xerun ESC.
If you like Novak then that combo deal at NitroHouse is hard to beat.
