Like Tree4Likes
Old 02-06-2011, 04:43 PM   #2011
Farmer_John's Avatar
So has anyone tried swapping over to the C hub front end off the Jammin?
I hate pillow ball front ends...
Join the Pancar nation
https://www.facebook.com/oneeigth2wdpancar/
Farmer_John is offline   Reply With Quote
Old 02-06-2011, 11:22 PM   #2012
how would a MMP with Novak Ballistic 550 4.5T run in this truck?
HB Ve8 HHH
DirtyCookieX is offline   Reply With Quote
Old 02-06-2011, 11:41 PM   #2013
thecman26's Avatar
Trader Rating: 99 (100%+)
The MMP would be great but the 4.5, that would be overkill... I have a 6.5 in mine and its crazy fast! But I would like to see one with a 4.5 in it! I am sure it would be a rocket!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 02-07-2011, 01:32 AM   #2014
redthunder's Avatar
Trader Rating: 15 (100%+)
I have a Ballistic 4.5t 550 in mine, and yes it is rather fast, 13t pinion and it works really well, but it runs hot getting a heat sink for it
redthunder is offline   Reply With Quote
Old 02-07-2011, 06:03 AM   #2015
justbeastit's Avatar
That doesn't sound right. I had a 6.5t 540 in mine and THAT ran hot so I switched over to the ballistic 4.5t with a 14t pinion and it comes off at 115 degrees after a 10 minute main. Buddy of mine is running the Tekin 4.5 sc4x and his is even cooler. Is your mesh too tight somewhere creating drag on the drivetrain? You should check into that imo...
justbeastit is offline   Reply With Quote
Old 02-07-2011, 06:39 AM   #2016
Mine is cold after a 10 min run with 20T pinion (about 30C).It's not heating up even on 3s lipo..
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 02-07-2011, 07:31 AM   #2017
the reason Im asking is because I ordered a hobbywing 120amp v2 to run with the ballistic 550 4.5T but its coming from Hong Kong. And with the Chinese New Year happening this might take a while to get So I was thinking of buying a MMP in the mean time or should I just wait it out? Ahhhh decisions and money!!
HB Ve8 HHH
Old 02-07-2011, 07:45 AM   #2018
Some video of our A-main from the "Truck Off" trophy race this past Saturday at Glenwood RC near Buffalo, NY. We had down to a C-main, as Davo said previously quite a few breakages throughout the day (stub axles, knuckles, steering racks). Definitely can't drive these like 1/8 scale truggies. http://www.youtube.com/watch?v=NZIVsnO542U
pullinteef is offline   Reply With Quote
Old 02-07-2011, 01:38 PM   #2019
ndi_guy's Avatar
Trader Rating: 32 (100%+)
Hopefully you will get to see mine at Emery this year and I can get to meet some fellow rc addicts. I am running the mmp in mine with Tekin sc4x 4.5 14 tooth pinion and I don't feel like its crazy fast yet. Ran it in Hutch a couple weeks ago and after 20 minutes it was only 86 degrees.
ndi_guy is offline   Reply With Quote
Old 02-07-2011, 03:06 PM   #2020
tedstryker's Avatar
Trader Rating: 75 (100%+)
ME..TT
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 02-07-2011, 04:43 PM   #2021
Originally Posted by tedstryker View Post
ME..TT
Ted Stryker Haha great name.
And dont call me Shirley!!
Hahahahaha
Hyper 10SC
Team Terribles, Mike's Hobby Shop Carrolton Tx.
Up and coming factory team driver
slowslug is offline   Reply With Quote
Old 02-07-2011, 05:42 PM   #2022
redthunder's Avatar
really? huh... well the gear mesh is fine, set it with the peice of paper method, and it rolls nicely, i can turn the pinion quite easly by hand or finger i should say, so i dont really know why its getting so hot I don't have a temp gun but i'm assuming if you cant hold your finger on the motor for longer then a second after a ten minute run then its probably too hot,
i had a 15t pinion on it before, changed to a 13t, but it gets to the same temp as the 15 did only slower
any other suggestions would help, i am running on carpet if that makes any difference.
Old 02-07-2011, 06:10 PM   #2023
1Fastpede's Avatar
Trader Rating: 48 (100%+)
i run a 4.5 tekin 15T and it comes off at 90.
on mine the piece of paper method gets the mesh too tight. so i fold it. you should be able to hold the spur and rock the pinion back and forth a lil
i would assume carpet would increase temp because of high grip.
1Fastpede is offline   Reply With Quote
Old 02-07-2011, 06:18 PM   #2024
redthunder's Avatar
yep, i can rock the pinion back and forth a little, ill try folding over a piece of a4 paper see if that helps, is that 90 degrees C or Fahrenheit?
Old 02-07-2011, 06:19 PM   #2025
90 degrees F
