Like Tree4Likes
Old 02-01-2011, 12:13 PM   #1936
Smile
Originally Posted by iThinman View Post
"It puts the lotion on it's skin or else it gets the hose again"
HAHAHAHAHA!!!!!!
Hyper 10SC
Team Terribles, Mike's Hobby Shop Carrolton Tx.
Up and coming factory team driver
slowslug is offline   Reply With Quote
Old 02-01-2011, 07:25 PM   #1937
jrz93's Avatar
Originally Posted by Toiffel View Post
I prolly did, but from talking to Chris, and based on my current set up, going to give it a try, I made the mistake to make all my changes before trying the box set up, so I really don't have any comparison besides what I have been running..... apart from the lack of steering the box set up "looks good" but then again I didn't try it...so let's see.
box stock is a great feel...let me know how it feels with 1-5-1
what about 1-3-1?
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 02-01-2011, 07:29 PM   #1938
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
I'm currently running 5-7-3 (because that's what I had) but am going to switch to 3-7-1 to get more low speed steering (hopefully).
heavyjeffd is offline   Reply With Quote
Old 02-01-2011, 07:29 PM   #1939
jrz93's Avatar
Originally Posted by 1Fastpede View Post
what day was that..and what heat the running them in? sportsman?
at the 1st trophy race we traveled there too, we had to run em in unlimited n some were running on converted 4s lipo vehicles
Old 02-01-2011, 07:38 PM   #1940
jrz93's Avatar
Originally Posted by thecman26 View Post
You need these:
OFN37220 OFNA 3mm King Pin Screw
PTK-MR85ZZ ProTek R/C 5x8x2.5mm Metal Shielded "Speed" Ball Bearings
The ackerman goes as it should, on top, trust me it works! You can grind on the diff case a bit if you want to but I didn't do that, plenty of throw for me...
Originally Posted by jrz93 View Post
ok so i tried the steering mod using the st racing jammin bellcrank all is good except how do you sue the ackerman?
the hole is too big for the stock/wire rod and too big for a 3mm screw for the strc aluminum one that comes with it??????????
thank you for any answers
ok sorry back to this
yall said that there is no more modding necessary but why does the bellcrank hit the diffcase. and yes i know about the steering mod posted here many times. the plastic bellcrank and aluminum both are same size but when turned left the right side (passenger) hits the diff case.
and also it may be that my strc ackerman is not complete flush but the ackerman hits the left side top plate (strc aluminum as well)???????
Old 02-01-2011, 08:25 PM   #1941
jrz93's Avatar
im gunna try traxxas ballends and dremmel the ackerman flush n see what happens i guess
Old 02-01-2011, 08:42 PM   #1942
1Fastpede's Avatar
Trader Rating: 45 (100%+)
I cant get mine to hit the diff case if i tried. im not sure how you guys have these issues. even one at my track guy was grinding down the plastic on the diff.
1Fastpede is offline   Reply With Quote
Old 02-01-2011, 08:52 PM   #1943
thecman26's Avatar
Trader Rating: 98 (100%+)
Mine hits but I have plenty of steering anyways, its not the issue now... I have TOO much steering now, its really twitchy! But its still fun to play with though!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 02-02-2011, 09:42 AM   #1944
JayRC66's Avatar
That was this past sunday. I was the only one that showed up with the truck. Ran it in Sportsman.
As for that trophy night, I believe that was a LOSI 10T converted to electric. I was there as well. But my electronics was acting up. MM Pro. Go figure.
Jovanny S.
Losi, Serpent, Schumacher, Ofna.... yea I got a little bit everything.
JayRC66 is offline   Reply With Quote
Old 02-02-2011, 09:52 AM   #1945
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
Whats the best motor for these trucks? I plan on running a MMP.
Can we run a 540 can Mod motor? or do you need a 550 to keep up? Whats the advantage of running a 550 over a 540?
I have a 5700kv Castle Sidewinder setup i ran in my Stadium truck that was WAY to much power. Would that work in the TT?
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 02-02-2011, 09:59 AM   #1946
JayRC66's Avatar
I am running Associated LRP SXX TC Spec Brushless Speed Control with an X12 6.5T motor. Stock pinion
Jovanny S.
Old 02-02-2011, 10:09 AM   #1947
utah300rum's Avatar
Trader Rating: 27 (100%+)
Default Stock wheels durability?
How are the stock wheels holding up?
I got some tires and want to mount them...the Ofna have a good price of $14for 4...but how are the holding up to the power and abuse?
I have an E-Firestorm and noticed thay have the same offset....HPI has a bunch of wheels that will work...dish, spoke etc. etc. but they are a little more $8 to $15 for 2 wheels.
Anyone have any good or bad experiences.
Spooky's Racing for Asphalt & Carpet, Blacksheep Raceway for off-road, Utah Mountains for bashing!
utah300rum is offline   Reply With Quote
Old 02-02-2011, 10:30 AM   #1948
Your running the regular 540 can? They make a x12L 550 version for short course..
Nick George
Old 02-02-2011, 10:37 AM   #1949
Trader Rating: 36 (100%+)
The stock wheels have been solid for me. I have seen some get cracked, but mostly from bangin offa the pipes n walls, etc. The only real - on the TT is the stock foams.
NitroOB4You is offline   Reply With Quote
Old 02-02-2011, 10:42 AM   #1950
aegiswa's Avatar
Trader Rating: 14 (100%+)
I am running a Novak Kinetic 2s with a 540 Ballistic 6.5, 12T pinion. - no heat issues and stupid fast.
AegisWA <><
Ofna Hyper SC10 + 2S Kinetic/Ballistic 5.5 (550)
Ofna Hyper 10TT + 2S Kinetic/Ballistic 6.5 (540)
Team Associated - FT SC10 + 2S Kinetic/Ballistic 10.5
Mugen - MBX6 + Nova - hibernating 'till things warm up and dry-out....
aegiswa is offline   Reply With Quote
